Bug Report Web Page wont record properly
Marge
On OBS (64 bit and 32 bit) If I choose for it to record a web page on IE, it will show the top bar (tabs, search and back/forward page) and the bookmarks, but the rest of the page is white.
* I don't know where a log file is.
I will update this in a minute with the log file
Marge
https://gist.github.com/7e7ce3183a5964574fed
Multiple video cards detected
If you are having problems and are using a laptop, seethis threadfor advice.
If you are using SLI or Crossfire, you may need to disable it for compatibility with OBS.
Bad resolution / FPS / bitrate combination
The combination of settings you are using will likely lead to a low quality stream with artifacting and other problems. Consider either raising your bitrate or lowering your resolution / FPS (qval: 0.01)
2 issues found (1 major, 1 minor).
all that the most recent analuzed log file said. The original computer that I used did not have this. But it was much older than this one, but bother were/are connected to a monitor.
Marge
Old OBS Version
You are using an old version of OBS. Please update to the latest version to ensure you receive bug fixes and improvements. Use Help / Check For Updates or visit theOBS download pageto get the latest release.
Wireless detected
You appear to be streaming over a wireless connection. While this can be OK, keep in mind that interference from other radio sources or obstacles can cause your connection to momentarily stall, resulting in dropped frames or disconnects. A wired connection is strongly recommended for a reliable stream.
Dropped frames detected
15% of your frames were dropped due to poor network conditions. Frames are dropped when data can not be sent fast enough to the server you have selected. This is caused by trying to stream at too high of a bitrate, or by the streaming server you selected not being able to accept the data at the rate you are sending.
Try switching servers, especially if you are using twitch.tv. As a test, you could also try streaming to a different provider to check whether the problem is on your end or not.
Note that some ISPs will temporarily increase your upload speed at the start of a transfer - if you only start to drop frames after 30 - 60 seconds, your ISP is likely doing this and you will need to use a lower bitrate.
Finally, if you are using a wireless connection, keep in mind that interference from other radio sources can cause your connection to stutter and drop frames. A wired connection is strongly recommended when streaming.
Seehttps://obsproject.com/forum/viewtopic.php?f=5&t=8870for more advice on how to fix dropped frames.
Connection stalls detected
Your connection is stalling while sending data. This can result in frame drops, stream freezes and disconnects. Try changing the server you are streaming to, or lowering your bitrate
6 issues found (4 major, 2 minor).
this is from the last time I recorded a web page. though it was only for audio
https://gist.github.com/anonymous/909afd7f095c4d1ede68
