im not sure if its a bug, or if its something that is wrong with the logitech software.
I dont have the same problem with xsplit, so maybe someone here knows that problem?
I have 2 scenes, on both my webcam is on with custom resolution 640x480.
Everytime i switch a scene the cam goes "off" for some reason even if the second scene also has the webcam on with same settings. It works fine but sometimes when i switch to scene 2 it wont turn on again.
After i switch back to the first scene again then it will turn on and then it also works on scene 2 again to sometimes.
Seems a bit random, i already tryed to slow down the switching between scenes but does not seem to affect the problem.
Any ideas?
thanks for reading!
Any ideas?
thanks for reading!
