Question / Help Zoom into youtube via OBS - I need advice
Heidi Hornlein
Hi there,
I finally succeeded to bring the audio over from Zoom into Youtube via OBS and Soundsource.
I have still several problems:
  • My voice records much louder than the others in the Zoom room
    • In OBS bot Mic/Aux and Audio Input capture move when I speak and when the others speak, I cannot seperate it. (With nobody in Zoom only Mic/Aux moves)
    • They move and I can hear the zoom room only via OBS unmuted. I tried different setting
    • I seems to come over to Youtube all right, (apart from the different volume issue), but I hear myself twice in my headphones which is really disturbing
  • The imaGE IS FLICKERING, I have already modified the settings. What bitrate do you think I should take?
Narcogen
You have iShowU in there as a device twice. Set the 2nd one to disabled.
You're sending audio from your mic to an iShowU device. Is there a reason?
