eyehesitate
I'm not sure what exactly is causing it - system sounds are fine, but my microphone has a sporadic stutter every once in a while with the sound... it's almost like it just cuts off for a split second and sounds like a little, but annoying, pop. I can't find a sure-fire way to reproduce it yet. I am not using noise gate at this time. From what I've read, this patch has some improvements for the USB microphones... So, idk. I did not have issues (other than slight delay) with my USB snowball mic before the patch. BTW, microphone is functioning fine on other programs (skype, windows sound recorder).
15:12:42: Open Broadcaster Software v0.55b - 32bit (´・ω・`)
15:12:42: -------------------------------
15:12:42: CPU Name: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
15:12:42: CPU Speed: 3491MHz
15:12:42: Physical Memory: 4095MB Total, 4095MB Free
15:12:42: stepping id: 3, model 12, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
15:12:42: monitor 1: pos={0, 0}, size={1920, 1080}
15:12:42: Windows Version: 6.1 Build 7601 S
15:12:42: Aero is Disabled
15:12:42: OBS Modules:
15:12:42: Base Address Module
15:12:42: 01140000 OBS.exe
15:12:42: 5DEC0000 OBSApi.dll
15:12:42: 6FCA0000 DShowPlugin.dll
15:12:42: 73020000 GraphicsCapture.dll
15:12:42: 70370000 NoiseGate.dll
15:12:42: 6FC30000 PSVPlugin.dll
15:12:42: ------------------------------------------
15:12:42: Adapter 1
15:12:42: Video Adapter: NVIDIA GeForce GTX 550 Ti
15:12:42: Video Adapter Dedicated Video Memory: 1025179648
15:12:42: Video Adapter Shared System Memory: 3221106688
15:12:42: Adapter 2
15:12:42: Video Adapter: Intel(R) HD Graphics 4600
15:12:42: Video Adapter Dedicated Video Memory: 67108864
15:12:42: Video Adapter Shared System Memory: 1711276032
15:12:42: =====Stream Start: 2013-08-16, 15:12:42===============================================
15:12:42: Multithreaded optimizations: On
15:12:42: Base resolution: 1920x1080
15:12:42: Output resolution: 1280x720
15:12:42: Loading up D3D10 on NVIDIA GeForce GTX 550 Ti...
15:12:42: Playback device Default
15:12:42: Using desktop audio input: Speakers (2- Realtek High Definition Audio)
15:12:42: Using auxilary audio input: Microphone (Blue Snowball)
15:12:42: Audio Encoding: AAC
15:12:42: bitrate: 128
15:12:42: device: Logitech HD Webcam C270,
15:12:42: device id \\?\usb#vid_046d&pid_0825&mi_00#6&266c8843&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:12:42: chosen type: I420, usingFourCC: false, res: 1280x960 - 1280x960, frameIntervals: 333333-2000000, fourCC: 'I420'
15:12:42: audio device: Disable,
15:12:42: audio device id Disabled,
15:12:42:
15:12:42: Using directshow input
15:12:42: Using bitmap image
15:12:43: ------------------------------------------
15:12:43: Video Encoding: x264
15:12:43: fps: 60
15:12:43: width: 1280, height: 720
15:12:43: preset: faster
15:12:43: CBR: yes
15:12:43: CFR: no
15:12:43: max bitrate: 2800
15:12:43: MMDeviceAudioSource: Frequency for device 'Speakers (2- Realtek High Definition Audio)' is 384000, samples per sec is 48000
15:12:43: MMDeviceAudioSource: Frequency for device 'Microphone (Blue Snowball)' is 192000, samples per sec is 48000
15:12:44: Using RTMP service: Twitch / Justin.tv
15:12:44: Server selection: rtmp://live-iad-backup.justin.tv/app
15:12:44: Interface: Intel(R) Ethernet Connection I217-V (ethernet, 100 mbps)
15:12:46: SO_SNDBUF was at 8192
15:12:46: SO_SNDBUF is now 65536
15:12:47: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 35846 / 374784)
15:12:51: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:12:51: New Scene
15:12:51: ------------------------------------------
15:12:51: device: Logitech HD Webcam C270,
15:12:51: device id \\?\usb#vid_046d&pid_0825&mi_00#6&266c8843&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:12:51: chosen type: I420, usingFourCC: false, res: 1280x960 - 1280x960, frameIntervals: 333333-2000000, fourCC: 'I420'
15:12:51: audio device: Disable,
15:12:51: audio device id Disabled,
15:12:51:
15:12:51: Using directshow input
15:12:51: Using graphics capture
15:12:52: PERFORMANCE WARNING: Scene change took 1009 ms, maybe some sources should be global sources?
15:12:52: SharedTexCapture hooked
15:12:52: RTMPPublisher::Socketloop: Increasing send buffer to ISB 262144 (buffer: 0 / 374784)
15:12:53: RTMPPublisher::Socketloop: Increasing send buffer to ISB 524288 (buffer: 0 / 374784)
16:00:18: Capture window 0x001101A4 invalid or changing, terminating capture
16:00:21: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:00:21: New Scene
16:00:21: ------------------------------------------
16:00:21: device: Logitech HD Webcam C270,
16:00:21: device id \\?\usb#vid_046d&pid_0825&mi_00#6&266c8843&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
16:00:21: chosen type: I420, usingFourCC: false, res: 1280x960 - 1280x960, frameIntervals: 333333-2000000, fourCC: 'I420'
16:00:21: audio device: Disable,
16:00:21: audio device id Disabled,
16:00:21:
16:00:21: Using directshow input
16:00:21: Using bitmap image
16:00:22: PERFORMANCE WARNING: Scene change took 1091 ms, maybe some sources should be global sources?
16:00:41: Total frames rendered: 172358, number of late frames: 32 (0.02%) (it's okay for some frames to be late)
16:00:41: RTMPPublisher::SocketLoop: Graceful loop exit
16:00:41: Number of times waited to send: 0, Waited for a total of 0 bytes
16:00:41: Number of b-frames dropped: 6 (0.0035%), Number of p-frames dropped: 8 (0.0046%), Total 14 (0.0081%)
16:00:41:
16:00:41: Profiler results:
16:00:41:
16:00:41: ==============================================================
16:00:41: frame - [100%] [avg time: 1.736 ms (cpu time: avg 1.468 ms, total 253190 ms)] [avg calls per frame: 1] [children: 99.7%] [unaccounted: 0.288%]
16:00:41: | frame preprocessing and rendering - [30.2%] [avg time: 0.524 ms (cpu time: avg 0.417 ms, total 71963.3 ms)] [avg calls per frame: 1] [children: 9.04%] [unaccounted: 21.1%]
16:00:41: | | scene->Preprocess - [9.04%] [avg time: 0.157 ms (cpu time: avg 0.152 ms, total 26208.2 ms)] [avg calls per frame: 1]
16:00:41: | video encoding and uploading - [69.5%] [avg time: 1.207 ms (cpu time: avg 1.049 ms, total 180930 ms)] [avg calls per frame: 1] [children: 68.3%] [unaccounted: 1.27%]
16:00:41: | | flush - [8.01%] [avg time: 0.139 ms (cpu time: avg 0.038 ms, total 6567.66 ms)] [avg calls per frame: 1]
16:00:41: | | CopyResource - [0.922%] [avg time: 0.016 ms (cpu time: avg 0.012 ms, total 2121.61 ms)] [avg calls per frame: 0]
16:00:41: | | conversion to 4:2:0 - [0.346%] [avg time: 0.006 ms (cpu time: avg 0.004 ms, total 826.803 ms)] [avg calls per frame: 0]
16:00:41: | | call to encoder - [58.2%] [avg time: 1.01 ms (cpu time: avg 0.971 ms, total 167514 ms)] [avg calls per frame: 0]
16:00:41: | | sending stuff out - [0.806%] [avg time: 0.014 ms (cpu time: avg 0.009 ms, total 1638.01 ms)] [avg calls per frame: 0]
16:00:41: | Convert444Threads - [1.92e+003%] [avg time: 33.382 ms (cpu time: avg 1.124 ms, total 193862 ms)] [avg calls per frame: 1]
16:00:41:
16:00:41: =====Stream End: 2013-08-16, 16:00:41=================================================
Last game capture log:
2013-08-16, 15:12:52: we're booting up:
15:12:52: D3D9 Present
15:12:52: (half life scientist) everything.. seems to be in order
15:12:52: D3D9EndScene called
15:12:52: D3DPRESENT_PARAMETERS {
15:12:52: BackBufferWidth: 1920
15:12:52: BackBufferHeight: 1080
15:12:52: BackBufferFormat: D3DFMT_A8R8G8B8
15:12:52: BackBufferCount: 1
15:12:52: MultiSampleType: D3DMULTISAMPLE_NONE
15:12:52: MultiSampleQuality: 0
15:12:52: SwapEffect: D3DSWAPEFFECT_DISCARD
15:12:52: hDeviceWindow: 1114532
15:12:52: Windowed: true
15:12:52: EnableAutoDepthStencil: false
15:12:52: AutoDepthStencilFormat: D3DFMT_UNKNOWN
15:12:52: Flags: None
15:12:52: FullScreen_RefreshRateInHz: 0
15:12:52: PresentationInterval: 2147483648
15:12:52: };
15:12:52: successfully set up d3d9 hooks
15:12:52: D3D9SwapPresent called
15:12:52: DoD3D9GPUHook: success
15:12:52: D3DSURFACE_DESC {
15:12:52: Format: D3DFMT_A8R8G8B8
15:12:52: Type: D3DRTYPE_SURFACE
15:12:52: Usage: D3DUSAGE_RENDERTARGET
15:12:52: Pool: D3DPOOL_DEFAULT
15:12:52: Width: 1920
15:12:52: Height: 1080
15:12:52: };
15:12:52: successfully capturing d3d9 frames via GPU
15:12:42: Adapter 1
15:12:42: Adapter 2
15:12:42:
15:12:43: fps: 60
15:12:43: CBR: yes
15:12:43: CFR: no
15:12:51: New Scene
15:12:51:
16:00:21: New Scene
16:00:21:
16:00:41:
16:00:41:
16:00:41:
15:12:52: };
15:12:52: };
