Question / Help Sync Webcam and Mumble Audio
WTFender
First of all, I love OBS and it was very easy to setup and start using, however, I've had one problem.
I am using my webcam to record video and audio constantly, while playing. Additionally, I use "push-to-talk" to chat on mumble with friends (using the same webcam audio input). Although I do not hear my mumble input through my speakers, it seems that it is recording and playing back the audio twice on my stream (in very close intervals).
Is there any way to either disable my audio input being recorded from mumble or to perfectly sync the two audio inputs?
I have tried synching the two audio inputs the best I can by "dialing in" my Mic Time Offset under the OBS Audio options.
Thanks in advance. Attached are my settings for the devices/programs I'm using.
