lumisu
Small freeze when transitioning from a scene WITHOUT a display source to a scene WITH a display source, e.g. going from my Window capture scene to my Display capture scene. Transitions between two scenes that either both contain OR both don't contain a display source are smooth.
No other issues from what I can tell, but it makes the transitions look more like a cut. Sucks for me because I love Move and it really messes that up. It happens regardless of the transition type, INCLUDING cut! When using cut, the entire program appears to freeze for about 1/4 to 1/2 second before cutting to the desired scene.
I tried lengthening transition duration. The duration of the freeze was the same and when it ended the sources jumped to where they would be at that point in the transition.
