I understand how it works, I've seen it work but it always crashes with me, no idea why D:
I have restarted facerig, restarted obs, reinstalled obs and restarted my PC all with no prevail.
Inb4 using something other then vidcap. I need vidcap because I need the chroma key option and if I were to use the window capture id need a third screen to keep the window up by its self with out anything overlaying it. (window capture captures/bugs out everything that I put over the window and wont work if i minimize the window)
Look forward to seeing what you guys have to say, have a nice day!
Bug report when it crashes:
This crash appears to have occured in the '<unknown>' module.
Fault address: 0D1B41F0 (<unknown>)
OBS version: Open Broadcaster Software v0.632b
CPU: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
Crashing thread stack trace:
0D99E9C8 0D1B41F0 0D1A8F48 00000001 00000000 0001901C <unknown>!0xd1b41f0
0D99E9CC 0841F567 0D1B41F0 0000000C 0D1A8F48 00000001 pvmjpg20.dll!0x841f567
0D99E9F0 0841E9D4 0845A000 08445280 08445280 0D99ECC8 pvmjpg20.dll!0x841e9d4
0D99EA44 761E2221 00000000 00000000 00000000 00000000 kernelbase.dll!0x761e2221
A minidump was saved to C:\Users\Rama\AppData\Roaming\OBS\crashDumps\OBSCrashDump2014-09-13_21.dmp.
List of loaded modules:
Base Address Module
Base Address Module
