ukie
After updating to OBS 28 and ASS 1.19.2 on Mac (10.15.7), I can't run any applescripts with "Run".
They worked on prior version of OBS and ASS, but now, I keep getting the error:
The action "run applescript" encountered an error not authorized to send apple events to...
The applescript application does run on its own, but not through ASS anymore.
Tried all levels of permissions under Security&Pravacy, to no avail.
This is the case for all applescript apps, not just the Moom example above.
ukie
Just saw @Kenshin9977 issue. Looks like this is the same issue just on a Mac. @Warmuptill is there a hidden app that runs to initiate the RUN sequence that needs additional permission?
Dustin D
If you make the ad into its own scene or source, yes. No different from anything else at that point.
Typing in chat might require a third party app or script, that is triggered using the Run action in a macro. That takes a single command line, that is passed to your operating system as if you typed it in a terminal, except that it necessarily inherits its environment from OBS, which is a little bit different than if you used the terminal to do it. Absolute paths, or some trickery in a script that is called directly and then does the thing you want, are needed to break out of that...but some things work just fine regardless of their environment, so you may not have to break out. Try it and see.
Well, I got a stream deck and it allows me to just push a button to run an ad. It would be nice if someone developed something for this.
The problem mentioned in this post was Windows specific and relating to the current working directory of the process.
So I don't believe the problems are related.
Seems like a special set of permissions is required since macOS 10.14+.
I will try to look into how those could be granted.
KiraRedpaw
So I know its been awhile since I posted here with my issues with the new version of OBS 28 and advanced scene switcher 1.91 but I've been using this time to try some things out. Good news I got my macro to work for changing the scene once the audio ends. Bad news is I can only get one macro to work at a time. If I enable more then one then they try to all run at the same time and sometimes they just outright dont work. Like at soon as I open OBS they will try to all play instantly even though none of the conditions have been met like Run when I start streaming which you cant do unless you are streaming...its weird. Maybe there is a simple checkbox that I haven't checked. Anyone want to help me out. Attached are pics of my current settings.
Remember I can get one to run but not more then one.
I have End and Stop turned off because of the issues I described above.
Have you tried "Perform actions only on condition change"? I wonder if without that, the logic is "at least 30 seconds" instead of "exactly 30 seconds". So all of them are trying to run all the time and cancelling each other. I pretty much always have that checked because it matches the way I think of things.
Or it could be that you're set to not run the switcher at all on OBS startup. I'm guessing you did that on purpose though, to keep it from going nuts.
KiraRedpaw
What would a condition change be? like the end of a song or the start of the stream? What is the condition?
Each item in the list of things to watch for, is a condition.
Instead of executing continuously for the entire time that the condition is true, it would only execute once when the condition becomes true. When the condition goes false and then true again, it executes once again, etc.
It'd sure be nice to clean up the Rube Goldberg a bit, but it does at least WORK now!
Master:
Slave:
Arron,
I found a workaround for this, by managing the global.ini file and changing the port number before launching each instances of OBS.
Not ideal, but it works.
Thanks to Jay in a different thread, I did clean it up a *little* bit, at least as far as a user would see. My setup/teardown bash script handles the global.ini juggling, and the interconnection python script now commands both instances of OBS directly:
Python:
message="Feature"
OBS_Master_Request.call_vendor_request(vendor_name="AdvancedSceneSwitcher", request_type="AdvancedSceneSwitcherMessage", request_data={"message": message})
OBS_Slave_Request.set_current_program_scene(message)
The Slave instance no longer needs any macros at all, and the Master no longer sends the WS event. So it's also down to only the functions that it actually needs for itself.
Still a bit Rube-Goldbergy overall, if you include the global.ini juggling, but I do like this version a lot better. Now I just need to fix up the timing so that the local mics never get into the local speakers during the transitions. That's probably also done better in the python script because sometimes the Master needs to be first and sometimes the Slave needs to be first.
I know I've been back and forth across the fence on this, but having seen it this way for a while, I think I do want to get rid of the python script and the global.ini juggling. It does put more work onto the macros, which are slightly more user-accessible than the scripts are, but I don't think my users are going to get there anyway.
I think the only obstacle to that would be a regex on the Current Scene. Is there a release coming up that includes that? Thanks!
The problem of the some of the macros immediately firing after starting to stream is caused by the fact that the scene switcher does not properly reset the duration modifiers you can add to condition when stopping the plugin.
So if the plugin is running, then stopped, and finally started up again the timers of the duration modifiers will compare the time between "stopped" and "finally started" instead of restarting from zero. (Hope that was worded somewhat coherent)
I have adjusted this behaviour in this build:
(Note you need to be logged into GitHub to be able to download it)
A few notes regarding your setup:
  • I think you can remove the "Stop" macro entirely and simply add the action to stop the stream to the "End" macro.
  • Your "Start" and "End" macro conditions could be true at the same time.
    I assume that you will not be playing either the "Starting music" or "Ending music" continuously, so you can run into the situation of both macros being executed at the same time.
  • The audio conditions checking if the volume of a particular source is below a certain threshold can and will be true even if the the audio source is not part of the currently active scene.
    So for example if you "Gaming" scene does not contain an instance of the "Ending music" source the "End" macro might still be executed.
    So you could add an additional condition checking if the audio source is currently showing on a particular scene.
Without really knowing your setup I would suggest to rework your "End" and "Start" macro to something similar to this:
You can of course adjust the "is showing" source condition with something that fits better to your setup. (E.g. checking if the current scene is / is not "Scene XYZ")
Hope that helps!
Let me know if you have any questions! :)
Sure, that shouldn't be too difficult.
A first version can be found here in a few minutes:
(As usual you need to be logged into GitHub to be able to download this build)
Let me know if that works for you! :)
It does! Thank you!
I had a little bit of trouble with what looked like the WebSocket Event not getting from Master to Slave, but a quick reboot and check again was okay. So I'll have to see if that persists.
A couple more questions:
It's been discussed before, but it's been a while. Is there a better way to do a startup initialization that never runs again?
The idea here is to wait until the Slave is also started, and then trigger the normal automation to set things right. Or if the Slave isn't running for a particular configuration, that's fine too.
Does the extra "Scene Changed" condition here make any difference at all? I figured it might be a slight optimization so it's not running the regex all the time, but is it really?:
Don't know if it makes a difference in the answers, but I have both Master and Slave running as fast as they'll go - 50ms - to try and approximate "instant". That is, from a hotkey in the Master that switches scenes, to the Slave switching scenes:
Using the "plugin is running" with a duration modifier "for exactly 0 seconds" should do the trick.
The second condition is still checked regardless.
Is the scene switcher using a considerable amount of CPU time in your setup? (Can be checked by comparing OBS CPU usage with the plugin stopped / started).
Okay. What I posted seems to work too, probably because of the "edge-detect button" as I think of it. I was just wondering what the "best practice" was, if there is one.
Low priority, but how hard would it be to make an obvious "run once at startup" function? My first thought was a separate section that had all of the actions available but no conditions, and that's when it runs, but far more flexible might just be a dedicated condition that is true between startup and the first time its actions are executed, and never again. Then it could be combined with other conditions to delay the "init code" until it can actually work (init AND something else), or to repeat the "init code" without copying it (init OR something else).
It might even replace the "plugin running" condition, since it seems silly to me to have a condition that always returns true. In a loop, yes, I can see a boolean constant to run that loop forever, and I've also used "if(false)" to (temporarily!) disable a section of code (it's also easily searchable). But neither of those are relevant here, as there are no loops and there's already a dedicated disable button.
Good to know. So it's not doing the "short-circuit" logic that most other languages do, where only the first condition is always checked, and each one after that is only checked if it still makes a difference.
This entire system barely registers on my CPU meter, but my experience with 8-bit microcontrollers (lots of projects with a single core @ 20MHz, using 4 clocks per instruction, and 300-some bytes of RAM for the entire system) leaves me a bit paranoid. So it's become automatic for me to estimate the cost of each comparison (boolean is best, numbers are okay, and strings take forever), and then guard an expensive one to only run when it's actually needed. This often leads to logically redundant (but cheap) conditions being added to the front, and sometimes odd ordering, just to take advantage of the "short-circuit" logic.
But if the "short-circuit" logic just doesn't exist here, then the "guard conditions" only hurt. Their cost is tiny, but still there (I'll probably never stop thinking about optimization), and they clutter things up to read later. I'll take them out.
I guess the option to "highlight recently matched conditions" kinda forbids the "short-circuit" logic. And that's a very nice feature to have!
Hi,@Warmuptill
I updated Chinese simplified localization file.
A NEW BUG FOUND:
AdvSceneSwitcher.mediaTab.states.playlistEnd="Ended(Playlist)" This code ,Name not using
I added my video space homepage in the general settings, I hope you won't mind, if you don't want it to exist, you can restore it to the original Chinese text, thanks to the plugin, I have made it into a tutorial video and sent it to Bilibili.
ahquamarine
So i just got the Twiddler 3 (handheld keyboard) and I wanted to set up a stream like bbjess where i can hit the keys to jump between scenes/cameras. The problem im running into is OBS can not distinguish between when im hitting my normal keyboard to type outside of OBS and keeps switching scenes when I don't want it to. Is there a way in Advances Scene Switcher to specify buttons from different keyboards or will I have to hold all sorts of combinations to not have the keys conflict?
ahquamarine
Is there a way to set up a macro so that whenever I switch to a scene it auto refreshes the camera? When i switch between screens my camera goes black and I have to hide it and unhide it for it to pop back up. is there a way to automate this?
