Bug Report Weird echo (cam is responsible)
XyukuloviczX
Hello everyone !
I already posted a thread about an echo issue (echo after 1h stream) and I'm here again cause I didn't manage to completely solve this problem.
YES, I already set my webcam and disabled the cam's mic.
Here's the new issue :
After 10 minutes of stream, my viewers say to me that there's an echo on my stream.
- If I reboot my stream, the problem is solved but reappears 10min later.
- If I disable my webcam for the first time of the stream's session, the problem is solved but reappears ten minutes later
- If I disable my webcam another time in the same session, the echo don't disappear and the only solution I found is to reboot the stream.
- When the echo appears, if I disable my headphone's mic, viewers can't hear me.
Please Help Me, I'm like "What the...?"
Here's a log : https://gist.github.com/61047ae74cf85d63ded9
Thank you very much for your help
