16:33:13: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
16:33:13: -------------------------------
16:33:13: CPU Name: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz
16:33:13: CPU Speed: 2395MHz
16:33:13: Physical Memory: 4095MB Total, 4095MB Free
16:33:13: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
16:33:13: monitor 1: pos={0, 0}, size={1920, 1080}
16:33:13: Windows Version: 6.2 Build 9200
16:33:13: Aero is Enabled
16:33:13: OBS Modules:
16:33:13: Base Address Module
16:33:13: 00230000 OBS.exe
16:33:13: 5CA10000 OBSApi.dll
16:33:13: 5C7F0000 DShowPlugin.dll
16:33:13: 641C0000 GraphicsCapture.dll
16:33:13: 5C7D0000 NoiseGate.dll
16:33:13: ------------------------------------------
16:33:13: Adapter 1
16:33:13: Video Adapter: Intel(R) HD Graphics 4000
16:33:13: Video Adapter Dedicated Video Memory: 33554432
16:33:13: Video Adapter Shared System Memory: 1711276032
16:33:13: Adapter 2
16:33:13: Video Adapter: NVIDIA GeForce GTX 680M
16:33:13: Video Adapter Dedicated Video Memory: 3221225472
16:33:13: Video Adapter Shared System Memory: 1073676288
16:33:13: =====Stream Start: 2013-06-15, 16:33:13===============================================
16:33:13: Multithreaded optimizations: On
16:33:13: Base resolution: 1280x720
16:33:13: Output resolution: 1280x720
16:33:13: Loading up D3D10...
16:33:13: Playback device Default
16:33:13: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:33:13: Using auxilary audio input: Line In (Realtek High Definition Audio)
16:33:13: Audio Encoding: AAC
16:33:13: bitrate: 192
16:33:13: device: Decklink Video Capture,
16:33:13: device id (null),
16:33:13: chosen type: HDYC, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166833-166833, fourCC: 'HDYC'
16:33:13: audio device: Disable,
16:33:13: audio device id Disabled,
16:33:13:
16:33:13: Using directshow input
16:33:13: Video Encoding: x264
16:33:13: fps: 30
16:33:13: width: 1280, height: 720
16:33:13: preset: medium
16:33:13: CBR: yes
16:33:13: CFR: yes
16:33:13: max bitrate: 2250
16:33:16: Using RTMP service: Twitch / Justin.tv
16:33:16: Server selection: rtmp://live-jfk.justin.tv/app
16:33:17: SO_SNDBUF was at 65536
16:33:17: SO_SNDBUF is now 65536
Error: Texture->Map failed: 0x887a0005 0x8007000e
DXGI_ERROR_DEVICE_REMOVED
16:33:13: Adapter 1
16:33:13: Adapter 2
16:33:13:
16:33:13: fps: 30
16:33:13: CBR: yes
16:33:13: CFR: yes
The other threads about about this error had to do with gpu problems, but here I'm using a capture card which I would think changes things somewhat. It doesn't happen consistently, sometimes it doesn't happen for days.
While not too big of an issue, the video stream from the shuttle is somewhat judderish and sometimes appears as if it doesn't maintain it's framerate and/or skips, if there would be anything I could do to improve this that would be nice.
Upon writing this it occurred to me that I never changed the gpu setting within OBS, so it's been using the intel gpu for a while. I'll change that and hopefully it won't crash the next few times I stream.
