I figured I should not post this in problems and bugs since I am not having errors or crashing with obs and it's more of a streaming issue post so I was not sure maybe someone can help...I just did some speed test's at testmy.net and I have link's to two result's here is the first one
and here is the second one
...i've tried setting the max bitrate and buffer size to the same thing when I set them the last setting was 530 for max bitrate and buffer size in obs...the quality is set to 5 and audio is set to aac,128 bitrate,44.1khz...the stream to http://www.twitch.tv lagged and the audio and video were behind so I figured it was time for help...I have streamed before even though it was a while back on justin.tv I used justin's default option's instead of xsplit to stream black ops and the speed of the stream was good so I should be able to stream thing's...I usually try to stream from ps2,ps3,and capture video's on my pc using manycam as the video capture device in obs based on the two result's from testmy.net of upload speed's what should I set the max bitrate and buffer size as to end the lag?
