tby83
Hi there,
I've been using OBS last night and noticed after a couple of minutes, that the audio level was very low (-55dB on average). After checking the inputs (Focusrite Scarlett 4i4 showed proper input level), I decided to restart OBS. The issue was suddenly fixed without any other modifications.
I then checked an older recording which a colleague of mine made in September and he might ran into the same issue. The sound was loud a clear at the beginning but is very low again some time into the recoding.
The version I've used yesterday is the latest (32.0.2).
I'd appreciate your feedback!
Toby
Toby
