Virtual chanel sound in OBS does not get adjusted when I move my fader
SenTh
Hey guys,
I have the rodecaster duo and I stream with OBS.
I also use the virtual driver from rode to split my audio mix to virtual channels. It allows me in obs to route each sound to a virtual channel created by the rode driver.
Each channel is controlled by my fader from my rodecaster duo.
-Mic
-Discord
-Music
-System(game + alert..)
The output speaker(What I am hearing) is perfect. When i move my fader, volume gets adjusted.
However, the sound that gets captured in OBS does not change.
It stays the same no matter what I do with my fader.
In this example, my music fader is muted, yet obs still picks up sound.
Chrome is indeed routed to music rodecaster virtual channel.
My mic is not affected. However, music and all other sources still having the same issue.
When I change/mute mic channel, the sound picked up by OBS seems to be correct.
In OBS, Mic is getting picked up as "Audio Input Capture" whereas the rest is "Audio Output Capture" May be that is the cause. Though, I do not see in OBS any of my virtual channel in Audio Input Capture in (Music, Game,...) except from my mic virtual channel.
What to do is it from rodecaster or OBS? Many thanks for your help
