Bug Report Window Capture Problem Not Seen Before
ShafferSmash
Ok so I just had to reinstall Window 10 on my laptop along with everything esle like OBS, Teeboard, etc. When I went to capture my Hauppauge Gaming Device through its window with Window Capture, it did not get the whole window, and added an extra black edge to the right and bottom sides of it, while also cutting off some of the left of the window. And it's doing that for all my window captures no matter what it is. Switching from inner to outer window doesn't change a single thing.
Here's me capturing with window capture inner window [Photo 1]
41yyLmX
and then I get this extra black edge and not even the whole window[Photo 2]
pH6ChTC
So maybe doing the subregion and cutting out the window would work?[Photo 3]
QnY4aGJ
Ha, not at all. I ended up with this.[Photo 4]
pLdgR45
I can cut it out and position it to where I need it but it messes up my fitting for my stream.
My monitor is 1920x1080 and so is my stream output. I tried to use the "set resolution" button in window cap to see if it could fix something but still nothing, I'd really like some help on this as i Believe my monitor capture isn't working either.
[[UPDATE]]
So I switched to OBS Studio and have gotten my Hauppauge to be captured through Video Capture Device, which is nice because I don't have to run the program to pull up the window and window capture it, but yet, I've reached another problem. not really a bug but original was and still need a fix for that. My other problem is that TeeBoard does not work with the BrowserPlugin for OBS Studio and was wondering if theres a way to use CLR on OBS Studio? or TeeBoard through normal "Browser Source"? And one more thing, if there is no way to use TeeBoard on OBS Studio, would TwitchAlerts be a good option to switch to?
