Bug Report Weird 654.36 fps with Avermedia LGPLite Stream Engine
Mar00n
Hi,
I use Avermedia LGPLite Stream Engine and it intermittently renders the famous black screen instead of the video fed through its HDMI input.
IT SEEMS that tweaking Avermedia's configuration (via its own software) does the trick and makes the capture work again (I say "seems" now because I don't have the card here right now and can't run a test to be sure about it).
One interesting thing I've found reading the logs, looks like the frame per seconds were configured to weird 654.36 every times the capture went black screen (again, I'm unable to test it right now):
16:39:25.374: [DShow Device: 'CAM-Principal'] settings updated:
16:39:25.374: video device: LGPLite Stream Engine
16:39:25.374: video path:
16:39:25.374: resolution: 720x480
16:39:25.374: fps: 654.36 (interval: 15282)
16:39:25.374: format: YUY2
16:39:25.375: using video device audio: yes
16:39:25.375: sample rate: 44100
16:39:25.375: channels: 2
16:39:25.375: audio type: Capture
Do you guys know from where I could start to find out what is the issue?
I'm sending the whole log file.
Regards.
  • avermedia_fps_log.txt
Mar00n
Guys, I made a mistake posting this here, it was intended to OBS Studio forum. Please ignore this and help me on the OBS Studio post if you could.
