Dinotropia
I have been using the OBS Remote Plugin with no trouble for a couple of months now. Today, suddenly, whenever I tried to preview the stream OBS became unstable and crashed to the desktop. I have verified that the OBS Remote Plugin seems to be the issue, as removing the websocketapiplugin.dll allows me to use OBS normally.
However, I have put a decent amount of work into my remote interface and was hoping someone would have a solution to this problem. I have no clue what would have suddenly caused the problem when it was working fine only 2 days prior. If anyone can shed insight on this problem, I would greatly appreciate it!
This crash appears to have occured in the 'c:\program files (x86)\obs\plugins\websocketapiplugin.dll' module.
Fault address: 0A3D85A8 (c:\program files (x86)\obs\plugins\websocketapiplugin.dll)
OBS version: Open Broadcaster Software v0.651b
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Crashing thread stack trace:
0A64FD30 0A3D85A8 0A3F7794 0A6DAEBA 00000037 0A3E9400 websocketapiplugin.dll!0xa3d85a8
0A64FD4C 0A3E95BB 00000000 76947BE0 B636B513 0A64FDE8 websocketapiplugin.dll!0xa3e95bb
0A64FD94 76947C04 00000000 B7E881E9 00000000 00000000 kernel32.dll!0x76947c04
0A64FDA8 7772AD1F FFFFFFFF 7771022D 00000000 00000000 ntdll.dll!0x7772ad1f
0A64FDF0 7772ACEA 0A3E9400 00000000 00000000 00000000 ntdll.dll!0x7772acea
A minidump was saved to C:\Users\Prime\AppData\Roaming\OBS\crashDumps\OBSCrashDump2015-05-22_4.dmp.
List of loaded modules:
Base Address Module
