Question / Help Window Capture of PvP.net Client is a white box
Koraq
Sorry that I have to bother you all with this, but I've searched for hours to find the answer to this question with no success.
My in game stream works fine, and I had the stream of my out of game pvp.net client working as well -- but recently it's turned into a white box.
I have Aero enabled and the pvp.net client is in a different scene than the in-game client; I use the simple scene switcher to toggle between the two.
EDIT: Attached a recent log file.
  • 2013-09-10-1039-49.log
Koraq
And now it's working without having changed any settings...
wat
Oh well. I'll take it.
EDIT:
Nevermind. After playing a match and moving back into client as game ended, the box turned white again.
Lain
Lain
Hmm, tis seems like it could be a computer issue of some sort, though I'm betting it can be fixed. Could you try using "compatibility mode" for the window capture that captures the lobby and seeing if that fixes it? Turning off aero might also fix it, though not sure.
