Bug Report Supreme Commander FPS Drop
19:43:36:
19:43:38: Using directshow input
19:43:38: Using graphics capture
19:43:38: Trying to hook process: SupremeCommander.exe
19:43:38: Scene buffering time set to 400
19:43:38: ------------------------------------------
19:43:38: Video Encoding: x264
19:43:38: fps: 30
19:43:38: width: 908, height: 512
19:43:38: preset: veryfast
19:43:38: profile: high
19:43:38: keyint: 60
19:43:38: CBR: yes
19:43:38: CFR: yes
19:43:38: max bitrate: 1581
19:43:38: buffer size: 1581
19:43:38: using memory capture
60 fps with obs closed, 20-25 fps x264, obs preview w/o encoding, 25 fps w/ amd vce 25 fps
0.655b and 0.653b. gpu and cpu are way under utilized. quad core.
Different scene, 95 fps closed. 40 fps while previewing.
Windows 10
switched to obs multiplatform and it performs way way better.
