So, First of all. I am using an older version because the newest one caused problems for me. One that I know worked. but just recently. When I run OBS and start streaming. anything that's open will refuse to close, but I can still (sort of) use them.. It won't let Task manager come open. And if it does, ending OBS doesn't do anything, The problem continues. (I'm assuming it's OBS because It only happens when I run OBS.) It is so bad that I have to force my computer to restart by using the power button on the tower. It has done this to me about 4-5 times lately until I realized OBS is what I was doing differently. Here's the log file.
I really hope someone knows what's going on.
Open Broadcaster Software v0.472b - 32bit (´・ω・`)
CPU Name: AMD FX(tm)-6200 Six-Core Processor
CPU Speed: 3825MHz
Physical Memory: 4095MB Total, 3913MB Free
stepping id: 2, model 1, family 15, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 6, total cores 3
monitor 2: pos={-1280, 56}, size={1280, 1024}
Aero is Disabled
Adapter 1
Video Adapter: ATI Radeon HD 5670
Video Adapter Dedicated Video Memory: 1059729408
Video Adapter Shared System Memory: 4016697344
Base resolution: 1920x1080
Output resolution: 1280x720
Loading up D3D10...
Playback device {0.0.0.00000000}.{527c4ea2-d7bb-4406-ae25-a1b3884c16f0}
Using desktop audio input: Speakers (Realtek High Definition Audio)
Using auxilary audio input: Microphone (Realtek High Definition Audio)
Audio Encoding: AAC
bitrate: 128
Using Window Capture
Using graphics capture
Using Monitor Capture
Using text output
device: Microsoft LifeCam Cinema,
device id \\?\usb#vid_045e&pid_075d&mi_00#6&bc683c4&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, fps: 15-15, fourCC: 'YUY2'
Using directshow input
Using text output
x264: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 AVX XOP FMA4 SSEMisalign LZCNT
x264: profile High, level 3.1
Video Encoding: x264
fps: 30
width: 1280, height: 720
preset: faster
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Server selection: rtmp://live-3c.justin.tv/app
bufferTime: 1742, outputRateWindowTime: 1000, dropThreshold: 2242
Total frames rendered: 7731, number of frames that lagged: 288 (3.73%) (it's okay for some frames to lag)
