Resource icon
3D stinger transition 0.3.1
ElDonad
ElDonad submitted a new resource:
3D stinger transition - A 3D transition between scenes, with custom video support
A little experimental plugin aimed at generating 3D transitions. Currently only one transition is available and working, although the plugin is a bit quirky, it will definitively be improved in the future ! (also this is my first OBS related project, so lot of stuff to learn and overcome...)
How to use :
  • Install the plugin from the github release page
  • Create your own transition video using the provided blender file (you will need to create a video with...
ElDonad updated 3D stinger transition with a new update entry:
Custom JSON microcode
The transformation can now be controlled via inputting a JSON formatted text that describes the movement. Sample below :
JSON:
    "swap_time": 0.5,
    "transforms": [
            "begin_frame": 0.5,
            "end_frame": 0.7,
            "easing": "sinusoidal | linear | constant",
            "transformation": "scale | translate | rotate",
            "params": {
                "x": 1.0,
                "y": 0.1,
                "z": 1.0...
This is so dope. Was accomplishing a similar thing with a two pc setup and a lot of obs command line script stuff. This is WAY cleaner. Excited for further updates!
First release candidate !
First release candidate​
Lots of changes since the last release, beginning with the addition of a new mode of movement description : interpolation ! Instead of describing the scene's movement as a stack of transforms, the scene's position is recorded x times each frame (depending on the chosen resolution), and the OBS plugin uses this data to approximate the best it can the scene's actual position during the transition.
Also, the blender plugin is out...
It's a simple question, but why isn't it in video format? Because, to put it simply, this is a 3D video material of "Stinger", one of the transitions that OBS originally has, right? It would make sense if this was a plug-in that could edit decorations, text, colors, etc. in 3D videos within OBS, but in the end, each person has to output it using Blender on their own, right? Even though it can be edited, isn't it the same as video material? Where are the plugin elements located?
I love the concept here, but the delay between the transition movement and the video file is very inconsistent, which makes keeping the two aligned impossible and the result therefore unusable. Tuning with the static delay isn't enough because the delay varies depending on what scenes you're switching between, likely based on how much is in each scene. I realize it's been years since this plugin's been updated, but there's really nothing else like this available, and I would love it if this could be fixed, because it would easily be a 10/10 gamechanger with some polish.
