Question / Help VOD Lag problems on Twitch
Mister_Clox
Hello, I am new to streaming, and have been experimenting with different settings with different programs, tweaking high and low, but I always seem to be running into the same problem every time I record anything. Here is an example of how my streaming attempts go:
I set up OBS, no problems at all, follow the instructions on the website, and bam, I'm streaming. I open up Far Cry 2, and (take note) NO LAG on my screen. Absolutely none. So I play through the game a bit, just to demonstrate to myself how my computer can stream on Twitch.tv. I stop recording, and check the VOD which was just made as a result. To my surprise and frustration, it goes something like this - http://www.twitch.tv/mister_clox/b/428568065
If you haven't looked at the link or it's dead, what basically happens is the video starts to lag at ~1-2 fps, skipping parts of what I'm doing, meanwhile the audio is just fine. I want to stress once again that I, myself, experienced ZERO lag while streaming this video. I've tried everything: the estimator, countless FAQ solutions on the Twitch.tv website, tweaking every setting high and low, you name it. My download speed according to speedtest.net is 12.42mbps, whilst my upload speed is 1.79mbps.
If you need any more details, please let me know. Very frustrated as I'm following what looks like every rule in the book, and still getting the same result.
Mister_Clox
12:23:36: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
12:23:36: -------------------------------
12:23:36: CPU Name: AMD Phenom(tm) II X4 925 Processor
12:23:36: CPU Speed: 2798MHz
12:23:36: Physical Memory: 4095MB Total, 4095MB Free
12:23:36: stepping id: 2, model 4, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
12:23:36: monitor 1: pos={0, 0}, size={1920, 1080}
12:23:36: Windows Version: 6.0 Build 6002 S
12:23:36: Aero is Enabled
12:23:36: OBS Modules:
12:23:36: Base Address Module
12:23:36: 003C0000 OBS.exe
12:23:36: 634E0000 OBSApi.dll
12:23:36: 6F160000 DShowPlugin.dll
12:23:36: 6F1D0000 GraphicsCapture.dll
12:23:36: 6D5F0000 NoiseGate.dll
12:23:36: ------------------------------------------
12:23:36: Adapter 1
12:23:36: Video Adapter: ATI Radeon HD 4600 Series
12:23:36: Video Adapter Dedicated Video Memory: 1062473728
12:23:36: Video Adapter Shared System Memory: 3891884032
12:23:36: =====Stream Start: 2013-07-10, 12:23:36===============================================
12:23:36: Multithreaded optimizations: On
12:23:36: Base resolution: 1920x1080
12:23:36: Output resolution: 1920x1080
12:23:36: Loading up D3D10...
12:23:36: Playback device Default
12:23:36: Using desktop audio input: Speakers (Realtek High Definition Audio)
12:23:36: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
12:23:36: Audio Encoding: MP3
12:23:36: bitrate: 128
12:23:36: Video Encoding: x264
12:23:36: fps: 30
12:23:36: width: 1920, height: 1080
12:23:36: preset: veryfast
12:23:36: CBR: yes
12:23:36: CFR: no
12:23:36: max bitrate: 1000
12:23:42: Connection to (null) failed: No server specified to connect to
12:23:42: Total frames rendered: 49, number of frames that lagged: 1 (2.04%) (it's okay for some frames to lag)
12:23:42: Number of times waited to send: 0, Waited for a total of 0 bytes
12:23:42: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
12:23:42: =====Stream End: 2013-07-10, 12:23:42=================================================
12:37:57: =====Stream Start: 2013-07-10, 12:37:57===============================================
12:37:57: Multithreaded optimizations: On
12:37:57: Base resolution: 1920x1080
12:37:57: Output resolution: 1280x720
12:37:57: ------------------------------------------
12:37:57: Loading up D3D10...
12:37:57: Playback device {0.0.0.00000000}.{e198e7e1-aa75-4713-8286-bdbbdee96dbc}
12:37:57: Using desktop audio input: Speakers (Realtek High Definition Audio)
12:37:57: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
12:37:57: Audio Encoding: MP3
12:37:57: bitrate: 128
12:37:57: Video Encoding: x264
12:37:57: fps: 30
12:37:57: width: 1280, height: 720
12:37:57: preset: veryfast
12:37:57: CBR: yes
12:37:57: CFR: no
12:37:57: max bitrate: 1000
12:38:20: Total frames rendered: 696, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
12:38:20: =====Stream End: 2013-07-10, 12:38:20=================================================
12:49:03: =====Stream Start: 2013-07-10, 12:49:03===============================================
12:49:03: Multithreaded optimizations: On
12:49:03: Base resolution: 1920x1080
12:49:03: Output resolution: 1280x720
12:49:03: ------------------------------------------
12:49:03: Loading up D3D10...
12:49:03: Playback device {0.0.0.00000000}.{e198e7e1-aa75-4713-8286-bdbbdee96dbc}
12:49:03: Using desktop audio input: Speakers (Realtek High Definition Audio)
12:49:03: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
12:49:03: Audio Encoding: MP3
12:49:03: bitrate: 128
12:49:03: Video Encoding: x264
12:49:03: fps: 30
12:49:03: width: 1280, height: 720
12:49:03: preset: veryfast
12:49:03: CBR: yes
12:49:03: CFR: no
12:49:03: max bitrate: 1000
12:49:04: Using RTMP service: Twitch / Justin.tv
12:49:04: Server selection: rtmp://live-dfw.justin.tv/app
12:49:06: SO_SNDBUF was at 8192
12:49:06: SO_SNDBUF is now 65536
12:50:24: Total frames rendered: 2432, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
12:50:24: RTMPPublisher::SocketLoop: Aborting due to loop exit
12:50:24: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
12:50:24: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
12:50:24: Number of times waited to send: 34, Waited for a total of 132106 bytes
12:50:24: Number of b-frames dropped: 692 (30%), Number of p-frames dropped: 671 (29%), Total 1363 (60%)
12:50:24: =====Stream End: 2013-07-10, 12:50:24=================================================
12:50:53: =====Stream Start: 2013-07-10, 12:50:53===============================================
12:50:53: Multithreaded optimizations: On
12:50:53: Base resolution: 1920x1080
12:50:53: Output resolution: 1280x720
12:50:53: ------------------------------------------
12:50:53: Loading up D3D10...
12:50:53: Playback device {0.0.0.00000000}.{e198e7e1-aa75-4713-8286-bdbbdee96dbc}
12:50:53: Using desktop audio input: Speakers (Realtek High Definition Audio)
12:50:53: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
12:50:53: Audio Encoding: MP3
12:50:53: bitrate: 128
12:50:53: Using Monitor Capture
12:50:53: Video Encoding: x264
12:50:53: fps: 30
12:50:53: width: 1280, height: 720
12:50:53: preset: veryfast
12:50:53: CBR: yes
12:50:53: CFR: no
12:50:53: max bitrate: 1000
12:50:55: Using RTMP service: Twitch / Justin.tv
12:50:55: Server selection: rtmp://live-dfw.justin.tv/app
12:50:57: SO_SNDBUF was at 8192
12:50:57: SO_SNDBUF is now 65536
12:53:07: Total frames rendered: 3223, number of frames that lagged: 1664 (51.63%) (it's okay for some frames to lag)
12:53:07: RTMPPublisher::SocketLoop: Aborting due to loop exit
12:53:07: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
12:53:07: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
12:53:07: Number of times waited to send: 56, Waited for a total of 158587 bytes
12:53:07: Number of b-frames dropped: 984 (32%), Number of p-frames dropped: 1247 (40%), Total 2231 (72%)
12:53:07: =====Stream End: 2013-07-10, 12:53:07=================================================
12:59:11: =====Stream Start: 2013-07-10, 12:59:11===============================================
12:59:11: Multithreaded optimizations: On
12:59:11: Base resolution: 1920x1080
12:59:11: Output resolution: 852x480
12:59:11: ------------------------------------------
12:59:11: Loading up D3D10...
12:59:11: Playback device {0.0.0.00000000}.{e198e7e1-aa75-4713-8286-bdbbdee96dbc}
12:59:11: Using desktop audio input: Speakers (Realtek High Definition Audio)
12:59:11: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
12:59:11: Audio Encoding: MP3
12:59:11: bitrate: 128
12:59:11: Using graphics capture
12:59:12: ------------------------------------------
12:59:12: Video Encoding: x264
12:59:12: fps: 25
12:59:12: width: 852, height: 480
12:59:12: preset: veryfast
12:59:12: CBR: yes
12:59:12: CFR: no
12:59:12: max bitrate: 1000
12:59:13: Using RTMP service: Twitch / Justin.tv
12:59:13: Server selection: rtmp://live-dfw.justin.tv/app
12:59:15: SO_SNDBUF was at 8192
12:59:15: SO_SNDBUF is now 65536
13:00:36: Total frames rendered: 2112, number of frames that lagged: 2 (0.09%) (it's okay for some frames to lag)
13:00:36: okay, this is strange
13:00:36: RTMPPublisher::SocketLoop: Aborting due to loop exit
13:00:36: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
13:00:36: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
13:00:36: Number of times waited to send: 35, Waited for a total of 127443 bytes
13:00:36: Number of b-frames dropped: 614 (31%), Number of p-frames dropped: 578 (29%), Total 1192 (60%)
13:00:36: =====Stream End: 2013-07-10, 13:00:36=================================================
13:02:10: =====Stream Start: 2013-07-10, 13:02:10===============================================
13:02:10: Multithreaded optimizations: On
13:02:10: Base resolution: 1920x1080
13:02:10: Output resolution: 852x480
13:02:10: ------------------------------------------
13:02:10: Loading up D3D10...
13:02:10: Playback device {0.0.0.00000000}.{e198e7e1-aa75-4713-8286-bdbbdee96dbc}
13:02:10: Using desktop audio input: Speakers (Realtek High Definition Audio)
13:02:10: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
13:02:10: Audio Encoding: MP3
13:02:10: bitrate: 128
13:02:10: Using graphics capture
13:02:10: Using Monitor Capture
13:02:10: Video Encoding: x264
13:02:10: fps: 25
13:02:10: width: 852, height: 480
13:02:10: preset: veryfast
13:02:10: CBR: yes
13:02:10: CFR: no
13:02:10: max bitrate: 1000
13:02:12: Using RTMP service: Twitch / Justin.tv
13:02:12: Server selection: rtmp://live-dfw.justin.tv/app
13:02:14: SO_SNDBUF was at 8192
13:02:14: SO_SNDBUF is now 65536
13:04:05: Total frames rendered: 2699, number of frames that lagged: 122 (4.52%) (it's okay for some frames to lag)
13:04:05: RTMPPublisher::SocketLoop: Aborting due to loop exit
13:04:05: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
13:04:05: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
13:04:05: Number of times waited to send: 50, Waited for a total of 150368 bytes
13:04:05: Number of b-frames dropped: 631 (24%), Number of p-frames dropped: 1128 (44%), Total 1759 (68%)
13:04:06: =====Stream End: 2013-07-10, 13:04:06=================================================
13:07:28: =====Stream Start: 2013-07-10, 13:07:28===============================================
13:07:28: Multithreaded optimizations: On
13:07:28: Base resolution: 1920x1080
13:07:28: Output resolution: 852x480
13:07:28: ------------------------------------------
13:07:28: Loading up D3D10...
13:07:28: Playback device {0.0.0.00000000}.{e198e7e1-aa75-4713-8286-bdbbdee96dbc}
13:07:28: Using desktop audio input: Speakers (Realtek High Definition Audio)
13:07:28: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
13:07:28: Audio Encoding: MP3
13:07:28: bitrate: 128
13:07:28: Using graphics capture
13:07:28: Using Monitor Capture
13:07:28: Video Encoding: x264
13:07:28: fps: 25
13:07:28: width: 852, height: 480
13:07:28: preset: veryfast
13:07:28: CBR: yes
13:07:28: CFR: no
13:07:28: max bitrate: 1522
13:07:30: Using RTMP service: Twitch / Justin.tv
13:07:30: Server selection: rtmp://live-dfw.justin.tv/app
13:07:32: SO_SNDBUF was at 8192
13:07:32: SO_SNDBUF is now 65536
13:09:44: Total frames rendered: 3341, number of frames that lagged: 174 (5.21%) (it's okay for some frames to lag)
13:09:44: RTMPPublisher::SocketLoop: Aborting due to loop exit
13:09:44: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
13:09:44: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
13:09:44: Number of times waited to send: 44, Waited for a total of 155685 bytes
13:09:44: Number of b-frames dropped: 1029 (32%), Number of p-frames dropped: 1450 (45%), Total 2479 (77%)
13:09:45: =====Stream End: 2013-07-10, 13:09:45=================================================
13:22:41: =====Stream Start: 2013-07-10, 13:22:41===============================================
13:22:41: Multithreaded optimizations: On
13:22:41: Base resolution: 1920x1080
13:22:41: Output resolution: 852x480
13:22:41: ------------------------------------------
13:22:41: Loading up D3D10...
13:22:41: Playback device {0.0.0.00000000}.{e198e7e1-aa75-4713-8286-bdbbdee96dbc}
13:22:41: Using desktop audio input: Speakers (Realtek High Definition Audio)
13:22:41: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
13:22:41: Audio Encoding: MP3
13:22:41: bitrate: 128
13:22:41: Using graphics capture
13:22:41: Using Monitor Capture
13:22:41: Video Encoding: x264
13:22:41: fps: 30
13:22:41: width: 852, height: 480
13:22:41: preset: veryfast
13:22:41: CBR: yes
13:22:41: CFR: no
13:22:41: max bitrate: 1522
13:22:42: Using RTMP service: Twitch / Justin.tv
13:22:42: Server selection: rtmp://live-dfw.justin.tv/app
13:22:44: SO_SNDBUF was at 8192
13:22:44: SO_SNDBUF is now 65536
13:23:16: Total frames rendered: 1030, number of frames that lagged: 52 (5.05%) (it's okay for some frames to lag)
13:23:16: RTMPPublisher::SocketLoop: Aborting due to loop exit
13:23:16: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
13:23:16: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
13:23:16: Number of times waited to send: 9, Waited for a total of 22692 bytes
13:23:16: Number of b-frames dropped: 316 (34%), Number of p-frames dropped: 382 (41%), Total 698 (75%)
13:23:16: =====Stream End: 2013-07-10, 13:23:16=================================================
13:25:41: =====Stream Start: 2013-07-10, 13:25:41===============================================
13:25:41: Multithreaded optimizations: On
13:25:41: Base resolution: 1920x1080
13:25:41: Output resolution: 1280x720
13:25:41: ------------------------------------------
13:25:41: Loading up D3D10...
13:25:41: Playback device {0.0.0.00000000}.{e198e7e1-aa75-4713-8286-bdbbdee96dbc}
13:25:41: Using desktop audio input: Speakers (Realtek High Definition Audio)
13:25:41: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
13:25:41: Audio Encoding: MP3
13:25:41: bitrate: 128
13:25:41: Using graphics capture
13:25:41: Using Monitor Capture
13:25:41: Video Encoding: x264
13:25:41: fps: 30
13:25:41: width: 1280, height: 720
13:25:41: preset: veryfast
13:25:41: CBR: yes
13:25:41: CFR: no
13:25:41: max bitrate: 1522
13:25:43: Using RTMP service: Twitch / Justin.tv
13:25:43: Server selection: rtmp://live-dfw.justin.tv/app
13:25:45: SO_SNDBUF was at 8192
13:25:45: SO_SNDBUF is now 65536
13:26:10: Total frames rendered: 850, number of frames that lagged: 45 (5.29%) (it's okay for some frames to lag)
13:26:10: RTMPPublisher::SocketLoop: Aborting due to loop exit
13:26:10: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
13:26:10: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
13:26:10: Number of times waited to send: 9, Waited for a total of 30627 bytes
13:26:10: Number of b-frames dropped: 200 (28%), Number of p-frames dropped: 259 (36%), Total 459 (64%)
13:26:11: =====Stream End: 2013-07-10, 13:26:11=================================================
13:26:55: =====Stream Start: 2013-07-10, 13:26:55===============================================
13:26:55: Multithreaded optimizations: On
13:26:55: Base resolution: 1920x1080
13:26:55: Output resolution: 1280x720
13:26:55: ------------------------------------------
13:26:55: Loading up D3D10...
13:26:56: Playback device {0.0.0.00000000}.{e198e7e1-aa75-4713-8286-bdbbdee96dbc}
13:26:56: ------------------------------------------
13:26:56: Using desktop audio input: Speakers (Realtek High Definition Audio)
13:26:56: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
13:26:56: Audio Encoding: MP3
13:26:56: bitrate: 128
13:26:56: Using Monitor Capture
13:26:56: Video Encoding: x264
13:26:56: fps: 30
13:26:56: width: 1280, height: 720
13:26:56: preset: veryfast
13:26:56: CBR: yes
13:26:56: CFR: no
13:26:56: max bitrate: 1522
13:27:03: Total frames rendered: 142, number of frames that lagged: 142 (100.00%) (it's okay for some frames to lag)
13:27:03: =====Stream End: 2013-07-10, 13:27:03=================================================
13:29:08: =====Stream Start: 2013-07-10, 13:29:08===============================================
13:29:08: Multithreaded optimizations: On
13:29:08: Base resolution: 1920x1080
13:29:08: Output resolution: 1280x720
13:29:08: ------------------------------------------
13:29:09: Loading up D3D10...
13:29:09: Playback device {0.0.0.00000000}.{e198e7e1-aa75-4713-8286-bdbbdee96dbc}
13:29:09: ------------------------------------------
13:29:09: Using desktop audio input: Speakers (Realtek High Definition Audio)
13:29:09: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
13:29:09: Audio Encoding: MP3
13:29:09: bitrate: 128
13:29:09: Using graphics capture
13:29:09: Using Monitor Capture
13:29:09: Video Encoding: x264
13:29:09: fps: 30
13:29:09: width: 1280, height: 720
13:29:09: preset: veryfast
13:29:09: CBR: yes
13:29:09: CFR: no
13:29:09: max bitrate: 1522
13:29:10: Using RTMP service: Twitch / Justin.tv
13:29:10: Server selection: rtmp://live-dfw.justin.tv/app
13:29:12: SO_SNDBUF was at 8192
13:29:12: SO_SNDBUF is now 65536
13:29:41: Total frames rendered: 943, number of frames that lagged: 53 (5.62%) (it's okay for some frames to lag)
13:29:41: RTMPPublisher::SocketLoop: Aborting due to loop exit
13:29:41: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
13:29:41: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
13:29:41: Number of times waited to send: 9, Waited for a total of 31726 bytes
13:29:41: Number of b-frames dropped: 248 (30%), Number of p-frames dropped: 324 (39%), Total 572 (69%)
13:29:41: =====Stream End: 2013-07-10, 13:29:41=================================================
14:08:58: =====Stream Start: 2013-07-10, 14:08:58===============================================
14:08:58: Multithreaded optimizations: On
14:08:58: Base resolution: 1920x1080
14:08:58: Output resolution: 1920x1080
14:08:58: ------------------------------------------
14:08:58: Loading up D3D10...
14:08:58: Playback device {0.0.0.00000000}.{e198e7e1-aa75-4713-8286-bdbbdee96dbc}
14:08:58: Using desktop audio input: Speakers (Realtek High Definition Audio)
14:08:58: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
14:08:58: Audio Encoding: MP3
14:08:58: bitrate: 128
14:08:58: Using graphics capture
14:08:58: Using Monitor Capture
14:08:58: Video Encoding: x264
14:08:58: fps: 30
14:08:58: width: 1920, height: 1080
14:08:58: preset: veryfast
14:08:58: CBR: yes
14:08:58: CFR: yes
14:08:58: max bitrate: 1522
14:09:00: Using RTMP service: Twitch / Justin.tv
14:09:00: Server selection: rtmp://live-dfw.justin.tv/app
14:09:02: SO_SNDBUF was at 8192
14:09:02: SO_SNDBUF is now 65536
14:09:25: Total frames rendered: 766, number of frames that lagged: 124 (16.19%) (it's okay for some frames to lag)
14:09:25: Total duplicated frames: 42 (5.48%)
14:09:25: RTMPPublisher::SocketLoop: Aborting due to loop exit
14:09:25: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
14:09:25: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
14:09:25: Number of times waited to send: 8, Waited for a total of 24459 bytes
14:09:25: Number of b-frames dropped: 182 (28%), Number of p-frames dropped: 279 (42%), Total 461 (70%)
14:09:25: =====Stream End: 2013-07-10, 14:09:25=================================================
14:15:52:
14:15:52: Profiler results:
14:15:52:
14:15:52: ==============================================================
14:15:52: frame - [100%] [avg time: 19.41 ms] [avg calls per frame: 1] [children: 91.1%] [unaccounted: 8.93%]
14:15:52: | scene->Preprocess - [77.3%] [avg time: 14.999 ms] [avg calls per frame: 1]
14:15:52: | video encoding and uploading - [13.8%] [avg time: 2.677 ms] [avg calls per frame: 1] [children: 13.3%] [unaccounted: 0.474%]
14:15:52: | | CopyResource - [0.0773%] [avg time: 0.015 ms] [avg calls per frame: 0]
14:15:52: | | conversion to 4:2:0 - [0.124%] [avg time: 0.024 ms] [avg calls per frame: 0]
14:15:52: | | call to encoder - [13%] [avg time: 2.515 ms] [avg calls per frame: 0]
14:15:52: | | sending stuff out - [0.16%] [avg time: 0.031 ms] [avg calls per frame: 0]
14:15:52:
Sorry.
dodgepong
Administrator
Community Helper
You are dropping a ton of frames You need to lower your bit rate to something that fits within your upload speed.
Can you run ShaperProbe and post the results? http://www.cc.gatech.edu/~partha/diffpr ... probe.html
Are you streaming over wireless, by any chance?
Also you will need to downscale your OBS resolution to compensate for the lower bit rate, too, probably down to 480p.
Mister_Clox
Here are my ShaperProbe results:
"DiffProbe release. January 2012. Build 1008.
Shaper Detection Module.
Connected to server 217.163.1.100.
Estimating capacity:
Upstream: 2182 Kbps.
Downstream: 21006 Kbps.
The measurement will take upto 2.5 minutes. Please wait.
Checking for traffic shapers:
Upstream: Measurement aborted due to high packet loss rate.
Downstream: Burst size: 14702-15079 KB;
Shaping rate: 12581 Kbps.
For more information, visit: http://www.cc.gatech.edu/~partha/diffprobe"
Hope that helps. :)
I am not streaming wirelessly, I have my computer actually hardwired directly to my modem.
I will try out a lower resolution to see if that works. I think it's something I've tried before, but it can't hurt to try, will edit this post with results.
EDIT: This is what I got from changing the OBS Resolution to 480p: http://www.twitch.tv/mister_clox/b/428623255
dodgepong
Administrator
Community Helper
Hmm, that's not good. Can you run a speed test at http://testmy.net and post the results of that, too?
Also, changing the resolution isn't the important part, lowering the bit rate is. All I meant is that with a low bit rate, you'll need a lower resolution to still look OK.
Mister_Clox
Wow. This test that I ran at testmy.net really differed from the one I ran on speedtest.net.
11.1mbps download speed, with 427kbps upload speed.
Here's the result details in case you need them:
:::.. Internet Speed Test Result Details ..:::
Download Connection Speed:: 11143 Kbps or 11.1 Mbps
Download Speed Test Size:: 9.8 MB or 10048 kB or 10289152 bytes
Download Binary File Transfer Speed:: 1393 kB/s or 1.4 MB/s
Upload Connection Speed:: 427 Kbps or 0.4 Mbps
Upload Speed Test Size:: 480 kB or 491520 bytes
Upload Binary File Transfer Speed:: 53 kB/s
Timed:: Download: 7.387 seconds | Upload: 9.211 seconds
Tested At:: http://TestMy.net Version 13
Test Time:: 2013-07-10 18:18:20 Local Time
Location:: Saint Albert, AB CA >> Destination:: Dallas, TX US
Validation:: http://testmy.net/db/ONix3y5.nCzjrkY
TiP Measurement Summary (Download):: Min 6.96 Mbps | Middle Avg 11.48 Mbps | Max 17.48 Mbps | 50% Variance
TiP Data Points:: 11.61 Mbps, 14.62 Mbps, 10.49 Mbps, 8.34 Mbps, 8.59 Mbps, 9.42 Mbps, 10.27 Mbps, 12.13 Mbps, 14.06 Mbps, 15.99 Mbps, 17.48 Mbps, 13.35 Mbps, 12.27 Mbps, 9.13 Mbps, 11.61 Mbps, 7.63 Mbps, 9.06 Mbps, 10.72 Mbps, 6.96 Mbps
More Stats:: http://testmy.net/compID/1598972435
User Agent:: Mozilla/5.0 (Windows NT 6.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/27.0.1453.116 Safari/537.36 [!]
dodgepong
Administrator
Community Helper
Speedtest.net isn't reliable for measuring speed, since it opens multiple connections whereas streaming is a single-connection affair.
Try lowering your bit rate all the way to 400 and see what happens. It will look really bad, though. You might want to consider upgrading your internet.
R1CH
Packet loss generally indicates your connection is faulty, you should consider contacting your ISP.
FerretBomb
Yeah. ISPs get away with providing shoddy/bursty connections because most consumers just assume Speedtest will give them a good result. Great for testing dead-file transfers, but useless when it comes to constant throughput; testmy will give you a much more accurate idea of what you're actually getting.
Only recommendations would be to log into your modem (if your ISP gives you the credentials) and check the signal-to-noise ratio (SNR) as well as any dropped packets/errors. Also in the case of a cable modem, the channels locked/bonded and bandwidth used on each, and if any of them overlap (some ISPs are doing that too, to try and squeeze even more out of the copper they were subsidized to upgrade to fiber connections).
