Hi, I'm rather new to streaming and have taken my time reading up on the basics as well as trying out various streaming software (FFsplit, Xsplit, etc.). I've come to like OBS and would like to use it to stream League of Legends in particular. I've used the general settings from the OBS feature but I feel very sluggish ingame as I am a very heavy APM player (In other words I like to click a lot and press a lot of buttons). I have absolutely no problems playing without the stream on and have spent several hours optimizing the settings, I also have the plugin that switches scenes automatically, so I use game capture when I am ingame (also Borderless).
Log:
To be honest I'm pretty sure my computer is outdated, and I am building a new computer, list here: http://pcpartpicker.com/user/Nahga/save ... ild_361865
I'll be building this computer within 2 months or so, but I just want a general idea if this computer can handle streaming at all, or if I decide to try a Dual setup. If connection is the issue I can upgrade that as well, I just got the bare minimum since that is what I saw during most of my reads. I've also tried Aero on and off and don't see a difference.
Side note: My CPU is actually a 2.9 Ghz~ , the 1.73 is where it idles at. I believe it's a 1st Gen i7. The computer I'm using is an Asus G73JH-A2.
Log:
05:24:54: Open Broadcaster Software v0.521b - 32bit (´・ω・`)
05:24:54: -------------------------------
05:24:54: CPU Name: Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz
05:24:54: CPU Speed: 1729MHz
05:24:54: Physical Memory: 4095MB Total, 3747MB Free
05:24:54: stepping id: 5, model 14, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
05:24:54: monitor 1: pos={0, 0}, size={1920, 1080}
05:24:54: monitor 2: pos={-1280, 0}, size={1280, 1024}
05:24:54: Windows Version: 6.1 Build 7601 S
05:24:54: Aero is Disabled
05:24:54: OBS Modules:
05:24:54: Base Address Module
05:24:54: 00060000 OBS.exe
05:24:54: 683D0000 OBSApi.dll
05:24:54: 69420000 DShowPlugin.dll
05:24:54: 71270000 GraphicsCapture.dll
05:24:54: 6F660000 NoiseGate.dll
05:24:54: ------------------------------------------
05:24:54: Adapter 1
05:24:54: Video Adapter: ATI Mobility Radeon HD 5800 Series
05:24:54: Video Adapter Dedicated Video Memory: 1062043648
05:24:54: Video Adapter Shared System Memory: 3232858112
05:24:54: =====Stream Start: 2013-05-08, 05:24:54===============================================
05:24:54: Multithreaded optimizations: On
05:24:54: Base resolution: 1920x1080
05:24:54: Output resolution: 1920x1080
05:24:54: Loading up D3D10...
05:24:54: Playback device Default
05:24:54: Using desktop audio input: Speakers (Realtek High Definition Audio)
05:24:54: Using auxilary audio input: Microphone (Realtek High Definition Audio)
05:24:54: Audio Encoding: AAC
05:24:54: bitrate: 128
05:24:54: Video Encoding: x264
05:24:54: fps: 30
05:24:54: width: 1920, height: 1080
05:24:54: preset: veryfast
05:24:54: CBR: yes
05:24:54: CFR: no
05:24:54: max bitrate: 1000
05:35:03: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
05:35:03: New Scene
05:35:08: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
05:35:08: New Scene
05:35:14: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
05:35:14: New Scene
05:35:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
05:35:16: New Scene
05:42:25: Total frames rendered: 31500, number of frames that lagged: 17 (0.05%) (it's okay for some frames to lag)
05:42:25: =====Stream End: 2013-05-08, 05:42:25=================================================
05:42:26: =====Stream Start: 2013-05-08, 05:42:26===============================================
05:42:26: Multithreaded optimizations: On
05:42:26: Base resolution: 1920x1080
05:42:26: Output resolution: 1280x720
05:42:26: ------------------------------------------
05:42:26: Loading up D3D10...
05:42:27: Playback device Default
05:42:27: ------------------------------------------
05:42:27: Using desktop audio input: Speakers (Realtek High Definition Audio)
05:42:27: Using auxilary audio input: Microphone (Realtek High Definition Audio)
05:42:27: Audio Encoding: AAC
05:42:27: bitrate: 128
05:42:27: Video Encoding: x264
05:42:27: fps: 30
05:42:27: width: 1280, height: 720
05:42:27: preset: veryfast
05:42:27: CBR: yes
05:42:27: CFR: no
05:42:27: max bitrate: 1000
05:42:40: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
05:42:40: New Scene
05:42:48: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
05:42:48: New Scene
05:42:52: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
05:42:52: New Scene
05:42:54: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
05:42:54: New Scene
05:43:06: Using Monitor Capture
05:48:05: Using bitmap image
05:56:53: Total frames rendered: 25848, number of frames that lagged: 1132 (4.38%) (it's okay for some frames to lag)
05:56:54: =====Stream End: 2013-05-08, 05:56:54=================================================
05:56:55: Using fixed low latency mode, factor 20
05:56:55: =====Stream Start: 2013-05-08, 05:56:55===============================================
05:56:55: Multithreaded optimizations: On
05:56:55: Base resolution: 1920x1080
05:56:55: Output resolution: 1280x720
05:56:55: ------------------------------------------
05:56:55: Loading up D3D10...
05:56:55: Playback device Default
05:56:55: Using desktop audio input: Speakers (Realtek High Definition Audio)
05:56:55: Using auxilary audio input: Microphone (Realtek High Definition Audio)
05:56:55: Audio Encoding: AAC
05:56:55: bitrate: 128
05:56:55: Using Monitor Capture
05:56:55: Video Encoding: x264
05:56:55: fps: 30
05:56:55: width: 1280, height: 720
05:56:55: preset: veryfast
05:56:55: CBR: no
05:56:55: CFR: no
05:56:55: max bitrate: 1306
05:56:55: buffer size: 1306
05:56:55: quality: 7
05:56:57: Using RTMP service: Twitch / Justin.tv
05:56:57: Server selection: rtmp://live.justin.tv/app
05:56:57: SO_SNDBUF was at 8192
05:56:57: SO_SNDBUF is now 65536
05:57:14: Total frames rendered: 572, number of frames that lagged: 48 (8.39%) (it's okay for some frames to lag)
05:57:14: RTMPPublisher::SocketLoop: Aborting due to loop exit
05:57:14: Number of times waited to send: 0, Waited for a total of 0 bytes
05:57:14: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
05:57:14: =====Stream End: 2013-05-08, 05:57:14=================================================
05:57:29: =====Stream Start: 2013-05-08, 05:57:29===============================================
05:57:29: Multithreaded optimizations: On
05:57:29: Base resolution: 1920x1080
05:57:29: Output resolution: 1280x720
05:57:29: ------------------------------------------
05:57:29: Loading up D3D10...
05:57:29: Playback device Default
05:57:29: Using desktop audio input: Speakers (Realtek High Definition Audio)
05:57:29: Using auxilary audio input: Microphone (Realtek High Definition Audio)
05:57:29: Audio Encoding: AAC
05:57:29: bitrate: 128
05:57:29: Using Monitor Capture
05:57:29: Video Encoding: x264
05:57:29: fps: 30
05:57:29: width: 1280, height: 720
05:57:29: preset: veryfast
05:57:29: CBR: no
05:57:29: CFR: no
05:57:29: max bitrate: 1306
05:57:29: buffer size: 1306
05:57:29: quality: 7
06:00:49: Total frames rendered: 5976, number of frames that lagged: 215 (3.60%) (it's okay for some frames to lag)
06:00:49: =====Stream End: 2013-05-08, 06:00:49=================================================
06:00:50: Using fixed low latency mode, factor 20
06:00:50: =====Stream Start: 2013-05-08, 06:00:50===============================================
06:00:50: Multithreaded optimizations: On
06:00:50: Base resolution: 1920x1080
06:00:50: Output resolution: 1280x720
06:00:50: ------------------------------------------
06:00:50: Loading up D3D10...
06:00:50: Playback device Default
06:00:50: Using desktop audio input: Speakers (Realtek High Definition Audio)
06:00:50: Using auxilary audio input: Microphone (Realtek High Definition Audio)
06:00:50: Audio Encoding: AAC
06:00:50: bitrate: 128
06:00:50: Using Monitor Capture
06:00:50: Video Encoding: x264
06:00:50: fps: 30
06:00:50: width: 1280, height: 720
06:00:50: preset: veryfast
06:00:50: CBR: no
06:00:50: CFR: no
06:00:50: max bitrate: 1306
06:00:50: buffer size: 1306
06:00:50: quality: 7
06:00:52: Using RTMP service: Twitch / Justin.tv
06:00:52: Server selection: rtmp://live.justin.tv/app
06:00:52: SO_SNDBUF was at 8192
06:00:52: SO_SNDBUF is now 65536
06:03:42: Total frames rendered: 5105, number of frames that lagged: 282 (5.52%) (it's okay for some frames to lag)
06:03:42: RTMPPublisher::SocketLoop: Aborting due to loop exit
06:03:42: Number of times waited to send: 0, Waited for a total of 0 bytes
06:03:42: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
06:03:42: =====Stream End: 2013-05-08, 06:03:42=================================================
06:03:43: Using fixed low latency mode, factor 20
06:03:43: =====Stream Start: 2013-05-08, 06:03:43===============================================
06:03:43: Multithreaded optimizations: On
06:03:43: Base resolution: 1920x1080
06:03:43: Output resolution: 1280x720
06:03:43: ------------------------------------------
06:03:43: Loading up D3D10...
06:03:44: Playback device Default
06:03:44: ------------------------------------------
06:03:44: Using desktop audio input: Speakers (Realtek High Definition Audio)
06:03:44: Using auxilary audio input: Microphone (Realtek High Definition Audio)
06:03:44: Audio Encoding: AAC
06:03:44: bitrate: 128
06:03:44: Using Monitor Capture
06:03:44: Video Encoding: x264
06:03:44: fps: 30
06:03:44: width: 1280, height: 720
06:03:44: preset: veryfast
06:03:44: CBR: no
06:03:44: CFR: no
06:03:44: max bitrate: 1306
06:03:44: buffer size: 1306
06:03:44: quality: 7
06:03:45: Using RTMP service: Twitch / Justin.tv
06:03:45: Server selection: rtmp://live.justin.tv/app
06:03:46: SO_SNDBUF was at 8192
06:03:46: SO_SNDBUF is now 65536
06:04:06: Total frames rendered: 651, number of frames that lagged: 33 (5.07%) (it's okay for some frames to lag)
06:04:06: RTMPPublisher::SocketLoop: Aborting due to loop exit
06:04:06: Number of times waited to send: 0, Waited for a total of 0 bytes
06:04:06: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
06:04:06: =====Stream End: 2013-05-08, 06:04:06=================================================
06:04:11: =====Stream Start: 2013-05-08, 06:04:11===============================================
06:04:11: Multithreaded optimizations: On
06:04:11: Base resolution: 1920x1080
06:04:11: Output resolution: 1280x720
06:04:11: ------------------------------------------
06:04:11: Loading up D3D10...
06:04:11: Playback device Default
06:04:11: Using desktop audio input: Speakers (Realtek High Definition Audio)
06:04:11: Using auxilary audio input: Microphone (Realtek High Definition Audio)
06:04:12: ------------------------------------------
06:04:12: Audio Encoding: AAC
06:04:12: bitrate: 128
06:04:12: Using Monitor Capture
06:04:12: Video Encoding: x264
06:04:12: fps: 30
06:04:12: width: 1280, height: 720
06:04:12: preset: veryfast
06:04:12: CBR: no
06:04:12: CFR: no
06:04:12: max bitrate: 1306
06:04:12: buffer size: 1306
06:04:12: quality: 7
06:07:18: Total frames rendered: 5555, number of frames that lagged: 202 (3.64%) (it's okay for some frames to lag)
06:07:18: =====Stream End: 2013-05-08, 06:07:18=================================================
06:07:18: Using fixed low latency mode, factor 20
06:07:18: =====Stream Start: 2013-05-08, 06:07:18===============================================
06:07:18: Multithreaded optimizations: On
06:07:18: Base resolution: 1920x1080
06:07:18: Output resolution: 1280x720
06:07:18: ------------------------------------------
06:07:18: Loading up D3D10...
06:07:18: Playback device Default
06:07:18: Using desktop audio input: Speakers (Realtek High Definition Audio)
06:07:18: Using auxilary audio input: Microphone (Realtek High Definition Audio)
06:07:19: ------------------------------------------
06:07:19: Audio Encoding: AAC
06:07:19: bitrate: 128
06:07:19: Using Monitor Capture
06:07:19: Video Encoding: x264
06:07:19: fps: 30
06:07:19: width: 1280, height: 720
06:07:19: preset: veryfast
06:07:19: CBR: no
06:07:19: CFR: no
06:07:19: max bitrate: 1306
06:07:19: buffer size: 1306
06:07:19: quality: 7
06:07:20: Using RTMP service: Twitch / Justin.tv
06:07:20: Server selection: rtmp://live.justin.tv/app
06:07:21: SO_SNDBUF was at 8192
06:07:21: SO_SNDBUF is now 65536
06:07:45: Total frames rendered: 785, number of frames that lagged: 41 (5.22%) (it's okay for some frames to lag)
06:07:45: RTMPPublisher::SocketLoop: Aborting due to loop exit
06:07:45: Number of times waited to send: 0, Waited for a total of 0 bytes
06:07:45: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
06:07:45: =====Stream End: 2013-05-08, 06:07:45=================================================
06:07:49: Using fixed low latency mode, factor 20
06:07:49: =====Stream Start: 2013-05-08, 06:07:49===============================================
06:07:49: Multithreaded optimizations: On
06:07:49: Base resolution: 1920x1080
06:07:49: Output resolution: 1280x720
06:07:49: ------------------------------------------
06:07:49: Loading up D3D10...
06:07:49: Playback device Default
06:07:49: Using desktop audio input: Speakers (Realtek High Definition Audio)
06:07:49: Using auxilary audio input: Microphone (Realtek High Definition Audio)
06:07:49: Audio Encoding: AAC
06:07:49: bitrate: 128
06:07:50: Using Monitor Capture
06:07:50: ------------------------------------------
06:07:50: Video Encoding: x264
06:07:50: fps: 30
06:07:50: width: 1280, height: 720
06:07:50: preset: veryfast
06:07:50: CBR: no
06:07:50: CFR: no
06:07:50: max bitrate: 1306
06:07:50: buffer size: 1306
06:07:50: quality: 7
06:07:51: Using RTMP service: Twitch / Justin.tv
06:07:51: Server selection: rtmp://live.justin.tv/app
06:07:52: SO_SNDBUF was at 8192
06:07:52: SO_SNDBUF is now 65536
06:08:33: Total frames rendered: 1292, number of frames that lagged: 65 (5.03%) (it's okay for some frames to lag)
06:08:33: RTMPPublisher::SocketLoop: Aborting due to loop exit
06:08:33: Number of times waited to send: 0, Waited for a total of 0 bytes
06:08:33: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
06:08:33: =====Stream End: 2013-05-08, 06:08:33=================================================
06:11:43: Using fixed low latency mode, factor 20
06:11:43: =====Stream Start: 2013-05-08, 06:11:43===============================================
06:11:43: Multithreaded optimizations: On
06:11:43: Base resolution: 1920x1080
06:11:43: Output resolution: 1280x720
06:11:43: ------------------------------------------
06:11:43: Loading up D3D10...
06:11:43: Playback device Default
06:11:43: Using desktop audio input: Speakers (Realtek High Definition Audio)
06:11:43: Using auxilary audio input: Microphone (Realtek High Definition Audio)
06:11:43: Audio Encoding: AAC
06:11:43: bitrate: 128
06:11:43: Using Monitor Capture
06:11:44: ------------------------------------------
06:11:44: Video Encoding: x264
06:11:44: fps: 30
06:11:44: width: 1280, height: 720
06:11:44: preset: veryfast
06:11:44: CBR: no
06:11:44: CFR: no
06:11:44: max bitrate: 1306
06:11:44: buffer size: 1306
06:11:44: quality: 7
06:11:45: Using RTMP service: Twitch / Justin.tv
06:11:45: Server selection: rtmp://live.justin.tv/app
06:11:46: SO_SNDBUF was at 8192
06:11:46: SO_SNDBUF is now 65536
06:20:08: Total frames rendered: 11791, number of frames that lagged: 6905 (58.56%) (it's okay for some frames to lag)
06:20:08: RTMPPublisher::SocketLoop: Aborting due to loop exit
06:20:08: Number of times waited to send: 0, Waited for a total of 0 bytes
06:20:08: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
06:20:09: =====Stream End: 2013-05-08, 06:20:09=================================================
06:38:22: =====Stream Start: 2013-05-08, 06:38:22===============================================
06:38:22: Multithreaded optimizations: On
06:38:22: Base resolution: 1920x1080
06:38:22: Output resolution: 1280x720
06:38:22: ------------------------------------------
06:38:22: Loading up D3D10...
06:38:23: Playback device Default
06:38:23: ------------------------------------------
06:38:23: Using desktop audio input: Speakers (Realtek High Definition Audio)
06:38:23: Using auxilary audio input: Microphone (Realtek High Definition Audio)
06:38:23: Audio Encoding: AAC
06:38:23: bitrate: 128
06:38:23: Using Monitor Capture
06:38:23: Video Encoding: x264
06:38:23: fps: 30
06:38:23: width: 1280, height: 720
06:38:23: preset: veryfast
06:38:23: CBR: no
06:38:23: CFR: no
06:38:23: max bitrate: 1306
06:38:23: buffer size: 1306
06:38:23: quality: 7
06:38:24: Using RTMP service: Twitch / Justin.tv
06:38:24: Server selection: rtmp://live.justin.tv/app
06:38:25: SO_SNDBUF was at 8192
06:38:25: SO_SNDBUF is now 65536
06:44:08: Total frames rendered: 9116, number of frames that lagged: 4943 (54.22%) (it's okay for some frames to lag)
06:44:08: RTMPPublisher::SocketLoop: Aborting due to bStopping
06:44:08: Number of times waited to send: 0, Waited for a total of 0 bytes
06:44:08: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
06:44:08: =====Stream End: 2013-05-08, 06:44:08=================================================
07:10:55: =====Stream Start: 2013-05-08, 07:10:55===============================================
07:10:55: Multithreaded optimizations: On
07:10:55: Base resolution: 1920x1080
07:10:55: Output resolution: 960x540
07:10:55: ------------------------------------------
07:10:55: Loading up D3D10...
07:10:55: Playback device Default
07:10:55: Using desktop audio input: Speakers (Realtek High Definition Audio)
07:10:55: Using auxilary audio input: Microphone (Realtek High Definition Audio)
07:10:55: Audio Encoding: AAC
07:10:55: bitrate: 128
07:10:55: Using Monitor Capture
07:10:55: Video Encoding: x264
07:10:55: fps: 25
07:10:55: width: 960, height: 540
07:10:55: preset: veryfast
07:10:55: CBR: no
07:10:55: CFR: no
07:10:55: max bitrate: 1306
07:10:55: buffer size: 1306
07:10:55: quality: 7
07:10:57: Using RTMP service: Twitch / Justin.tv
07:10:57: Server selection: rtmp://live.justin.tv/app
07:10:58: SO_SNDBUF was at 8192
07:10:58: SO_SNDBUF is now 65536
07:32:05: Total frames rendered: 30621, number of frames that lagged: 5856 (19.12%) (it's okay for some frames to lag)
07:32:05: RTMPPublisher::SocketLoop: Aborting due to bStopping
07:32:05: Number of times waited to send: 0, Waited for a total of 0 bytes
07:32:05: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
07:32:05: =====Stream End: 2013-05-08, 07:32:05=================================================
07:55:07: =====Stream Start: 2013-05-08, 07:55:07===============================================
07:55:07: Multithreaded optimizations: On
07:55:07: Base resolution: 1920x1080
07:55:07: Output resolution: 852x480
07:55:07: ------------------------------------------
07:55:07: Loading up D3D10...
07:55:08: Playback device Default
07:55:08: ------------------------------------------
07:55:08: Using desktop audio input: Speakers (Realtek High Definition Audio)
07:55:08: Using auxilary audio input: Microphone (Realtek High Definition Audio)
07:55:08: Audio Encoding: AAC
07:55:08: bitrate: 128
07:55:08: Using graphics capture
07:55:08: Video Encoding: x264
07:55:08: fps: 30
07:55:08: width: 852, height: 480
07:55:08: preset: veryfast
07:55:08: CBR: no
07:55:08: CFR: no
07:55:08: max bitrate: 1306
07:55:08: buffer size: 1306
07:55:08: quality: 7
07:55:08: SharedTexCapture hooked
07:55:48: Exit signal received, terminating capture
07:55:50: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
07:55:50: New Scene
07:55:50: Using Monitor Capture
07:55:53: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
07:55:53: New Scene
07:57:05: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
07:57:05: New Scene
07:57:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
07:57:06: New Scene
07:57:24: SharedTexCapture hooked
07:57:43: Exit signal received, terminating capture
07:57:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
07:57:46: New Scene
07:58:41: SharedTexCapture hooked
08:00:13: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
08:00:13: New Scene
08:00:37: Exit signal received, terminating capture
08:00:40: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
08:00:40: New Scene
08:00:42: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
08:00:42: New Scene
08:00:48: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
08:00:48: New Scene
08:03:30: Using text output
08:17:57: Total frames rendered: 34994, number of frames that lagged: 12824 (36.65%) (it's okay for some frames to lag)
08:17:57: =====Stream End: 2013-05-08, 08:17:57=================================================
08:17:58: =====Stream Start: 2013-05-08, 08:17:58===============================================
08:17:58: Multithreaded optimizations: On
08:17:58: Base resolution: 1920x1080
08:17:58: Output resolution: 852x480
08:17:58: ------------------------------------------
08:17:58: Loading up D3D10...
08:17:58: Playback device Default
08:17:58: Using desktop audio input: Speakers (Realtek High Definition Audio)
08:17:58: Using auxilary audio input: Microphone (Realtek High Definition Audio)
08:17:58: Audio Encoding: AAC
08:17:58: bitrate: 128
08:17:58: Using text output
08:17:58: Using graphics capture
08:17:58: Using Monitor Capture
08:17:58: Video Encoding: x264
08:17:58: fps: 45
08:17:58: width: 852, height: 480
08:17:58: preset: veryfast
08:17:58: CBR: no
08:17:58: CFR: no
08:17:58: max bitrate: 1306
08:17:58: buffer size: 1306
08:17:58: quality: 7
08:18:00: Using RTMP service: Twitch / Justin.tv
08:18:00: Server selection: rtmp://live.justin.tv/app
08:18:01: SO_SNDBUF was at 8192
08:18:01: SO_SNDBUF is now 65536
08:18:43: SharedTexCapture hooked
08:22:03: Exit signal received, terminating capture
08:24:06: SharedTexCapture hooked
08:47:04: Exit signal received, terminating capture
08:47:14: Total frames rendered: 34694, number of frames that lagged: 34694 (100.00%) (it's okay for some frames to lag)
08:47:14: RTMPPublisher::SocketLoop: Aborting due to bStopping
08:47:14: Number of times waited to send: 0, Waited for a total of 0 bytes
08:47:14: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
08:47:14: =====Stream End: 2013-05-08, 08:47:14=================================================
08:48:46: =====Stream Start: 2013-05-08, 08:48:46===============================================
08:48:46: Multithreaded optimizations: On
08:48:46: Base resolution: 1920x1080
08:48:46: Output resolution: 852x480
08:48:46: ------------------------------------------
08:48:46: Loading up D3D10...
08:48:46: Playback device Default
08:48:46: Using desktop audio input: Speakers (Realtek High Definition Audio)
08:48:46: Using auxilary audio input: Microphone (Realtek High Definition Audio)
08:48:46: Audio Encoding: AAC
08:48:46: bitrate: 128
08:48:46: Using text output
08:48:46: Using graphics capture
08:48:46: Using Monitor Capture
08:48:46: Video Encoding: x264
08:48:46: fps: 60
08:48:46: width: 852, height: 480
08:48:46: preset: faster
08:48:46: CBR: no
08:48:46: CFR: no
08:48:46: max bitrate: 1306
08:48:46: buffer size: 1306
08:48:46: quality: 6
08:48:49: Using RTMP service: Twitch / Justin.tv
08:48:49: Server selection: rtmp://live.justin.tv/app
08:48:49: SO_SNDBUF was at 8192
08:48:49: SO_SNDBUF is now 65536
08:50:56: SharedTexCapture hooked
08:53:21: GraphicsCaptureSource::NewCapture: eliminating old capture
08:53:21: SharedTexCapture hooked
08:53:58: GraphicsCaptureSource::NewCapture: eliminating old capture
08:53:58: SharedTexCapture hooked
09:10:11: Exit signal received, terminating capture
09:10:30: Total frames rendered: 25531, number of frames that lagged: 25531 (100.00%) (it's okay for some frames to lag)
09:10:30: RTMPPublisher::SocketLoop: Aborting due to bStopping
09:10:30: Number of times waited to send: 0, Waited for a total of 0 bytes
09:10:30: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
09:10:30: =====Stream End: 2013-05-08, 09:10:30=================================================
09:11:50: =====Stream Start: 2013-05-08, 09:11:50===============================================
09:11:50: Multithreaded optimizations: On
09:11:50: Base resolution: 1920x1080
09:11:50: Output resolution: 852x480
09:11:50: ------------------------------------------
09:11:50: Loading up D3D10...
09:11:50: Playback device Default
09:11:50: Using desktop audio input: Speakers (Realtek High Definition Audio)
09:11:50: Using auxilary audio input: Microphone (Realtek High Definition Audio)
09:11:50: Audio Encoding: AAC
09:11:50: bitrate: 128
09:11:50: Using text output
09:11:50: Using graphics capture
09:11:50: Using Monitor Capture
09:11:50: Video Encoding: x264
09:11:50: fps: 60
09:11:50: width: 852, height: 480
09:11:50: preset: fast
09:11:50: CBR: no
09:11:50: CFR: no
09:11:50: max bitrate: 1306
09:11:50: buffer size: 1306
09:11:50: quality: 6
09:11:54: Using RTMP service: Twitch / Justin.tv
09:11:54: Server selection: rtmp://live.justin.tv/app
09:11:55: SO_SNDBUF was at 8192
09:11:55: SO_SNDBUF is now 65536
09:14:15: SharedTexCapture hooked
09:40:15: Exit signal received, terminating capture
09:40:20: Total frames rendered: 33261, number of frames that lagged: 33261 (100.00%) (it's okay for some frames to lag)
09:40:20: RTMPPublisher::SocketLoop: Aborting due to bStopping
09:40:20: Number of times waited to send: 0, Waited for a total of 0 bytes
09:40:20: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
09:40:20: =====Stream End: 2013-05-08, 09:40:20=================================================
10:19:52:
10:19:52: Profiler results:
10:19:52:
10:19:52: ==============================================================
10:19:52: frame - [100%] [avg time: 31.336 ms] [avg calls per frame: 1] [children: 96.2%] [unaccounted: 3.77%]
10:19:52: | scene->Preprocess - [90.7%] [avg time: 28.414 ms] [avg calls per frame: 1]
10:19:52: | video encoding and uploading - [5.56%] [avg time: 1.742 ms] [avg calls per frame: 1] [children: 5.47%] [unaccounted: 0.0862%]
10:19:52: | | CopyResource - [0.0447%] [avg time: 0.014 ms] [avg calls per frame: 0]
10:19:52: | | conversion to 4:2:0 - [0.0543%] [avg time: 0.017 ms] [avg calls per frame: 0]
10:19:52: | | call to encoder - [5.32%] [avg time: 1.666 ms] [avg calls per frame: 0]
10:19:52: | | sending stuff out - [0.0574%] [avg time: 0.018 ms] [avg calls per frame: 0]
10:19:52:
10:23:29: Open Broadcaster Software v0.521b - 64bit ( ^ω^)
10:23:29: -------------------------------
10:23:29: CPU Name: Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz
10:23:29: CPU Speed: 1729MHz
10:23:29: Physical Memory: 8116MB Total, 3572MB Free
10:23:29: stepping id: 5, model 14, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
10:23:29: monitor 1: pos={0, 0}, size={1920, 1080}
10:23:29: monitor 2: pos={-1280, 0}, size={1280, 1024}
10:23:29: Windows Version: 6.1 Build 7601 S
10:23:29: Aero is Enabled
10:23:29: OBS Modules:
10:23:29: Base Address Module
10:23:29: 000000003F480000 OBS.exe
10:23:29: 00000000E1E50000 OBSApi.dll
10:23:29: 00000000F8000000 DShowPlugin.dll
10:23:29: 00000000F6620000 GraphicsCapture.dll
10:23:29: 00000000F7070000 NoiseGate.dll
10:23:29: ------------------------------------------
10:23:29: Adapter 1
10:23:29: Video Adapter: ATI Mobility Radeon HD 5800 Series
10:23:29: Video Adapter Dedicated Video Memory: 1062043648
10:23:29: Video Adapter Shared System Memory: 3986974720
10:23:29: =====Stream Start: 2013-05-08, 10:23:29===============================================
10:23:29: Multithreaded optimizations: On
10:23:29: Base resolution: 1920x1080
10:23:29: Output resolution: 852x480
10:23:30: Loading up D3D10...
10:23:30: Playback device Default
10:23:30: ------------------------------------------
10:23:30: Using desktop audio input: Speakers (Realtek High Definition Audio)
10:23:30: Using auxilary audio input: Microphone (Realtek High Definition Audio)
10:23:30: Audio Encoding: AAC
10:23:30: bitrate: 128
10:23:30: Using text output
10:23:30: Using graphics capture
10:23:30: Using Monitor Capture
10:23:30: Video Encoding: x264
10:23:30: fps: 60
10:23:30: width: 852, height: 480
10:23:30: preset: fast
10:23:30: CBR: no
10:23:30: CFR: no
10:23:30: max bitrate: 1306
10:23:30: buffer size: 1306
10:23:30: quality: 6
10:26:35: Total frames rendered: 3604, number of frames that lagged: 3604 (100.00%) (it's okay for some frames to lag)
10:26:35: =====Stream End: 2013-05-08, 10:26:35=================================================
10:26:35:
10:26:35: Profiler results:
10:26:35:
10:26:35: ==============================================================
10:26:35: frame - [100%] [avg time: 51.095 ms] [avg calls per frame: 1] [children: 99.2%] [unaccounted: 0.818%]
10:26:35: | scene->Preprocess - [97.3%] [avg time: 49.722 ms] [avg calls per frame: 1]
10:26:35: | video encoding and uploading - [1.87%] [avg time: 0.955 ms] [avg calls per frame: 1] [children: 1.83%] [unaccounted: 0.0352%]
10:26:35: | | CopyResource - [0.0274%] [avg time: 0.014 ms] [avg calls per frame: 0]
10:26:35: | | conversion to 4:2:0 - [0.0235%] [avg time: 0.012 ms] [avg calls per frame: 0]
10:26:35: | | call to encoder - [1.78%] [avg time: 0.909 ms] [avg calls per frame: 0]
10:26:35: | | sending stuff out - [0.00391%] [avg time: 0.002 ms] [avg calls per frame: 0]
10:26:35:
10:26:39: Open Broadcaster Software v0.521b - 64bit ( ^ω^)
10:26:39: -------------------------------
10:26:39: CPU Name: Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz
10:26:39: CPU Speed: 1729MHz
10:26:39: Physical Memory: 8116MB Total, 3562MB Free
10:26:39: stepping id: 5, model 14, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
10:26:39: monitor 1: pos={0, 0}, size={1920, 1080}
10:26:39: monitor 2: pos={-1280, 0}, size={1280, 1024}
10:26:39: Windows Version: 6.1 Build 7601 S
10:26:39: Aero is Enabled
10:26:39: OBS Modules:
10:26:39: Base Address Module
10:26:39: 000000003FAA0000 OBS.exe
10:26:39: 00000000E1E50000 OBSApi.dll
10:26:39: 00000000F6660000 DShowPlugin.dll
10:26:39: 00000000F8000000 GraphicsCapture.dll
10:26:39: 00000000F8150000 NoiseGate.dll
10:26:39: 00000000F7CC0000 scenesw.dll
10:26:39: ------------------------------------------
10:26:39: Adapter 1
10:26:39: Video Adapter: ATI Mobility Radeon HD 5800 Series
10:26:39: Video Adapter Dedicated Video Memory: 1062043648
10:26:39: Video Adapter Shared System Memory: 3986974720
10:26:39: =====Stream Start: 2013-05-08, 10:26:39===============================================
10:26:39: Multithreaded optimizations: On
10:26:39: Base resolution: 1920x1080
10:26:39: Output resolution: 852x480
10:26:39: Loading up D3D10...
10:26:39: Playback device Default
10:26:39: Using desktop audio input: Speakers (Realtek High Definition Audio)
10:26:39: Using auxilary audio input: Microphone (Realtek High Definition Audio)
10:26:39: Audio Encoding: AAC
10:26:39: bitrate: 128
10:26:39: Using text output
10:26:39: Using graphics capture
10:26:39: Using Monitor Capture
10:26:39: Video Encoding: x264
10:26:39: fps: 60
10:26:39: width: 852, height: 480
10:26:39: preset: fast
10:26:39: CBR: no
10:26:39: CFR: no
10:26:39: max bitrate: 1306
10:26:39: buffer size: 1306
10:26:39: quality: 6
10:27:00: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
10:27:00: New Scene
10:27:22: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
10:27:22: New Scene
10:27:48: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
10:27:48: New Scene
10:27:52: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
10:27:52: New Scene
10:30:40: SharedTexCapture hooked
10:30:52: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
10:30:52: New Scene
10:30:52: New Scene
10:30:54: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
10:30:54: New Scene
10:30:54: New Scene
10:32:04: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
10:32:04: New Scene
10:34:06: Exit signal received, terminating capture
10:34:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
10:34:06: New Scene
10:35:02: Total frames rendered: 9082, number of frames that lagged: 9082 (100.00%) (it's okay for some frames to lag)
10:35:02: =====Stream End: 2013-05-08, 10:35:02=================================================
11:07:18: =====Stream Start: 2013-05-08, 11:07:18===============================================
11:07:18: Multithreaded optimizations: On
11:07:18: Base resolution: 1920x1080
11:07:18: Output resolution: 852x480
11:07:18: ------------------------------------------
11:07:18: Loading up D3D10...
11:07:18: Playback device Default
11:07:19: ------------------------------------------
11:07:19: Using desktop audio input: Speakers (Realtek High Definition Audio)
11:07:19: Using auxilary audio input: Microphone (Realtek High Definition Audio)
11:07:19: Audio Encoding: AAC
11:07:19: bitrate: 128
11:07:19: Using text output
11:07:19: Using Monitor Capture
11:07:19: Video Encoding: x264
11:07:19: fps: 30
11:07:19: width: 852, height: 480
11:07:19: preset: veryfast
11:07:19: CBR: no
11:07:19: CFR: no
11:07:19: max bitrate: 1306
11:07:19: buffer size: 1306
11:07:19: quality: 6
11:07:28: Using Window Capture
11:08:43: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
11:08:43: New Scene
11:08:43: Using graphics capture
11:08:43: New Scene
11:13:04: Total frames rendered: 7102, number of frames that lagged: 6312 (88.88%) (it's okay for some frames to lag)
11:13:04: =====Stream End: 2013-05-08, 11:13:04=================================================
11:13:07:
11:13:07: Profiler results:
11:13:07:
11:13:07: ==============================================================
11:13:07: frame - [100%] [avg time: 51.965 ms] [avg calls per frame: 1] [children: 99%] [unaccounted: 0.951%]
11:13:07: | scene->Preprocess - [97.2%] [avg time: 50.493 ms] [avg calls per frame: 1]
11:13:07: | video encoding and uploading - [1.88%] [avg time: 0.978 ms] [avg calls per frame: 1] [children: 1.85%] [unaccounted: 0.0289%]
11:13:07: | | CopyResource - [0.025%] [avg time: 0.013 ms] [avg calls per frame: 0]
11:13:07: | | conversion to 4:2:0 - [0.0289%] [avg time: 0.015 ms] [avg calls per frame: 0]
11:13:07: | | call to encoder - [1.79%] [avg time: 0.932 ms] [avg calls per frame: 0]
11:13:07: | | sending stuff out - [0.00577%] [avg time: 0.003 ms] [avg calls per frame: 0]
11:13:07:
11:13:12: Open Broadcaster Software v0.521b - 64bit ( ^ω^)
11:13:12: -------------------------------
11:13:12: CPU Name: Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz
11:13:12: CPU Speed: 1729MHz
11:13:12: Physical Memory: 8116MB Total, 3525MB Free
11:13:12: stepping id: 5, model 14, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
11:13:12: monitor 1: pos={0, 0}, size={1920, 1080}
11:13:12: monitor 2: pos={-1280, 0}, size={1280, 1024}
11:13:12: Windows Version: 6.1 Build 7601 S
11:13:12: Aero is Enabled
11:13:12: OBS Modules:
11:13:12: Base Address Module
11:13:12: 000000003FA70000 OBS.exe
11:13:12: 00000000E2060000 OBSApi.dll
11:13:12: 00000000FB730000 DShowPlugin.dll
11:13:12: 00000000FBB40000 GraphicsCapture.dll
11:13:12: 00000000F8150000 NoiseGate.dll
11:13:12: 00000000F8430000 scenesw.dll
11:13:12: ------------------------------------------
11:13:12: Adapter 1
11:13:12: Video Adapter: ATI Mobility Radeon HD 5800 Series
11:13:12: Video Adapter Dedicated Video Memory: 1062043648
11:13:12: Video Adapter Shared System Memory: 3986974720
11:13:12: =====Stream Start: 2013-05-08, 11:13:12===============================================
11:13:12: Multithreaded optimizations: On
11:13:12: Base resolution: 1920x1080
11:13:12: Output resolution: 852x480
11:13:12: Loading up D3D10...
11:13:13: Playback device Default
11:13:13: ------------------------------------------
11:13:13: Using desktop audio input: Speakers (Realtek High Definition Audio)
11:13:13: Using auxilary audio input: Microphone (Realtek High Definition Audio)
11:13:13: Audio Encoding: AAC
11:13:13: bitrate: 128
11:13:13: Using Window Capture
11:13:13: Using text output
11:13:13: Using Monitor Capture
11:13:13: Video Encoding: x264
11:13:13: fps: 30
11:13:13: width: 852, height: 480
11:13:13: preset: veryfast
11:13:13: CBR: no
11:13:13: CFR: no
11:13:13: max bitrate: 1306
11:13:13: buffer size: 1306
11:13:13: quality: 6
11:13:19: Total frames rendered: 115, number of frames that lagged: 115 (100.00%) (it's okay for some frames to lag)
11:13:19: =====Stream End: 2013-05-08, 11:13:19=================================================
11:39:22:
11:39:22: Profiler results:
11:39:22:
11:39:22: ==============================================================
11:39:22: frame - [100%] [avg time: 50.816 ms] [avg calls per frame: 1] [children: 98.6%] [unaccounted: 1.4%]
11:39:22: | scene->Preprocess - [96.8%] [avg time: 49.181 ms] [avg calls per frame: 1]
11:39:22: | video encoding and uploading - [1.82%] [avg time: 0.924 ms] [avg calls per frame: 1] [children: 1.79%] [unaccounted: 0.0276%]
11:39:22: | | CopyResource - [0.0216%] [avg time: 0.011 ms] [avg calls per frame: 0]
11:39:22: | | conversion to 4:2:0 - [0.0157%] [avg time: 0.008 ms] [avg calls per frame: 0]
11:39:22: | | call to encoder - [1.75%] [avg time: 0.89 ms] [avg calls per frame: 0]
11:39:22: | | sending stuff out - [0.00197%] [avg time: 0.001 ms] [avg calls per frame: 0]
11:39:22:
