Question / Help window capture laggy
angelitolunatico1
  • 2017-04-17 17-40-36.txt
Narcogen
Yes. Use display capture. Window capture in MacOS is laggy because of how MacOS does windows.
Have you tried Syphon? Doesn't work on everything, but when it does, it's faster than window capture.
Narcogen
It is included in OBS. Add a syphon source from the drop down, and choose Launch SyphonInject, then choose the app you want to inject, and choose that app from the properties of the source.
Requires an OpenGL app to work, and doesn't support everything, but when it works, it works as well as display capture performance-wise, but only captures a window.
