Good evening,
I am streaming using an M4 Mac Studio and yesterday went fine, but today is being difficult.
I stream 1080p to Twitch at 6000 bitrate using Apple VT H264 Hardware Encoder.
I stream 1080x1920 to TikTok (via StreamElements) at 8000 bitrate using x264 and veryfast (profile high).
I record 1080p ProRes LT.
I have a Replay Buffer of 120s.
Today, while live, I noticed I had a huge spike of encoding lag--I think it went up to nearly 6% before I realized. I ended the recording and replay buffer and it recovered, though it took a good 30 seconds to end the recording/replay, but it didn't cancel my stream or crash OBS.
I let it run for a little while without recording or replay and it seemed to work fine. I turned on Replay Buffer and NOT record, and it seemed to work without any issues for the remainder of my stream.
I've attached what I believe is the relevant log file. Does anyone have any insight into what went wrong? I was recording ProRes 4K yesterday with no overloading, but today I changed the Video tab to scale to 1080p--is that causing a problem? Previously, it was scaling as I sent it to Twitch instead, but I thought that was more resource intensive.
Thank you,
Thank you,
