True constant quality mode for h264_nvenc and hevc_nvenc?
whitepuzzle
Currently the only way to use true constant quality mode with these encoders is with the FFmpeg custom output mode set to options "rc=vbr b=0 cq=[0-51]", which doesn't work with replay buffer. Is there any plan to add a proper CQ mode to the standard output in the future? VBR and CQP are both inferior for quality-to-filesize ratio.
I did a test game recording with CQ mode and it seems to work just fine without overloading the encoder or anything, so I doubt it's a technical limitation that prevents it from being officially implemented.
rockbottom
I think you're confused or looking at bad information.
-cq <float> E..V....... Set target quality level (0 to 51, 0 means automatic) for constant quality mode in VBR rate control (from 0 to 51) (default 0)
  • H264_NVENC_2022-05-20.txt
  • H265_NVENC_2022-05-20.txt
whitepuzzle
Definitely not confused about anything. I was right that CQ (Constant Quality) and CQP (Constant Quantizer Parameter) are not the same thing, however I just did some test encodes with ffmpeg comparing CQ (-rc vbr -b 0 -cq X) and CQP (-rc constqp -qp X) modes for hevc_nvenc and found that, at the same file size, CQ mode actually has worse quality than CQP, at least at lower bitrates. I guess OBS devs don't implement the true CQ mode for a reason? According to information I've read on this forum and other forums, CQ mode should in theory outperform CQP mode. Perhaps that's only true for h264_nvenc which I will test later.
rockbottom
The attached docs are correct for NVENC. CQ is the target quality setting. Your encoder settings are more than likely being rejected. Look at your log.
Try this to start & adjust as needed. H265
preset=hq profile=main tier=high rc=constqp rc-lookahead=0 init_qpI=15 init_qpP=18 init_qpB=20 bf=0 b_ref_mode=disabled refs=4
