0.473b test 11
Status
Not open for further replies.
Blackhive
Re: 0.473b test 6
Been using this for the last few days with no major issues at all. Desktop volume option works great.
DoK_-
Re: 0.473b test 6
Hi!
i've switched to the latest version, the 0.473b(test 6) and since i've made the switch i got this error when i try to start streaming on twitch.tv : http://imgur.com/Ka07PFs
Open Broadcaster Software v0.473b (test build 6) - 64bit ( ^ω^)
CPU Name: Intel(R) Core(TM) i7 CPU         930  @ 2.80GHz
CPU Speed: 3990MHz
Physical Memory:  6142MB Total, 3875MB Free
stepping id: 5, model 10, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
monitor 1: pos={0, 0}, size={1440, 900}
Aero is Disabled
Adapter 1
  Video Adapter: ATI Radeon HD 5800 Series
  Video Adapter Dedicated Video Memory: 1064140800
  Video Adapter Shared System Memory: 2951966720
Using automatic low latency mode
  Multithreaded optimizations: Off
  Base resolution: 952x600
  Output resolution: 952x600
Loading up D3D10...
Playback device {0.0.0.00000000}.{51a574db-d94e-42ba-bd2d-daae6236ef88}
Using desktop audio input: Speakers (Realtek High Definition Audio)
Using auxilary audio input: Microphone (Realtek High Definition Audio)
Audio Encoding: AAC
    bitrate: 64
Using graphics capture
Using custom x264 settings: "--rc-lookahead 60 --ref 16 --subme 10 --b-adapt 2 --direct auto --me tesa --bframes 16 --merange 24  --trellis 2 --crf 10"
x264: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2
x264: profile High, level 3.1
Video Encoding: x264
    fps: 25
    width: 952, height: 600
    preset: slow
    CBR: no
    CFR: no
    max bitrate: 833
    buffer size: 3000
    quality: 5
  Server selection: rtmp://live-lhr.justin.tv/app
librtmp error: RTMP_Connect0, failed to bind socket. 10049 (Unknown error)
Total frames rendered: 86, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Number of times waited to send: 0, Waited for a total of 0 bytes
Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
x264: frame I:1     Avg QP:13.00  size:   939
x264: frame P:3     Avg QP:13.00  size:    33
x264: frame B:7     Avg QP:16.57  size:    29
x264: consecutive B-frames:  7.7%  0.0%  0.0% 92.3%
x264: mb I  I16..4: 100.0%  0.0%  0.0%
x264: mb P  I16..4:  0.0%  0.0%  0.0%  P16..4:  0.0%  0.0%  0.0%  0.0%  0.0%    skip:100.0%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.0%  0.0%  0.0%  direct: 0.0%  skip:100.0%
x264: 8x8 transform intra:0.0%
x264: direct mvs  spatial:28.6% temporal:71.4%
x264: coded y,uvDC,uvAC intra: 0.0% 0.0% 0.0% inter: 0.0% 0.0% 0.0%
x264: i16 v,h,dc,p: 97%  0%  3%  0%
x264: i8c dc,h,v,p: 100%  0%  0%  0%
x264: kb/s:22.51
Profiler results:
frame - [100%] [avg time: 3.128 ms] [avg calls per frame: 1] [children: 91.3%] [unaccounted: 8.7%]
| scene->Preprocess - [0%] [avg time: 0 ms] [avg calls per frame: 1]
| video encoding and uploading - [91.3%] [avg time: 2.856 ms] [avg calls per frame: 1] [children: 28.9%] [unaccounted: 62.4%]
| | CopyResource - [0.032%] [avg time: 0.001 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [11.8%] [avg time: 0.368 ms] [avg calls per frame: 0]
| | call to encoder - [17.1%] [avg time: 0.534 ms] [avg calls per frame: 0]
| | sending stuff out - [0%] [avg time: 0 ms] [avg calls per frame: 0]
i don't see other related cause ... and i had no problem at all with the test 3, the one i was using before the test 6.
Thanks
bilehazard
Re: 0.473b test 6
Need to make sure your Bind to Interface settings are correct under the advanced tab. Once thats correct, you should be able to connect without any problems.
Lain
Lain
Re: 0.473b test 7
just uploaded test 7, has some game capture tweaks (potentially a little better performance hopefully, less memory usage as well), fixed a problem it was having with dx10 games as well and a few graphical mods that were having problems.
optimized mp4 file output so that compilation and the end is almost instant.
fixed the delay feature as well, should work with the new network code
Muidi
Re: 0.473b test 7
Hi.
Tried to stream Trials Evolution Gold with test7, and it shows only black screen. Tried OBS_0473b_network_test1 and it works.
Open Broadcaster Software v0.473b (test build 7) - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
CPU Speed: 3300MHz
Physical Memory:  4095MB Total, 4095MB Free
stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
monitor 1: pos={0, 0}, size={1920, 1200}
monitor 2: pos={-1920, 11}, size={1920, 1080}
Aero is Disabled
Adapter 1
  Video Adapter: NVIDIA GeForce GTX 460
  Video Adapter Dedicated Video Memory: 1025966080
  Video Adapter Shared System Memory: 3220779008
Adapter 2
  Video Adapter Dedicated Video Memory: 1026097152
  Base resolution: 1920x1080
  Output resolution: 1280x720
Loading up D3D10...
Playback device {0.0.0.00000000}.{1ead44f0-4123-4218-8336-aa1dc01b4e4d}
Using desktop audio input: Realtek Digital Output(Optical) (Realtek High Definition Audio)
Using auxilary audio input: Mic in at front panel (Pink) (Realtek High Definition Audio)
Audio Encoding: AAC
    bitrate: 128
Using text output
x264: profile High, level 3.2
    fps: 60
    width: 1280, height: 720
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2500
    buffer size: 2500
    quality: 6
Warning -- D3D10Texture::CreateFromSharedHandle: NULL handle value.
Warning -- SharedTexCapture::Init: Could not create shared texture
Total frames rendered: 464, number of frames that lagged: 1 (0.22%) (it's okay for some frames to lag)
x264: frame I:2     Avg QP:22.50  size:  1756
x264: frame P:103   Avg QP:32.35  size:   190
x264: frame B:306   Avg QP:38.90  size:    41
x264: consecutive B-frames:  0.7%  0.0%  0.0% 99.3%
x264: mb I  I16..4: 98.9%  0.1%  1.0%
x264: mb P  I16..4:  0.1%  0.0%  0.0%  P16..4:  2.2%  0.1%  0.0%  0.0%  0.0%    skip:97.6%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.0%  0.0%  0.0%  direct: 0.0%  skip:100.0%  L0:31.8% L1:29.7% BI:38.6%
x264: 8x8 transform intra:0.1% inter:11.0%
x264: coded y,uvDC,uvAC intra: 0.7% 0.2% 0.0% inter: 0.1% 0.0% 0.0%
x264: i16 v,h,dc,p: 95%  2%  3%  0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25%  6% 56% 13%  0%  0%  0%  0%  0%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 42% 18% 26%  1%  2%  3%  3%  2%  2%
x264: i8c dc,h,v,p: 98%  2%  0%  0%
x264: Weighted P-Frames: Y:37.9% UV:0.0%
x264: kb/s:41.73
Profiler results:
frame - [100%] [avg time: 3.319 ms] [avg calls per frame: 1] [children: 29.4%] [unaccounted: 70.6%]
| scene->Preprocess - [0.301%] [avg time: 0.01 ms] [avg calls per frame: 1]
| video encoding and uploading - [29.1%] [avg time: 0.966 ms] [avg calls per frame: 1] [children: 28.2%] [unaccounted: 0.874%]
| | CopyResource - [0.331%] [avg time: 0.011 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.121%] [avg time: 0.004 ms] [avg calls per frame: 0]
| | call to encoder - [27.8%] [avg time: 0.922 ms] [avg calls per frame: 0]
Edit: Also tested test6, and it works with Trials.
Edit2: captureHookLog
D3D9 Present
InitDXGICapture: factory->CreateSwapChain failed, result = 2289696769
Syssx
Re: 0.473b test 7
This happens everytime when I select TERA in game capture (test 6 was fine):
This crash appears to have occured in the 'c:\windows\system32\nvwgf2um.dll' module.
Fault address: 5DD97E08 (c:\windows\system32\nvwgf2um.dll)
OBS version: Open Broadcaster Software v0.473b (test build 7)
Crashing thread stack trace:
Stack    EIP      Arg0     Arg1     Arg2     Arg3     Address
1438E26C 5DD97E08 062337B0 01126E7C 00000001 00000000 nvwgf2um.dll!0x5dd97e08
1438E2DC 5DEEF2DC 03590048 01126E9C 00000000 71ECCE34 nvwgf2um.dll!0x5deef2dc
1438E364 5DEDA633 03590048 1438E510 01126E9C 71ECCE34 nvwgf2um.dll!0x5deda633
1438E384 6FDFC154 1438E510 01126E9C 71ECCE34 1438E3C0 nvumdshim.dll!0x6fdfc154
1438E39C 6FDFD53C 03485E40 1438E510 01126E9C 71ECCE34 nvumdshim.dll!0x6fdfd53c
1438E3B0 6FDF400E 1438E510 01126E9C 71ECCE34 1438E558 nvumdshim.dll!0x6fdf400e
1438E3C8 6FDF53EC 0113202C 1438E510 01126E9C 71ECCE34 nvumdshim.dll!0x6fdf53ec
1438E3DC 71ECC93B 01126E7C 00000000 1438EAFC 01BE1AD2 d3d11.dll!0x71ecc93b
1438E560 71ECCC4F 00000004 1438F548 01126DE0 01126E10 d3d11.dll!0x71eccc4f
1438F4B8 71ECB618 01121BA4 00000004 1438F548 0000001C d3d11.dll!0x71ecb618
1438F4D0 71ECC5EC 00000004 1438F548 0000001C 01126DE0 d3d11.dll!0x71ecc5ec
1438F50C 71ECBA64 01126E00 00000004 1438F5E0 0000001C d3d11.dll!0x71ecba64
1438F5C4 71ECB254 011218B0 00000004 1438F6D4 0000001C d3d11.dll!0x71ecb254
1438F6A8 71ECCFC9 01121BE4 00000003 00000001 00000006 d3d11.dll!0x71eccfc9
1438F734 71ED320A 00000000 01127AF8 1438F770 1438F76C d3d11.dll!0x71ed320a
1438F750 00D8CC55 000005A0 00000384 1438F808 74314351 obs.exe!D3D10Texture::CreateFromSharedHandle+0x125
1438F78C 00D8B258 000005A0 00000384 00000006 C0001382 obs.exe!D3D10System::CreateTextureFromSharedHandle+0x18
1438F79C 74314351 1438F808 0455A04E 00D75900 1438F868 graphicscapture.dll!SharedTexCapture::Init+0x151
1438F7E0 74312CEB 0455AFE6 012A4120 00000002 00000000 graphicscapture.dll!GraphicsCaptureSource::NewCapture+0x2bb
1438F83C 74312ED0 00000021 01240400 00DA67DF 70A4FC07 graphicscapture.dll!GraphicsCaptureSource::Preprocess+0xd0
1438F870 743C1E6B 70A4FC07 00000000 00000000 1438FD6C obsapi.dll!Scene::Preprocess+0x2b
1438F87C 00DA67DF 00000001 6C710000 046FF140 1438F8BC obs.exe!OBS::MainCaptureLoop+0x82f
1438F8A4 7514C5EC 6D191BF8 1438F8F4 6C8FD8CF 0000000C kernelbase.dll!0x7514c5ec
1438F8B8 6C9054B4 0000000C 6C8FD8B8 010001C5 3D072B02 igd10umd32.dll!0x6c9054b4
1438F8C4 6C8FD8CF 000043F7 012A4000 00000002 00000001 igd10umd32.dll!0x6c8fd8cf
1438F8FC 3B02E400 012A4000 00000002 00000001 0000021C <unknown>!0x3b02e400
A minidump was saved to C:\Users\honda_000\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-03-02_4.dmp.
List of loaded modules:
Base Address      Module
Log:
CPU Name: Intel(R) Core(TM) i7-3612QM CPU @ 2.10GHz
CPU Speed: 2095MHz
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
Windows Version: 6.2 Build 9200
Aero is Enabled
Adapter 1
  Video Adapter: NVIDIA GeForce GT 630M
  Video Adapter Dedicated Video Memory: 2096693248
  Video Adapter Shared System Memory: 2147037184
Adapter 2
Adapter 3
  Video Adapter: Microsoft Basic Render Driver
  Base resolution: 1440x900
  Output resolution: 1440x900
Loading up D3D10...
Playback device {0.0.0.00000000}.{c02de1e7-9783-4a35-8841-16e054ef064c}
Using desktop audio input: Reproduktory (Realtek High Definition Audio)
Using auxilary audio input: Mikrofon (Realtek High Definition Audio)
Audio Encoding: AAC
    bitrate: 256
Using text output
Using bitmap image
Using bitmap image
Using Monitor Capture
x264: profile High, level 4.0
    fps: 30
    width: 1440, height: 900
    preset: veryfast
    CBR: no
    CFR: yes
    max bitrate: 1100
    buffer size: 1100
    quality: 6
Syncing audio to video time
  New Scene
Using Slide Show
Using bitmap image
  New Scene
  New Scene
Using bitmap image
  New Scene
Using text output
  New Scene
  New Scene
Using bitmap image
Don't know if this will be useless but:
D3D9 Present
DoD3D9GPUHook: success
austinmrs
Re: 0.473b test 7
im using windows capture on windows 8, it is good, right ? i dont want to use game capture, because i have to change scene every time im on windows, i like windows capture, because i dont have to have many scenes and that stuff xd
Affinitii
Re: 0.473b test 7
I cannot seem to get OBS test 7 to attach to World of Warcraft 64. It shows up when I add a game source, but the screen remains black. WOW32 works fine, but WOW64 does not. WOW64 was working up until this build, now even when I load the beta version of OBS it will not attach to WOW64.
Using Windows 8 if that matters.
There's no errors or anything in the Logs, it all looks normal.
dehixem
Re: 0.473b test 7
Used Test7 and got a bug that screwed my vidéo !
My webcam "stuttered" : every 2 frames repeat twice, then go on to the next two frames. It's really bizarre, but ruined teh vidéo :s
Going back to test 6 ^^'
Triksterism
Re: 0.473b test 7
These test versions have broken the game capture option. You need to run 32 bit OBS to capture 32 bit games again and so on, otherwise your games will show up as a black screen (with audio).
ProClub
Re: 0.473b test 7
Triksterism said:
These test versions have broken the game source option. You need to run 32 bit OBS to capture 32 bit games again and so on, otherwise your games will show up as a black screen (with audio).
I just tried Test 7 and didn't have that problem running 64bit. Only thing I noticed was that I would get horrible in game frame drops even tho my FPS is over 130+ in Black Ops 2. Stopped stream and it would be really smooth.
ProClub
Re: 0.473b test 7
Turned off Automatic low latency mode in advanced. Forgot I checked that. To test if it would work for me. It doesn't lol. Everything seems good now.
Blackhive
Re: 0.473b test 7
@Triksterism I dont have that issue. Try running 64 bit obs as administrator.
also, bug report. for some reason when i try to drag someone in teamspeak from one channel to another it crashes obs. crash log attached
  • OBSCrashLog2013-03-03_1.txt
ProClub
Re: 0.473b test 7
I finally found out what was making my ingame FPS drop even tho it was high. Firefox Flash player. I know everyone recommended to not view your stream while casting, but never really thought it mattered for me until I noticed it would freeze the past month, but not in Chrome. Tested 60FPS and it's smooth and also saved about 10-15% CPU usage. Usually would be 80-90% usage and now down to around 70-75%.
Lain
Lain
Re: 0.473b test 7
blackhive - not a bug with OBS, bug with drivers or something. -- correction: was a bug with obs that made me think it was a bug with drivers
Aelthan
Re: 0.473b test 7
Hello and first of all, thanks for this great software.
I have systematic crashs when I start a stream or a test since the 0.473b test 6 version (and on test 7 too). Through tests, I've notice it only crash when the "Use Multithread Operation" box is ticked. But if it isin't, the performance suffers baddly... I've joined the crashlog. I hope it helps, at least a little. I'm working with test 5 for now that works perfectly ;)
For the crashdump : https://www.dropbox.com/s/mow8n6s14w0vq ... 04_4.dmp?m
  • OBSCrashLog2013-03-04_4.txt
Haliinen
Re: 0.473b test 7
Think I found a bug in the test 7 build with my Elgato Game Capture HD, in the preview window it shows smooth 60 fps, when I attempt to save the recording to a file it's choppy as hell. I did the exact same test in 0.472b and it's fine there. Do you think you can try to reproduce this one Jim? I think it has to do with how it builds the file since it works differently now doesn't it since 0.472b? But I can't say what causes this.
CPU Name: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
CPU Speed: 4500MHz
Physical Memory:  4095MB Total, 3452MB Free
stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
monitor 1: pos={0, 0}, size={2560, 1600}
Aero is Enabled
Adapter 1
  Video Adapter: NVIDIA GeForce GTX 580
  Video Adapter Dedicated Video Memory: 1560739840
  Video Adapter Shared System Memory: 2683908096
  Base resolution: 1280x720
Loading up D3D10...
Playback device {0.0.0.00000000}.{7e0878bb-1753-46c7-a0d7-05d677ba48be}
Using desktop audio input: Speakers (ASUS Xonar Essence STX Audio Device)
Using auxilary audio input: Microphone (ASUS Xonar Essence STX Audio Device)
Audio Encoding: MP3
    bitrate: 192
    device: Elgato Game Capture HD,
    device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
    chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, fps: 30-30, fourCC: 'UYVY'
Using directshow input
Using custom x264 settings: "crf=18"
    fps: 60
    preset: fast
    CBR: no
    CFR: yes
    max bitrate: 20000
    buffer size: 20000
    quality: 14
Total frames rendered: 4532, number of frames that lagged: 2 (0.04%) (it's okay for some frames to lag)
Total duplicated CFR frames: 13
x264: frame I:19    Avg QP:12.51  size: 91265
x264: frame P:1209  Avg QP:16.57  size:  9767
x264: frame B:3232  Avg QP:22.34  size:  1816
x264: consecutive B-frames:  2.5%  1.3%  3.8% 92.4%
x264: mb I  I16..4: 29.0% 42.8% 28.3%
x264: mb P  I16..4:  2.5%  2.0%  0.8%  P16..4: 18.0%  8.0%  4.7%  0.0%  0.0%    skip:64.1%
x264: mb B  I16..4:  0.5%  0.3%  0.1%  B16..8:  9.5%  2.3%  0.3%  direct: 2.6%  skip:84.6%  L0:41.4% L1:51.5% BI: 7.1%
x264: 8x8 transform intra:38.1% inter:55.1%
x264: coded y,uvDC,uvAC intra: 37.1% 67.7% 35.6% inter: 3.5% 7.3% 1.7%
x264: i16 v,h,dc,p: 31% 47%  9% 14%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 37% 28%  3%  2%  2%  4%  3%  5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 25% 16%  6%  6%  7%  6%  6%  6%
x264: i8c dc,h,v,p: 42% 35% 16%  7%
x264: Weighted P-Frames: Y:1.5% UV:1.4%
x264: ref P L0: 68.3% 31.7%
x264: ref B L0: 79.7% 20.3%
x264: ref B L1: 88.1% 11.9%
x264: kb/s:2089.03
Profiler results:
frame - [100%] [avg time: 4.211 ms] [avg calls per frame: 1] [children: 91.1%] [unaccounted: 8.88%]
| scene->Preprocess - [10.2%] [avg time: 0.429 ms] [avg calls per frame: 1]
| video encoding and uploading - [80.9%] [avg time: 3.408 ms] [avg calls per frame: 1] [children: 22.4%] [unaccounted: 58.5%]
| | CopyResource - [0.356%] [avg time: 0.015 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.285%] [avg time: 0.012 ms] [avg calls per frame: 0]
| | call to encoder - [21.7%] [avg time: 0.913 ms] [avg calls per frame: 0]
| | sending stuff out - [0.095%] [avg time: 0.004 ms] [avg calls per frame: 0]
Joe33345
Re: 0.473b test 7
I'm having the same problem as Haliinen but it happens on anything I record. Not just my Capture Device.
JoeNumbers
Status
