Bug Report Trouble with video capture device?
chicagofan
Any time I try to use my capture device through OBS's "Video Capture Device" option, it goes for a couple seconds without showing anything and then OBS Crashes. It's a very consistent crash, and the most recent crash log was this:
This crash appears to have occured in the 'c:\program files (x86)\obs\plugins\dshowplugin.dll' module.
Fault address: 630BCB20 (c:\program files (x86)\obs\plugins\dshowplugin.dll)
OBS version: Open Broadcaster Software v0.631b
CPU: AMD Athlon(tm) II X2 245 Processor
Crashing thread stack trace:
Stack  EIP  Arg0  Arg1  Arg2  Arg3  Address
0DE5F990 630BCB20 09A58000 12060000 00000C00 000001E0 dshowplugin.dll!DeviceSource::Convert422To444+0x110
0DE5F9B0 630B5B5F 001E0000 5D26C7F0 0142C29F 00000000 dshowplugin.dll!DeviceSource::Preprocess+0x1af
0DE5FA04 5D265818 00000000 00000000 00000000 00000070 obsapi.dll!Scene::Preprocess+0x28
0DE5FA10 0142C29F 775E338A 00000000 0DE5FDA4 77B39F72 obs.exe!OBS::MainCaptureLoop+0xacf
0DE5FD5C 0142A1B5 00000000 0DE5FDA4 77B39F72 00000000 obs.exe!OBS::MainCaptureThread+0x5
0DE5FD60 775E338A 00000000 7A7784CF 00000000 00000000 kernel32.dll!0x775e338a
0DE5FD6C 77B39F72 0142A1B0 00000000 00000000 00000000 ntdll.dll!0x77b39f72
0DE5FDAC 77B39F45 0142A1B0 00000000 00000000 00000000 ntdll.dll!0x77b39f45
A minidump was saved to C:\Users\CJ\AppData\Roaming\OBS\crashDumps\OBSCrashDump2014-09-11_9.dmp.
List of loaded modules:
Base Address  Module
I suspect it might just be the capture, but I want to make sure.
  • OBSCrashDump2014-09-11_9.dmp
chicagofan
It's just an easycap. I'm kind of skeptical about it though.
For more clarification, what happens every time is that I try to use a Capture Device (which lists itself as SMI Grabber Device, and is the reason I'm skeptical,) with OBS, leave everything as default (or not. it doesnt change the outcome, really) and confirm the settings. OBS runs for 3 seconds at most, with nothing showing up in regards to the capture device, and then crashes.
chicagofan
Double post to status update.
I'm not quite sure what I did, or if I even did anything, but somehow I got OBS to display the game without crashing. I did mess around with the easycap (now dubbed easycrap) a lot, and uninstalled and reinstalled numerous times, testing drivers constantly... and I had the video capture on a different scene when I got the capture card displaying in Virtualdub and trying to capture the video by Window Capturing Virtualdub. Vdub was eating up my computer's resources, though, so I started clicking around some more and I accidentally clicked on the scene with the Video Capture Device, and my game was there and OBS didn't crash.
Although, the game feed has this odd green line on the bottom of it. But I can easily just move that out of the viewing window just fine, so it's not too big of an issue.
Long story short, my easycap more than likely had the issue, rather than OBS. In any case, thank you for your time.
