Suggestion - Creating a Bin/Folder for Sources
hazzardouz
Would be a neat addition if you could group up multiple sources in a bin or folder so that you can easily organize sources in a scene or to easily disable/enable a group of sources.
For example - I have several sources that fit together to create my overlay on top of my game capture. Say that I wanted to disable the entire overlay on a source without changing scenes - it would be beneficial to have all of these sources grouped up so that I can easily enable/disable the entire overlay with a single button press on a folder in my source list instead of having to tick each source individually.
I quickly created a simple visual demonstration in PhotoShop of what I mean. (just realized the little arrow thing to collapse/expand the group is probably in the right direction, but you get the point, hopefully)
