Window Capture Problems
CrypticCherry
I tried to use the Window Capture (Xcomposite) to record a game I was playing, and it gave me a black screen. I enabled the alpha-less texture format and it shows the game but with a heavy red tint over it. This is the same with any window I try to capture. OBS it self also says it's version 0.0.1 and won't let me check for updates. Some say that happens if you install this from the linux software manager but I downloaded it from the terminal with apt. Thanks for any help.
  • 2020-06-18 18-14-04.txt
