Hey guys, for some remember I have a problem with streaming... whenever I start my stream, the upload goes red and my dropped frames goes really high...
After stopping the stream, my OBS just freezes or crashes.
Computer Specs
Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz (8 CPUs), ~3.4GHz
NVIDIA GeForce GTX 650
8.00 GB of RAM
Windows 7, 64-bit
Speedtest
OBS Logs
Video Encoding: http://puu.sh/4cKX5.png
Broadcasting Settings: http://puu.sh/4cKYd.png
Video: http://puu.sh/4cL0n.png
Advance: http://puu.sh/4cL0Q.png
Problem: http://puu.sh/4cL5i.png
Crash Report
Computer Specs
8.00 GB of RAM
Windows 7, 64-bit
Speedtest
OBS Logs
02:00:00: Settings::Video: Enabling Aero
02:00:19: Settings::Video: Disabling Aero
02:04:38: Open Broadcaster Software v0.552b - 32bit (´・ω・`)
02:04:38: -------------------------------
02:04:38: CPU Name: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
02:04:38: CPU Speed: 3400MHz
02:04:38: Physical Memory: 4095MB Total, 4095MB Free
02:04:38: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
02:04:38: monitor 1: pos={0, 0}, size={1920, 1080}
02:04:38: Windows Version: 6.1 Build 7601 S
02:04:38: Aero is Disabled
02:04:38: OBS Modules:
02:04:38: Base Address Module
02:04:38: 01060000 OBS.exe
02:04:38: 53CE0000 OBSApi.dll
02:04:38: 72400000 DShowPlugin.dll
02:04:38: 723E0000 GraphicsCapture.dll
02:04:38: 723C0000 NoiseGate.dll
02:04:38: 723A0000 PSVPlugin.dll
02:04:38: ------------------------------------------
02:04:38: Adapter 1
02:04:38: Video Adapter: NVIDIA GeForce GTX 650
02:04:38: Video Adapter Dedicated Video Memory: 1020985344
02:04:38: Video Adapter Shared System Memory: 3221549056
02:04:38: =====Stream Start: 2013-08-28, 02:04:38===============================================
02:04:38: Multithreaded optimizations: On
02:04:38: Base resolution: 1920x1080
02:04:38: Output resolution: 1280x720
02:04:38: Loading up D3D10 on NVIDIA GeForce GTX 650...
02:04:38: Playback device Default
02:04:38: Using desktop audio input: Speakers (Realtek High Definition Audio)
02:04:38: Using auxilary audio input: Microphone (Siberia v2 Frost Blue)
02:04:38: Audio Encoding: AAC
02:04:38: bitrate: 128
02:04:38: Using Monitor Capture
02:04:38: Using custom x264 settings: "keyint=60"
02:04:38: Video Encoding: x264
02:04:38: fps: 30
02:04:38: width: 1280, height: 720
02:04:38: preset: veryfast
02:04:38: CBR: yes
02:04:38: CFR: yes
02:04:38: max bitrate: 3300
02:04:38: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
02:04:38: MMDeviceAudioSource: Frequency for device 'Microphone (Siberia v2 Frost Blue)' is 352800, samples per sec is 44100
02:05:01: Total frames rendered: 662, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
02:05:01: Total duplicated frames to ensure constant framerate: 0 (0.00%)
02:05:01:
02:05:01: Profiler results:
02:05:01:
02:05:01: ==============================================================
02:05:01: frame - [100%] [avg time: 6.102 ms (cpu time: avg 4.171 ms, total 2761.22 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0983%]
02:05:01: | frame preprocessing and rendering - [73.5%] [avg time: 4.486 ms (cpu time: avg 3.016 ms, total 1996.81 ms)] [avg calls per frame: 1] [children: 59.6%] [unaccounted: 13.9%]
02:05:01: | | scene->Preprocess - [59.6%] [avg time: 3.639 ms (cpu time: avg 2.403 ms, total 1591.21 ms)] [avg calls per frame: 1]
02:05:01: | video encoding and uploading - [26.4%] [avg time: 1.61 ms (cpu time: avg 1.154 ms, total 764.406 ms)] [avg calls per frame: 1] [children: 26%] [unaccounted: 0.393%]
02:05:01: | | flush - [1.87%] [avg time: 0.114 ms (cpu time: avg 0.047 ms, total 31.201 ms)] [avg calls per frame: 1]
02:05:01: | | CopyResource - [0.279%] [avg time: 0.017 ms (cpu time: avg 0.047 ms, total 31.2 ms)] [avg calls per frame: 0]
02:05:01: | | conversion to 4:2:0 - [0.246%] [avg time: 0.015 ms (cpu time: avg 0.023 ms, total 15.601 ms)] [avg calls per frame: 0]
02:05:01: | | call to encoder - [23.5%] [avg time: 1.432 ms (cpu time: avg 1.013 ms, total 670.804 ms)] [avg calls per frame: 0]
02:05:01: | | sending stuff out - [0.131%] [avg time: 0.008 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
02:05:01: | Convert444Threads - [1.06e+003%] [avg time: 64.938 ms (cpu time: avg 1.225 ms, total 811.204 ms)] [avg calls per frame: 1]
02:05:01:
02:05:01: =====Stream End: 2013-08-28, 02:05:01=================================================
02:05:09: Settings::Video: Disabling Aero
02:05:11: =====Stream Start: 2013-08-28, 02:05:11===============================================
02:05:11: Multithreaded optimizations: On
02:05:11: Base resolution: 1920x1080
02:05:11: Output resolution: 1920x1080
02:05:11: ------------------------------------------
02:05:11: Loading up D3D10 on NVIDIA GeForce GTX 650...
02:05:11: Playback device Default
02:05:11: Using desktop audio input: Speakers (Realtek High Definition Audio)
02:05:11: Using auxilary audio input: Microphone (Siberia v2 Frost Blue)
02:05:11: Audio Encoding: AAC
02:05:11: bitrate: 128
02:05:11: Using Monitor Capture
02:05:11: Using custom x264 settings: "keyint=60"
02:05:11: Video Encoding: x264
02:05:11: fps: 30
02:05:11: width: 1920, height: 1080
02:05:11: preset: veryfast
02:05:11: CBR: yes
02:05:11: CFR: yes
02:05:11: max bitrate: 3300
02:05:11: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
02:05:11: MMDeviceAudioSource: Frequency for device 'Microphone (Siberia v2 Frost Blue)' is 352800, samples per sec is 44100
02:05:25: Total frames rendered: 409, number of late frames: 1 (0.24%) (it's okay for some frames to be late)
02:05:25: Total duplicated frames to ensure constant framerate: 0 (0.00%)
02:05:25:
02:05:25: Profiler results:
02:05:25:
02:05:25: ==============================================================
02:05:25: frame - [100%] [avg time: 7.2 ms (cpu time: avg 5.301 ms, total 2168.41 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0833%]
02:05:25: | frame preprocessing and rendering - [63%] [avg time: 4.534 ms (cpu time: avg 2.822 ms, total 1154.41 ms)] [avg calls per frame: 1] [children: 50.6%] [unaccounted: 12.3%]
02:05:25: | | scene->Preprocess - [50.6%] [avg time: 3.645 ms (cpu time: avg 1.907 ms, total 780.005 ms)] [avg calls per frame: 1]
02:05:25: | video encoding and uploading - [36.9%] [avg time: 2.66 ms (cpu time: avg 2.479 ms, total 1014.01 ms)] [avg calls per frame: 1] [children: 36.7%] [unaccounted: 0.222%]
02:05:25: | | flush - [1.15%] [avg time: 0.083 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
02:05:25: | | CopyResource - [0.208%] [avg time: 0.015 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
02:05:25: | | conversion to 4:2:0 - [0.139%] [avg time: 0.01 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
02:05:25: | | call to encoder - [35.2%] [avg time: 2.535 ms (cpu time: avg 2.479 ms, total 1014.01 ms)] [avg calls per frame: 0]
02:05:25: | | sending stuff out - [0.0139%] [avg time: 0.001 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
02:05:25: | Convert444Threads - [887%] [avg time: 63.866 ms (cpu time: avg 2.25 ms, total 920.405 ms)] [avg calls per frame: 1]
02:05:25:
02:05:25: =====Stream End: 2013-08-28, 02:05:25=================================================
02:05:44: =====Stream Start: 2013-08-28, 02:05:44===============================================
02:05:44: Multithreaded optimizations: On
02:05:44: Base resolution: 1920x1080
02:05:44: Output resolution: 1920x1080
02:05:44: ------------------------------------------
02:05:44: Loading up D3D10 on NVIDIA GeForce GTX 650...
02:05:44: Playback device Default
02:05:44: Using desktop audio input: Speakers (Realtek High Definition Audio)
02:05:44: Using auxilary audio input: Microphone (Siberia v2 Frost Blue)
02:05:44: Audio Encoding: AAC
02:05:44: bitrate: 128
02:05:44: Using Monitor Capture
02:05:44: Using custom x264 settings: "keyint=60"
02:05:44: Video Encoding: x264
02:05:44: fps: 30
02:05:44: width: 1920, height: 1080
02:05:44: preset: veryfast
02:05:44: CBR: yes
02:05:44: CFR: yes
02:05:44: max bitrate: 3300
02:05:44: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
02:05:44: MMDeviceAudioSource: Frequency for device 'Microphone (Siberia v2 Frost Blue)' is 352800, samples per sec is 44100
02:05:45: Using RTMP service: Twitch / Justin.tv
02:05:45: Server selection: rtmp://live-ord.justin.tv/app
02:05:46: Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
02:05:47: SO_SNDBUF was at 8192
02:05:47: SO_SNDBUF is now 65536
02:06:27: Total frames rendered: 1290, number of late frames: 1 (0.08%) (it's okay for some frames to be late)
02:06:27: Total duplicated frames to ensure constant framerate: 0 (0.00%)
02:07:27: WARNING: Forcibly terminating a thread after 60000 ms timeout!
Crash Report
This crash appears to have occured in the 'c:\windows\syswow64\kernelbase.dll' module.
**** UNHANDLED EXCEPTION: 80000003
Fault address: 75DC3219 (c:\windows\syswow64\kernelbase.dll)
OBS version: Open Broadcaster Software v0.552b
CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
Crashing thread stack trace:
0018EA24 75DC3219 000004FC 0000EA60 00C21520 00350000 kernelbase.dll!0x75dc3219
0018EA38 0108BD9E 00000000 0018EEF0 01086DF6 00000001 obs.exe!RTMPPublisher::~RTMPPublisher+0x7e
0018EEB0 0108BB1B 00000001 76A82DA4 76A9F1BA 00040D8E obs.exe!RTMPPublisher::`scalar deleting destructor'+0xb
0018EEBC 01086DF6 00350000 010A1D81 00000000 010A1280 obs.exe!OBS::Stop+0x136
0018EEF8 0108572A 00000000 010A1280 00000000 00060C98 obs.exe!OBS::ToggleCapturing+0x1a
0018EF00 010A1D81 76A76D51 0018F004 76A762FA 00040D8E obs.exe!OBS::OBSProc+0xb01
0018EFD4 76A76D91 010A1280 00040D8E 00000111 00001389 user32.dll!0x76a76d91
0018F00C 76A76D3A 00000000 010A1280 00040D8E 00000111 user32.dll!0x76a76d3a
0018F084 76A7965E 012624D0 00000000 010A1280 00001389 user32.dll!0x76a7965e
0018F0C8 76A796C5 00040D8E 00000111 00001389 00060C98 user32.dll!0x76a796c5
0018F0EC 704D4601 003DA6F0 00000000 00060C98 003DA6F0 comctl32.dll!0x704d4601
0018F10C 704D4663 54010000 00000001 00000000 7045B495 comctl32.dll!0x704d4663
0018F128 704D44ED 00060C98 00000202 00000000 000E0029 comctl32.dll!0x704d44ed
0018F188 76A762FA 7045B495 00060C98 00000202 00000000 user32.dll!0x76a762fa
0018F1B4 76A76D3A 00000000 7045B495 00060C98 00000202 user32.dll!0x76a76d3a
0018F22C 76A777C4 7045B495 00000000 0018F2C0 76A9C81F user32.dll!0x76a777c4
0018F28C 76A7788A 0018F33C 76A81246 76A778E2 00090DE1 user32.dll!0x76a7788a
0018F29C 76A9C81F 00040D8E 00000000 00000000 00000000 user32.dll!0x76a9c81f
0018F2C8 0107CCC5 01060000 00000000 0038243D 00000001 obs.exe!WinMain+0x7d5
0018F740 010E1E09 FFFDE000 0018F814 772F9F72 FFFDE000 obs.exe!strstr+0x1c9
0018F7D0 758533AA FFFDE000 77312F5A 00000000 00000000 kernel32.dll!0x758533aa
0018F7DC 772F9F72 010E1E5C FFFDE000 00000000 00000000 ntdll.dll!0x772f9f72
0018F81C 772F9F45 010E1E5C FFFDE000 00000000 00000000 ntdll.dll!0x772f9f45
A minidump was saved to C:\Users\Ryan\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-08-28_2.dmp.
List of loaded modules:
Base Address Module
