darkdream12
Hello Community of OBS today im here to ask if anyone have experience this problem and know how to fix it, well its simple im streaming at 480p (kinda low i know) after arround 7minuts my connection goes crazy and i start laging and after a few 9mins it goes back to normal, so it makes gameplay pretty much sad. (im aware i was actualy streaming at 424x240 because of the output resolution) But still my connection goes crazy.
My system specs:
AMD Athlon II x2 250 3.0GHz
4GB RAM
EVGA GTX 550TI FPB 1GB
Upload speed 0.60 (again its pretty low i know)
Download speed 3mb
my last stream log.
My system specs:
4GB RAM
Download speed 3mb
my last stream log.
Open Broadcaster Software v0.47a - 64bit ( ^ω^)
CPU Name: AMD Athlon(tm) II X2 250 Processor
CPU Speed: 3013MHz
Physical Memory: 4095MB Total, 1370MB Free
stepping id: 3, model 6, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 2, total cores 2
Aero is Disabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 550 Ti
Video Adapter Dedicated Video Memory: 1025179648
Video Adapter Shared System Memory: 1878650880
Base resolution: 854x480
Output resolution: 424x240
Loading up D3D10...
Playback device
Using desktop audio input: Altavoces (Dispositivo de High Definition Audio)
Using auxilary audio input: Micrófono (Dispositivo de High Definition Audio)
Audio Encoding: AAC
bitrate: 96
Using text output
Video Encoding: x264
fps: 25
width: 424, height: 240
preset: veryfast
CBR: no
CFR: no
max bitrate: 510
buffer size: 306
quality: 6
Total frames rendered: 456, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Playback device
Audio Encoding: AAC
bitrate: 96
Using text output
fps: 25
preset: veryfast
CBR: no
CFR: no
max bitrate: 510
buffer size: 306
quality: 6
Server selection: rtmp://live-dfw-backup.justin.tv/app
New Scene
Using Window Capture
Using text output
Using text output
bufferTime: 2092, outputRateWindowTime: 1000, dropThreshold: 2592
Using graphics capture
New Scene
Using text output
New Scene
Using text output
Using text output
SharedTexCapture hooked
RTMPPublisher::BufferedSend: Socket buffer is full (75423 / 76800 bytes), waiting to send 3588 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76516 / 76800 bytes), waiting to send 342 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (75889 / 76800 bytes), waiting to send 1965 bytes
RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 131072
RTMPPublisher::BufferedSend: Socket buffer is full (74125 / 76800 bytes), waiting to send 3065 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (72997 / 76800 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76774 / 76800 bytes), waiting to send 3662 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (73202 / 76800 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76791 / 76800 bytes), waiting to send 323 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76714 / 76800 bytes), waiting to send 673 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (73595 / 76800 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (73918 / 76800 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (74147 / 76800 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (73510 / 76800 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76537 / 76800 bytes), waiting to send 390 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (73453 / 76800 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (74922 / 76800 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (73398 / 76800 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (74768 / 76800 bytes), waiting to send 3790 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76278 / 76800 bytes), waiting to send 3706 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76677 / 76800 bytes), waiting to send 269 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (75287 / 76800 bytes), waiting to send 3491 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76706 / 76800 bytes), waiting to send 373 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (75180 / 76800 bytes), waiting to send 3812 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76460 / 76800 bytes), waiting to send 353 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76154 / 76800 bytes), waiting to send 1053 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (75814 / 76800 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76644 / 76800 bytes), waiting to send 3714 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (74149 / 76800 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76764 / 76800 bytes), waiting to send 310 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (74697 / 76800 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76545 / 76800 bytes), waiting to send 370 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76617 / 76800 bytes), waiting to send 301 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76290 / 76800 bytes), waiting to send 1805 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (74813 / 76800 bytes), waiting to send 3790 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76528 / 76800 bytes), waiting to send 310 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76691 / 76800 bytes), waiting to send 490 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76298 / 76800 bytes), waiting to send 2555 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76460 / 76800 bytes), waiting to send 363 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (73373 / 76800 bytes), waiting to send 3658 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (74171 / 76800 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76531 / 76800 bytes), waiting to send 331 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (75009 / 76800 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (73859 / 76800 bytes), waiting to send 3030 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (76115 / 76800 bytes), waiting to send 4104 bytes
Total frames rendered: 40247, number of frames that lagged: 8974 (22.30%) (it's okay for some frames to lag)
Number of b-frames dropped: 706 (0.63%), Number of p-frames dropped: 699 (0.62%), Total 1405 (1.2%)
Profiler results:
frame - [100%] [avg time: 28.901 ms] [avg calls per frame: 1] [children: 97.7%] [unaccounted: 2.34%]
| scene->Preprocess - [62.7%] [avg time: 18.135 ms] [avg calls per frame: 1]
| video encoding and uploading - [34.9%] [avg time: 10.091 ms] [avg calls per frame: 1] [children: 3.34%] [unaccounted: 31.6%]
| | CopyResource - [0.1%] [avg time: 0.029 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.291%] [avg time: 0.084 ms] [avg calls per frame: 0]
| | call to encoder - [2.84%] [avg time: 0.822 ms] [avg calls per frame: 0]
| | sending stuff out - [0.107%] [avg time: 0.031 ms] [avg calls per frame: 0]
