Greendweller
Hi i recently started using obs and its a great app and farly easy to understand if you know a bit of the technical stuff.
However i do feel like my setup can be further improved with the things that i have but i'm not sure where to start.
Pc is running on 1666mhz bus-speed andwill oc to 4.2 ghz on demand.
Is there anything you would change with this setup?
Ah and i forgot to mention that i will mostly stream WoW on ultra settings with music in de background and the game sounds (have mic on ptt).
*edit* Typo's
16:54:10: Open Broadcaster Software v0.542b - 64bit ( ^ω^)
16:54:10: -------------------------------
16:54:10: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
16:54:10: CPU Speed: 3332MHz
16:54:10: Physical Memory: 8159MB Total, 5671MB Free
16:54:10: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
16:54:10: monitor 1: pos={0, 0}, size={1920, 1080}
16:54:10: monitor 2: pos={-1280, 33}, size={1280, 1024}
16:54:10: Windows Version: 6.1 Build 7601 S
16:54:10: Aero is Enabled
16:54:10: OBS Modules:
16:54:10: Base Address Module
16:54:10: 000000003FF80000 OBS.exe
16:54:10: 00000000E7650000 OBSApi.dll
16:54:10: 00000000F5A20000 DShowPlugin.dll
16:54:10: 00000000E9CF0000 GraphicsCapture.dll
16:54:10: 00000000F5A80000 NoiseGate.dll
16:54:10: 00000000E9CD0000 PSVPlugin.dll
16:54:10: 00000000F11E0000 scenesw.dll
16:54:10: ------------------------------------------
16:54:10: Adapter 1
16:54:10: Video Adapter: NVIDIA GeForce GTX 560 Ti
16:54:10: Video Adapter Dedicated Video Memory: 1025966080
16:54:10: Video Adapter Shared System Memory: 3220779008
16:54:10: =====Stream Start: 2013-07-27, 16:54:10===============================================
16:54:10: Multithreaded optimizations: On
16:54:10: Base resolution: 1920x1080
16:54:10: Output resolution: 1280x720
16:54:10: Loading up D3D10...
16:54:11: Playback device Default
16:54:11: ------------------------------------------
16:54:11: Using desktop audio input: Luidsprekers (Realtek High Definition Audio)
16:54:11: Using 5.1 speaker setup
16:54:11: Using auxilary audio input: Microfoon (USB-audioapparaat)
16:54:11: Audio Encoding: MP3
16:54:11: bitrate: 192
16:54:11: device: USB-videoapparaat,
16:54:11: device id \\?\usb#vid_046d&pid_0990&mi_00#7&322d27b4&1&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
16:54:11: chosen type: YUY2, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-2000000, fourCC: 'YUY2'
16:54:11: audio device: Uitzetten,
16:54:11: audio device id Disabled,
16:54:11:
16:54:11: Using directshow input
16:54:11: Using text output
16:54:11: Using graphics capture
16:54:11: Video Encoding: x264
16:54:11: fps: 48
16:54:11: width: 1280, height: 720
16:54:11: preset: veryfast
16:54:11: CBR: yes
16:54:11: CFR: no
16:54:11: max bitrate: 3500
16:54:15: Total frames rendered: 212, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
16:54:15: =====Stream End: 2013-07-27, 16:54:15=================================================
16:54:31:
16:54:31: Profiler results:
16:54:31:
16:54:31: ==============================================================
16:54:31: frame - [100%] [avg time: 1.427 ms (cpu time: avg 1.986 ms, total 421.203 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.21%]
16:54:31: | frame preprocessing and rendering - [36.2%] [avg time: 0.516 ms (cpu time: avg 0.883 ms, total 187.202 ms)] [avg calls per frame: 1] [children: 7.22%] [unaccounted: 28.9%]
16:54:31: | | scene->Preprocess - [7.22%] [avg time: 0.103 ms (cpu time: avg 0.147 ms, total 31.201 ms)] [avg calls per frame: 1]
16:54:31: | video encoding and uploading - [63.6%] [avg time: 0.908 ms (cpu time: avg 1.103 ms, total 234.001 ms)] [avg calls per frame: 1] [children: 61.5%] [unaccounted: 2.1%]
16:54:31: | | flush - [5.61%] [avg time: 0.08 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
16:54:31: | | CopyResource - [2.03%] [avg time: 0.029 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:54:31: | | conversion to 4:2:0 - [0.14%] [avg time: 0.002 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:54:31: | | call to encoder - [53.7%] [avg time: 0.767 ms (cpu time: avg 1.03 ms, total 218.401 ms)] [avg calls per frame: 0]
16:54:31: | | sending stuff out - [0%] [avg time: 0 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:54:31: | Convert444Threads - [2.62e+003%] [avg time: 37.338 ms (cpu time: avg 1.324 ms, total 280.8 ms)] [avg calls per frame: 1]
*edit* Typo's
