I am starting to get problems when i am streaming. I used to use 2000 kbit, 10 quality, 25 FPS with no problems but now my stream now is always laggy and i dont understand why.
Internet Info:
Past Log File:
Internet Info:
Past Log File:
Open Broadcaster Software v0.472b - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
CPU Speed: 3467MHz
Physical Memory: 4095MB Total, 4095MB Free
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
monitor 2: pos={-1920, 0}, size={1920, 1080}
Aero is Disabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 550 Ti
Video Adapter Dedicated Video Memory: 1025179648
Video Adapter Shared System Memory: 3221368832
Using fixed low latency mode, factor 20
Base resolution: 1920x1080
Output resolution: 1280x720
Loading up D3D10...
Playback device Default
Using desktop audio input: Speakers (USB PnP Sound Device)
Using auxilary audio input: Microphone (USB PnP Sound Device)
Audio Encoding: AAC
bitrate: 192
Using graphics capture
Using bitmap image
Using text output
Using Monitor Capture
x264: profile High, level 3.1
Video Encoding: x264
fps: 25
width: 1280, height: 720
preset: veryfast
CBR: no
CFR: no
max bitrate: 2000
buffer size: 3000
quality: 4
timestamps for 'Microphone (USB PnP Sound Device)' just decided to go wacky. reverting to desktop time. PRAISE WONDERFUL DEVICE DRIVERS
SharedTexCapture hooked
Server selection: rtmp://live-ord.justin.tv/app
bufferTime: 1899, outputRateWindowTime: 1000, dropThreshold: 2399
RTMPPublisher::BufferedSend: Socket buffer is full (279946 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280088 / 280576 bytes), waiting to send 3729 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280283 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278225 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278394 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280177 / 280576 bytes), waiting to send 675 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278375 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280084 / 280576 bytes), waiting to send 662 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278516 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (276816 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280546 / 280576 bytes), waiting to send 596 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280179 / 280576 bytes), waiting to send 578 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279102 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279119 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279323 / 280576 bytes), waiting to send 3555 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280317 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277021 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278025 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279809 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278959 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280162 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280458 / 280576 bytes), waiting to send 546 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280297 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279582 / 280576 bytes), waiting to send 3770 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280481 / 280576 bytes), waiting to send 649 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278659 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278718 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280492 / 280576 bytes), waiting to send 607 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278507 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277319 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278937 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278635 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280077 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279203 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278935 / 280576 bytes), waiting to send 3448 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280543 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280324 / 280576 bytes), waiting to send 655 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280217 / 280576 bytes), waiting to send 589 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277517 / 280576 bytes), waiting to send 3165 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280018 / 280576 bytes), waiting to send 638 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280428 / 280576 bytes), waiting to send 659 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280311 / 280576 bytes), waiting to send 630 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277812 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278620 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279421 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (276836 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280379 / 280576 bytes), waiting to send 622 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277712 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (276714 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279724 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277928 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280131 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279862 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280210 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279363 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278545 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278348 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277123 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279525 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277205 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280263 / 280576 bytes), waiting to send 665 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279229 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277757 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280059 / 280576 bytes), waiting to send 687 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279042 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279454 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280027 / 280576 bytes), waiting to send 711 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279529 / 280576 bytes), waiting to send 2787 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277452 / 280576 bytes), waiting to send 3183 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280510 / 280576 bytes), waiting to send 721 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280294 / 280576 bytes), waiting to send 445 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280318 / 280576 bytes), waiting to send 491 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277423 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279193 / 280576 bytes), waiting to send 2607 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (276559 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279219 / 280576 bytes), waiting to send 2504 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280534 / 280576 bytes), waiting to send 666 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280484 / 280576 bytes), waiting to send 1028 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279965 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280111 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (276875 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278732 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280224 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280312 / 280576 bytes), waiting to send 1336 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279900 / 280576 bytes), waiting to send 2674 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279020 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277248 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278123 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280278 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280260 / 280576 bytes), waiting to send 710 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277681 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (276525 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280283 / 280576 bytes), waiting to send 742 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277954 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280468 / 280576 bytes), waiting to send 769 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280204 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280536 / 280576 bytes), waiting to send 715 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280417 / 280576 bytes), waiting to send 252 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277187 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278839 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279647 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (276546 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280181 / 280576 bytes), waiting to send 755 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279837 / 280576 bytes), waiting to send 769 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280134 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278584 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278214 / 280576 bytes), waiting to send 2595 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280259 / 280576 bytes), waiting to send 647 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277983 / 280576 bytes), waiting to send 3236 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279966 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280411 / 280576 bytes), waiting to send 670 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279291 / 280576 bytes), waiting to send 2483 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279201 / 280576 bytes), waiting to send 2594 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280080 / 280576 bytes), waiting to send 692 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279574 / 280576 bytes), waiting to send 1325 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278444 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278080 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278229 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278115 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279131 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277931 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (276593 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279487 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279996 / 280576 bytes), waiting to send 582 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278459 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277204 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278756 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (276534 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277168 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280429 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280001 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280363 / 280576 bytes), waiting to send 2948 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280494 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (277198 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279569 / 280576 bytes), waiting to send 3060 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280288 / 280576 bytes), waiting to send 341 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (278063 / 280576 bytes), waiting to send 3339 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (276679 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280358 / 280576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (276852 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279369 / 280576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (279758 / 280576 bytes), waiting to send 3718 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (280058 / 280576 bytes), waiting to send 570 bytes
Total frames rendered: 2817, number of frames that lagged: 2 (0.07%) (it's okay for some frames to lag)
RTMPPublisher::SocketLoop: Aborting due to loop exit
Number of b-frames dropped: 98 (3.5%), Number of p-frames dropped: 86 (3.1%), Total 184 (6.6%)
x264: frame I:20 Avg QP:22.96 size: 43372
x264: frame P:953 Avg QP:27.03 size: 5058
x264: frame B:1809 Avg QP:28.63 size: 498
x264: consecutive B-frames: 9.7% 9.9% 2.9% 77.5%
x264: mb I I16..4: 40.4% 31.7% 27.8%
x264: mb P I16..4: 4.8% 4.7% 0.6% P16..4: 10.7% 4.7% 1.4% 0.0% 0.0% skip:73.1%
x264: mb B I16..4: 0.2% 0.2% 0.0% B16..8: 2.3% 0.7% 0.1% direct: 0.3% skip:96.2% L0:41.3% L1:53.0% BI: 5.8%
x264: 8x8 transform intra:44.1% inter:31.2%
x264: coded y,uvDC,uvAC intra: 34.5% 21.9% 7.0% inter: 1.6% 1.0% 0.1%
x264: i16 v,h,dc,p: 36% 39% 16% 9%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 26% 36% 2% 5% 3% 5% 3% 6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 26% 19% 5% 6% 5% 7% 4% 6%
x264: i8c dc,h,v,p: 67% 20% 12% 2%
x264: Weighted P-Frames: Y:0.9% UV:0.2%
x264: kb/s:471.79
