Question / Help Window Capture LiveSplit is put into corner of black box
Gixty
I'm not sure if this is a problem with LiveSplit or OBS but when I window capture the LiveSplit window it places the window into a black box that acts as the entire window. When I resize LiveSplit then the entire black box is resized. I can't resize the LiveSplit capture inside the box either. I'm not sure if it's a setting or not because all I've done is selected LiveSplit for capture.
Whew that's quite enough of the word LiveSplit eh? Anyways here's the image:
The Log is: https://obsproject.com/logs/wX-eTCMaYGHygbHm
OBS 25.0.8 (64-bit, windows) log file uploaded at 2020-05-25, 17:53:33
17:41:31.023: CoInitializeEx succeeded: 0x00000001
17:41:31.023: CPU Name: Intel(R) Core(TM) i5-8265U CPU @ 1.60GHz
17:41:31.023: CPU Speed: 1800MHz
17:41:31.023: Physical Cores: 4, Logical Cores: 8
17:41:31.023: Physical Memory: 16254MB Total, 11655MB Free
17:41:31.023: Windows Version: 10.0 Build 17763 (release: 1809; revision: 1039; 64-bit)
17:41:31.023: Running as administrator: false
17:41:31.023: Aero is Enabled (Aero is always on for windows 8 and above)
17:41:31.024: Windows 10 Gaming Features:
17:41:31.024: Game Bar: On
17:41:31.024: Game DVR: On
17:41:31.024: Game DVR Background Recording: On
17:41:31.033: Sec. Software Status:
17:41:31.037: Windows Defender Antivirus: enabled (AV)
17:41:31.037: Windows Firewall: enabled (FW)
17:41:31.038: Windows Defender Antivirus: enabled (ASW)
17:41:31.038: Current Date/Time: 2020-05-25, 17:41:31
17:41:31.038: Browser Hardware Acceleration: true
17:41:31.038: Portable mode: false
17:41:33.391: OBS 25.0.8 (64-bit, windows)
17:41:33.391: ---------------------------------
17:41:33.417: ---------------------------------
17:41:33.417: audio settings reset:
17:41:33.417: samples per sec: 44100
17:41:33.417: speakers: 2
17:41:33.460: ---------------------------------
17:41:33.460: Initializing D3D11...
17:41:33.460: Available Video Adapters:
17:41:33.467: Adapter 0: NVIDIA GeForce MX250
17:41:33.467: Dedicated VRAM: 2080038912
17:41:33.467: Shared VRAM: 4227252224
17:41:33.467: PCI ID: 10de:1d13
17:41:33.467: Driver Version: 25.21.14.1788
17:41:33.468: output 0: pos={0, 0}, size={1920, 1080}, attached=true, refresh=60, name=
17:41:33.468: Adapter 1: Intel(R) UHD Graphics 620
17:41:33.468: Dedicated VRAM: 134217728
17:41:33.468: Shared VRAM: 4227252224
17:41:33.468: PCI ID: 8086:3ea0
17:41:33.469: Driver Version: 25.20.100.6519
17:41:33.476: Loading up D3D11 on adapter NVIDIA GeForce MX250 (0)
17:41:33.580: D3D11 loaded successfully, feature level used: b000
17:41:33.580: DXGI increase maximum frame latency success
17:41:33.581: D3D11 GPU priority setup failed (not admin?)
17:41:34.876: ---------------------------------
17:41:34.876: video settings reset:
17:41:34.876: base resolution: 1920x1080
17:41:34.876: output resolution: 1280x720
17:41:34.876: downscale filter: Bicubic
17:41:34.876: fps: 30/1
17:41:34.876: format: NV12
17:41:34.876: YUV mode: 601/Partial
17:41:34.877: NV12 texture support enabled
17:41:34.885: Audio monitoring device:
17:41:34.885: name: Default
17:41:34.885: id: default
17:41:34.886: ---------------------------------
17:41:35.021: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
17:41:35.082: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
17:41:35.229: [AMF] Unable to load 'amfrt64.dll', error code 126.
17:41:35.232: [AMF] AMF Test failed due to one or more errors.
17:41:35.232: Failed to initialize module 'enc-amf.dll'
17:41:35.829: [obs-browser]: Version 2.8.6
17:41:36.687: VLC found, VLC video source enabled
17:41:37.287: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
17:41:37.289: No blackmagic support
17:41:37.596: ---------------------------------
17:41:37.596: Loaded Modules:
17:41:37.596: win-wasapi.dll
17:41:37.596: win-mf.dll
17:41:37.596: win-dshow.dll
17:41:37.596: win-decklink.dll
17:41:37.596: win-capture.dll
17:41:37.596: vlc-video.dll
17:41:37.596: text-freetype2.dll
17:41:37.596: rtmp-services.dll
17:41:37.596: obs-x264.dll
17:41:37.596: obs-vst.dll
17:41:37.596: obs-transitions.dll
17:41:37.596: obs-text.dll
17:41:37.596: obs-qsv11.dll
17:41:37.596: obs-outputs.dll
17:41:37.596: obs-filters.dll
17:41:37.596: obs-ffmpeg.dll
17:41:37.596: obs-browser.dll
17:41:37.596: image-source.dll
17:41:37.596: frontend-tools.dll
17:41:37.596: enc-amf.dll
17:41:37.596: decklink-ouput-ui.dll
17:41:37.596: coreaudio-encoder.dll
17:41:37.597: ==== Startup complete ===============================================
17:41:37.600: Service '' not found
17:41:37.708: All scene data cleared
17:41:37.708: ------------------------------------------------
17:41:37.974: WASAPI: Device 'Hörlurar (Realtek(R) Audio)' [48000 Hz] initialized
17:41:37.998: [Loaded global audio device]: 'Desktop Audio'
17:41:38.347: WASAPI: Device 'Extern mikrofon (Realtek(R) Audio)' [48000 Hz] initialized
17:41:38.347: [Loaded global audio device]: 'Mic/Aux'
17:41:38.398: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Mic/Aux)
17:41:38.398:
17:41:38.411: [window-capture: 'Live Split'] update settings:
17:41:38.411: executable: LiveSplit.exe
17:41:38.412: [window-capture: 'Stream'] update settings:
17:41:38.412: executable: chrome.exe
17:41:38.414: Switched to scene 'WW2 Speedrunning'
17:41:38.415: ------------------------------------------------
17:41:38.415: Loaded scenes:
17:41:38.415: - scene 'WW2 Speedrunning':
17:41:38.415: - source: 'Stream' (window_capture)
17:41:38.415: - source: 'Live Split' (window_capture)
Thank YOU!
Gixty
I solved the problem but I have no idea how to delete this post!
There's an edit and delete here but nowhere else
Fenrir
There is no need to delete the post. This is actually a common issue with livesplit, I would recommend just posting your solution so that others may find it in the future.
