18:47:10: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
18:47:10: -------------------------------
18:47:10: CPU Name: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
18:47:10: CPU Speed: 3000MHz
18:47:10: Physical Memory: 3071MB Total, 1665MB Free
18:47:10: stepping id: 6, model 7, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 2, total cores 2
18:47:10: monitor 1: pos={0, 0}, size={1280, 1024}
18:47:10: Windows Version: 6.1 Build 7600
18:47:10: Aero is Disabled
18:47:10: OBS Modules:
18:47:10: Base Address Module
18:47:10: 001A0000 OBS.exe
18:47:10: 61FB0000 OBSApi.dll
18:47:10: 72F70000 DShowPlugin.dll
18:47:10: 74490000 GraphicsCapture.dll
18:47:10: 732F0000 NoiseGate.dll
18:47:10: 73030000 WebSocketAPIPlugin.dll
18:47:10: ------------------------------------------
18:47:10: Adapter 1
18:47:10: Video Adapter: NVIDIA GeForce 9500 GT
18:47:10: Video Adapter Dedicated Video Memory: 1056505856
18:47:10: Video Adapter Shared System Memory: 1341714432
18:47:10: =====Stream Start: 2013-05-13, 18:47:10===============================================
18:47:10: Multithreaded optimizations: On
18:47:10: Base resolution: 1280x720
18:47:10: Output resolution: 852x480
18:47:11: Loading up D3D10...
18:47:11: Playback device Default
18:47:11: ------------------------------------------
18:47:11: Using desktop audio input: Głośniki (Realtek High Definition Audio)
18:47:11: Using auxilary audio input: Logitech (Urządzenie audio USB)
18:47:11: Audio Encoding: MP3
18:47:11: bitrate: 96
18:47:11: Using graphics capture
18:47:11: Using text output
18:47:11: Video Encoding: x264
18:47:11: fps: 30
18:47:11: width: 852, height: 480
18:47:11: preset: veryfast
18:47:11: CBR: no
18:47:11: CFR: yes
18:47:11: max bitrate: 1400
18:47:11: buffer size: 2000
18:47:11: quality: 7
18:47:15: Using text output
18:48:04: SharedTexCapture hooked
18:49:34: GraphicsCaptureSource::NewCapture: eliminating old capture
18:49:34: SharedTexCapture hooked
18:50:12: Capture window 0x00CE045C invalid or changing, terminating capture
18:50:13: Total frames rendered: 3794, number of frames that lagged: 956 (25.20%) (it's okay for some frames to lag)
18:50:13: Total duplicated frames: 1677 (44.20%)
18:50:13: =====Stream End: 2013-05-13, 18:50:13=================================================
18:50:14:
18:50:14: Profiler results:
18:50:14:
18:50:14: ==============================================================
18:50:14: frame - [100%] [avg time: 27.086 ms] [avg calls per frame: 1] [children: 97.1%] [unaccounted: 2.89%]
18:50:14: | scene->Preprocess - [0.144%] [avg time: 0.039 ms] [avg calls per frame: 1]
18:50:14: | video encoding and uploading - [97%] [avg time: 26.264 ms] [avg calls per frame: 1] [children: 96.9%] [unaccounted: 0.0628%]
18:50:14: | | CopyResource - [84.8%] [avg time: 22.98 ms] [avg calls per frame: 0]
18:50:14: | | conversion to 4:2:0 - [0.251%] [avg time: 0.068 ms] [avg calls per frame: 0]
18:50:14: | | call to encoder - [11.8%] [avg time: 3.197 ms] [avg calls per frame: 1]
18:50:14: | | sending stuff out - [0.00738%] [avg time: 0.002 ms] [avg calls per frame: 1]
18:50:14:
