Hi so im using window capture to record csgo in borderless windowed mode. i set my window capture to capture cs go, but it picks up my desktop instead of just csgo. any help? should i just be using game capture instead?
This is a common confusion; if aero is off, window capture can capture windows that are on top. So aero must be enabled with window capture (and also makes window capture specifically more efficient). If aero is not disabled in video settings, then you must set your windows theme in your windows settings to the aero theme to enable actual aero mode.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
