BetterStreams - Stream Automation
Semi-free BetterStreams - Stream Automation 2.0.0
Features:
  • Added giveaway feature
    • Link your giveaway to a Custom Reward and users can redeem channel points to enter
    • Resetting the giveaway rejects all entrants redemptions
    • Completing the giveaway accepts all entrants redemptions
    • Pausing the giveaway will disable the custom reward so viewers can no longer enter
Bugfixes:
  • Improved some back-end code to better handle rate limiting
  • Solved an issue causing a crash on the back-end
We're offering 20% off Better Points Pro to any new customers through January!
Just use the promo code below during checkout.
Give your users a voice!
Don't forget we have a promo running until the end of January, during checkout if you use the code FK2020 you will receive 20% off any purchase!
Features
  • Added a Text-To-Speech module: Streamers can now create Custom Rewards that read out viewer input with the system narrator
  • Added a TTS Settings module to the main menu, use this to set up TTS
  • The Custom Reward form now properly gives feedback for errors
Bugfixes
  • Fixed a bug where the color picker would display the wrong color
  • Fixed a bug that was causing the test button to not work properly on OBS Events
Features
  • Users can now set the background color on custom rewards
  • Added the ability to set redemption limits per user and per stream
  • Enable or disable custom rewards directly from the rewards list
  • Your custom reward image is now displayed within the reward list
Bugfixes
  • Custom reward form will no longer randomly become disabled
  • Cause of the random server crashes has been identified and fixed
We have just completed a major update to Better Points, and are now moving away from using a browser extension. The extension will be retired in the coming months (with plenty of notice).
We've restarted the versioning as this is a completely new project built on a new framework. It currently offers more features than the previous extension version and will continue to receive updates with lots of content planned for 2021.
Features:
  • Dedicated website for managing your custom channel point rewards and OBS events
  • Easier linking for connecting rewards to events (more link types coming soon!)
  • More properties for sources such as position, scale and rotation
  • Instead of a single starting scene a list can be provided to allow an event to work in multiple scenes
  • OBS integration so that your scenes, sources and filters can be picked from a list instead of typed (OBS must be open and connected)
  • OBS Connection module to more easily track if OBS is connected properly
  • Fixes black text when in light mode on twitch
  • Fixes scroll not working in the new modal window
This update brings a new UI design which conceptually separates events from a redemption and introduces a new component called the "Event List". While making it easier to manage all of your existing events, this in turn allows multiple redemptions to be linked to a single event.
Features:
  • New Event List
  • Updated UI Layout
  • App window is now separated and is always visible in the queue page
This is a small patch to address changes to the Twitch redemption queue page
FIXES:
  • Small update that solves the constant reconnecting that can sometimes occur.
NOTE:
  • We are still waiting on Chrome to approve this version and allow the app back onto the Chrome webstore. We appreciate your patience.
NEWS:
Features:
  • Modify sources in other scenes
  • Return to starting scene
  • Set visibility on filters
  • Redemption events will no longer play if there is currently one in progress
