I just started using BOS to stream and overall I think the software is excellent :D But I have been encountering problems. Every 5 minutes or so I encounter this 5 seconds lag and makes the stream hold back longer than the normal 5 seconds. I have tried changing my setting below the recommended settings BOS gave me but nothing worked :P Can anyone help me?
My specs
- G.SKILL Ripjaws 8GB 2X4GB DDR3-1600
- Intel Core i5 3570K Unlocked Quad Core CPU 3.4GHZ
- Gigabyte GA-Z77X-UD5H Motherboard
- GTX 650 Ti 928MHZ 2GB 5.4GHZ
Here is my log : http://pastebin.com/j8UrB3jt
(It was to long :P)
My specs
(It was to long :P)
