Bug Report Stutter lag spikes while streaming CS:GO
Sean McCormack
okay, where do I start? For a couple months now I've had this problem that when ever I stream CS:GO (on any settings low and high) it runs fine, looks great on twitch, everything's good, a nice solid 200 fps, but out of nowhere it spikes to 30 fps and stutters, causing me to usually die in game. I have searched forum after forum, video after video, i have tried everything you can possibly think of, this still happens. I have not ever had this problem before until a couple months ago. I can stream any other game and it wont do this, literally only CS:GO, but its not the game cause it runs fine when I'm not streaming, and also when recording. I'm pretty sure it's some sort of encoding problem, but I have tried tweaking it so much and still with the same results
I REALLY HOPE SOMEONE AT OBS CAN HELP ME WITH THIS :)
UPLOAD SPEED: 6000kbs
thanks,
PubPlays
Here's a log of it happening:
02:41:14: OBS 0.10.1 (64bit, windows)
02:41:14: CPU Name: AMD FX(tm)-8320 Eight-Core Processor
02:41:14: CPU Speed: 4200MHz
02:41:14: Physical Cores: 4, Logical Cores: 8
02:41:14: Physical Memory: 8156MB Total, 3698MB Free
02:41:14: Windows Version: 6.1 Build 7601 Service Pack 1
02:41:14: audio settings reset:
samples per sec: 44100
speakers: 2
buffering (ms): 1000
02:41:14: ---------------------------------
02:41:14: Initializing D3D11..
02:41:14: Available Video Adapters:
02:41:14: Adapter 0: AMD Radeon HD 6900 Series
02:41:14: Loading up D3D11 on adapter AMD Radeon HD 6900 Series (0)
02:41:14: D3D11 loaded sucessfully, feature level used: 45056
02:41:15: video settings reset:
base resolution: 1600x900
output resolution: 1280x720
fps: 60/1
format: NV12
02:41:15: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/ffmpegsumo.dll' not found, loading of module failed
02:41:15: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
02:41:15: Failed to load 'en-US' text for module: 'obs-browser.dll'
02:41:15: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/pdf.dll' not found, loading of module failed
02:41:15: No blackmagic support
02:41:15: Failed to start search for DeckLink devices
02:41:15: output 'adv_stream' (rtmp_output) created
02:41:15: output 'adv_file_output' (flv_output) created
02:41:15: encoder 'streaming_h264' (obs_x264) created
02:41:15: encoder 'adv_aac0' (ffmpeg_aac) created
02:41:15: encoder 'adv_aac1' (ffmpeg_aac) created
02:41:15: encoder 'adv_aac2' (ffmpeg_aac) created
02:41:15: encoder 'adv_aac3' (ffmpeg_aac) created
02:41:15: service 'default_service' (rtmp_common) created
02:41:15: WASAPI: Device 'Speakers (Realtek High Definition Audio)' initialized
02:41:15: source 'Desktop Audio' (wasapi_output_capture) created
02:41:15: WASAPI: Device 'Microphone (Blue Snowball)' initialized
02:41:15: source 'Mic/Aux' (wasapi_input_capture) created
02:41:15: source 'Intermission' (scene) created
02:41:15: source 'CS:GO' (scene) created
02:41:15: source 'Image' (image_source) created
02:41:15: source 'Video Capture Device' (dshow_input) created
02:41:15: source 'Crop' (crop_filter) created
02:41:15: source 'Text (FreeType 2)' (text_ft2_source) created
02:41:15: source 'Image 1' (image_source) created
02:41:16: source 'Text (FreeType 2) 1' (text_ft2_source) created
02:41:16: source 'Image 2' (image_source) created
02:41:16: source 'Image 3' (image_source) created
02:41:16: source 'Text (FreeType 2) 2' (text_ft2_source) created
02:41:16: source 'Game Capture' (game_capture) created
02:41:16: source 'BrowserSource' (browser_source) created
02:41:16: source 'Text (FreeType 2) 3' (text_ft2_source) created
02:41:16: source 'Text (FreeType 2) 4' (text_ft2_source) created
02:41:16: source 'Image 4' (image_source) created
02:41:16: Update check failed: Unable to init SSL Context:
02:41:18: [game-capture: 'Game Capture'] attempting to hook process: csgo.exe
02:41:18: [game-capture: 'Game Capture'] d3d9 shared texture capture successful
02:41:19: [x264 encoder: 'streaming_h264'] preset: veryfast
02:41:19: [x264 encoder: 'streaming_h264'] profile: main
02:41:19: [x264 encoder: 'streaming_h264'] settings:
bitrate: 2500
buffer size: 2500
fps_num: 60
fps_den: 1
width: 1280
height: 720
keyint: 120
cbr: on
02:41:19: Using ffmpeg "aac" aac encoder
02:41:19: FFmpeg AAC: bitrate: 160, channels: 2
02:41:19: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live-jfk.twitch.tv/app...
02:41:20: [rtmp stream: 'adv_stream'] Connection to rtmp://live-jfk.twitch.tv/app successful
02:47:02: [rtmp stream: 'adv_stream'] User stopped the stream
02:47:02: Output 'adv_stream': stopping
02:47:02: Output 'adv_stream': Total frames: 20587
02:47:02: Output 'adv_stream': Number of skipped frames: 0 (0%)
02:47:02: Output 'adv_stream': Number of dropped frames: 366 (1.77782%)
02:47:32: service 'default_service' destroyed
02:47:32: encoder 'streaming_h264' destroyed
02:47:32: encoder 'Track4' destroyed
02:47:32: encoder 'Track3' destroyed
02:47:32: encoder 'Track2' destroyed
02:47:32: encoder 'Track1' destroyed
02:47:32: warning: 2 frames left in the queue on closing
02:47:32: output 'adv_stream' destroyed
02:47:32: output 'adv_file_output' destroyed
02:47:32: source 'Desktop Audio' destroyed
02:47:32: WASAPI: Device 'Speakers (Realtek High Definition Audio)' Terminated
02:47:32: source 'Mic/Aux' destroyed
02:47:32: WASAPI: Device 'Microphone (Blue Snowball)' Terminated
02:47:32: Freeing OBS context data
02:47:32: 15 user source(s) were remaining
02:47:32: source 'Intermission' destroyed
02:47:32: source 'Image 4' destroyed
02:47:32: source 'CS:GO' destroyed
02:47:32: source 'Game Capture' destroyed
02:47:32: source 'Crop' destroyed
02:47:32: source 'Video Capture Device' destroyed
02:47:32: source 'Image' destroyed
02:47:32: source 'Text (FreeType 2)' destroyed
02:47:32: source 'Image 1' destroyed
02:47:32: source 'Text (FreeType 2) 1' destroyed
02:47:32: source 'Image 2' destroyed
02:47:32: source 'Image 3' destroyed
02:47:32: source 'Text (FreeType 2) 2' destroyed
02:47:32: source 'BrowserSource' destroyed
02:47:32: source 'Text (FreeType 2) 3' destroyed
02:47:32: source 'Text (FreeType 2) 4' destroyed
02:47:32: Number of memory leaks: 2
