Bug Report Window Capture bugs when using 2nd monitor
Arisa
Not sure if this is a compatibility problem with Windows 8, because previously (formatted the computer, was windows 7 before) everything worked fine.
The problem:
I want to capture my spotify (or any other window) and it will oddly mix with the OBS window. The problem is only fixed if I stop using the 2nd monitor; then, the window capture works just fine.
In the example below, the spotify window should be filling the entire screen in the preview. but instead, is oddly mixing with other elements:
I really need to use the 2nd monitor tho. And it worked before installed windows 8. Any leads?
Thank you
