artsyomni
Really like how robust this plugin is. Excellent work!
Just wanted to make a suggestion. I think it'd be really helpful if there was an option to have the settings used under the Transitions tab in the Advanced Scene Switcher apply to switching scenes manually from the main OBS window, overriding whatever transition is set in the main window.
Perhaps this could be implemented as a checkbox under the Transitions Tab (eg: "Override active transition for manual scene switching" or something like that).
Just as a use case example, I have a set of scenes I use for art streams, and one of the scenes is a simple "I'll be right back!" screen ("BRB"). I want to use a specific transition when switching from my "Photoshop" scene to the "BRB," and another specific one when switching back from "BRB" to "Photoshop." Obviously I can this by having Quick Transitions handy, but it would be nice to not have to worry about accidentally hitting the wrong button and using the wrong transition for a specific scene switch.
Draven Meex
Idle Detection isn't working. I check the box, close the window, come back to the tab and the box is unchecked. No real help on the tab, either... just "has been added".
Lauren Jackson
I think you need to update your windows install instructions. I'm not the best when it comes to fiddling with programs but it took me a while to figure out how to actually install it. For those of you who are stuck like I was...
1. Download and extract the zip file. Open 'SceneSwitcher', select your operating system, open 'obs-studio', open 'obs-plugins', select your system type (32/64-bit) and cut/copy the .dll file. My file path was: C:\Users\Lauren\Downloads\SceneSwitcher\SceneSwitcher\Windows\obs-studio\obs-plugins\64bit
2. Find the Program file for obs-studio, open 'obs-plugins', select 32/64-bit. My file path was: C:\Program Files (x86)\obs-studio\obs-plugins\64bit
3. Paste the .dll file in the location mentioned above.
4. Reopen the OBS studio program and select the Tools menu. You should now see the Advanced Scene Switcher option.
Hope this helps clear the mud!
Lauren
diffi
Great job on this plugin, it's really needed. :) A have a quick question: trying to set up different transitions for different scenes, decided to go with the "Switching of scenes based on file input" way. It switches OK, but the defined transitions in the Transitions tab don't have any effect. Is this a bug, or is there something I need to put in the txt file in the first place (right now I'm just specifying the scene name).
Great thanks, cheers! :)
That is a bug (simply forgot to add the transition check there). I will try to fix it soon.
I did some looking through the forums in regards to this plugin and since I don't know the terminology, I thought I would just come out and ask.
I don't have a very complicated setup, but I was curious if I was able to mute my mic when I press the hotkey for my be Right Back screen?
This is currently not possible with this plugin.
diffi
Why not add a mute / unmute hotkey in the OBS itself, same as your BRB scene? Does it conflict or something?
Warmuptill updated Automatic Scene Switching with a new update entry:
Added option for default transition per scene. Added Idle Detection for MacOS. Bug fixes
  • Added the option to set a default transition for each scene. This is meant for manual scene switching and not the automated ones caused by the scene switcher itself. (The transitions set for automated scene changes take higher priority)
  • Transitions tab now also works for scene changes if the scene is read from a file (Thanks to diffi...
Stroe Radu
Hi there, is there someone here who uses this scene auto-switcher for streaming poker on Pokerstars?
1. I don't know how to make Jivaro appear while using the window captures, any idea how can this be done? :(
2. I am struggling to make autoswitches between scenes..sometimes it works, sometimes it gets stuck on one of the tables :(...I am putting a table on each scene and map each table to each scene on the plugin, I use duplicate scenes which have only the poker table (window) as the difference but it's not working..I might be going wrong about doing this...any tips?
Thank you!
Thank you!
I am not familiar with Jivaro so I cant really help there.
Are you using the built in scene switcher or this plugin? (if you are using this plugin which parts of it?) It would be great if you can describe your setup in more detail (what are the window names/ are you using regular expressions) or even take a screenshot of your settings and send it to me so I can try to assist you further!
Rhindon7
With 11 pages of comments, I don't know if this has been addressed or not...
I downloaded, unzipped, and copied the obs-studio folder in your plugin to the OBS installation folder (later to the plugins folder) and it didn't seem to recognize that there's this new plugin available for the Advanced Scene Switcher. According to your instructions on your website, I need to look for the Tools drop-down menu, but the latest version of OBS doesn't seem to have that option. I've searched everywhere else and I don't know what to do to access this plugin.
I'm using OBS v0.659b.
Any thoughts on how I can make this work?
Thank you! :)
RytoEX
Thank you! :)
This plugin is for OBS Studio, not OBS Classic (regular OBS, old OBS, OBS v0.6xx). That's the issue you're having.
timpa009
Problem: Whenever I set my OBS to english (Normally I run swedish) it crashes instantly (as soon as I start OBS) with this message: "Whoops, OBS has crashed! Would you like to copy the crash log to the clipboard? (Crash logs will still be saved to blablabla...)" [Yes/No]
[Crash Log]
[Crash Log]
Sorry about that!
I cant recreate the crash on my end, so I sent you a message on how you can send me the settings of you scene switcher.
EDIT: Found the source of the crash, just waiting for confirmation that it is indeed fixed
mcdoolz
Hey, apologies for posting without installing and looking for myself, but can this utility switch scenes based on microphone input?
I would like the camera to switch depending on the source of audio.
  • Audio is received by microphone
  • While gain is < X, count seconds
  • If count reaches threshold switch scene to X
That is currently not supported.
Something similar is implemented however, based on keyboard / mouse inputs. Maybe that could work for you.
