So, I've tinkered with a lot of the settings to see if I can solve this problem but so far after about a hour or so of tinkering nothing fixes my problem. What I noticed is something is wrong with my sound when something either loads Sc2 for example loads and my sound stutters. So I tried things to make it less stressful on my CPU to see if that would solve it but nothing. So I don't know what the problem is I saw the thread on sound problems but I can hear sound it sounds good but just random stutters is my only problem. I really want to use this program so please halp.
Comp specs.
I7 930 Bloomfield overclocked 3.5ghz
6gb triple channel ram
470 GTX Geforce
according to speed test 1.9 upload (I use 1100 for stream)
Thanks in advance if you need any more information or idea's on how to fix let me know.
Comp specs.
470 GTX Geforce
Open Broadcaster Software v0.467a (test 2) - 64bit ( ^ω^)
CPU Name: Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz
CPU Speed: 3330MHz
Physical Memory: 6135MB Total, 2570MB Free
stepping id: 5, model 10, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
Aero is Disabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 470
Video Adapter Dedicated Video Memory: 1293352960
Video Adapter Shared System Memory: 2948165632
Base resolution: 1920x1080
Output resolution: 1920x1080
Loading up D3D10...
Using 7.1 surround speaker setup (experimental)
Using auxilary audio input: Microphone (Realtek High Definition Audio)
Audio Encoding: AAC
bitrate: 48
Using Monitor Capture
Using bitmap image
device: Logitech HD Webcam C615,
device id \\?\usb#vid_046d&pid_082c&mi_02#6&9adc8fd&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
chosen type: RGB24, usingFourCC: false, res: 1920x1080 - 1920x1080, fps: 5-30, fourCC: 00000000
Using directshow input
Video Encoding: x264
fps: 30
width: 1920, height: 1080
preset: veryfast
CBR: yes
max bitrate: 1100
curTime: 22428475, timeOffset: 5
Total frames rendered: 500, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Base resolution: 1280x720
Output resolution: 1280x720
Loading up D3D10...
Audio Encoding: AAC
bitrate: 48
Using bitmap image
chosen type: RGB24, usingFourCC: false, res: 1280x720 - 1280x720, fps: 5-30, fourCC: 00000000
fps: 30
width: 1280, height: 720
preset: veryfast
CBR: yes
max bitrate: 1100
curTime: 22471035, timeOffset: 6
Total frames rendered: 2820, number of frames that lagged: 3 (0.11%) (it's okay for some frames to lag)
Profiler results:
frame - [100%] [avg time: 15.626 ms] [avg calls per frame: 1] [children: 97%] [unaccounted: 3.03%]
| scene->Preprocess - [46.4%] [avg time: 7.249 ms] [avg calls per frame: 1]
| video encoding and uploading - [50.6%] [avg time: 7.904 ms] [avg calls per frame: 1] [children: 8.81%] [unaccounted: 41.8%]
| | CopyResource - [0.0704%] [avg time: 0.011 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.179%] [avg time: 0.028 ms] [avg calls per frame: 0]
| | call to encoder - [8.56%] [avg time: 1.337 ms] [avg calls per frame: 0]
| | sending stuff out - [0.0064%] [avg time: 0.001 ms] [avg calls per frame: 0]
