Streaming issue
aliNxPa
Hello. I have an issue. i try to start streaming on youtube. all good until something happen'.
Minute 46:35 Stream suddenly started being laggy for no reason. Internet was in good standing. my pc was in good standing. in task manager nothing goes higher than 40-50%.
Apss i used: Animaze, discord, FACEIT AC, steam and CS2. And a chrome tab. no error. i tried to search for a solution online, but nothing worked for me. I mean.. my pc is not that bad i guess..
PC SPECS:
CPU: 13th Gen Intel Core I7-13700KF (24CPUs) 3.4Ghz
RAM: 32GB
GPU: Nvidia GeForce RTX 3070 8GB
HDD: 5 TB (Only games on it)
SSD: 1TB (Windows, some games, and important things)
+WATER COOLING
Please don't ignore the pinned posts on this forum
aliNxPa
i attached files. It can t be copy-pasted.
Sorry for that. it was late for me
  • 2025-07-14 20-40-48.txt
Start fixing the issues pointed on the analyzer;
It is better to use the NVENC encoder instead of the CPU one. This also fix the audio buffering in most cases. You can also try using AV1 encoder.
Make sure all your drivers are up to date.
aliNxPa
ACtually i had an issue only on CS2. I limited fps to 200 from maximum and this was good. no more lags. i do some more steps from link u posted. I ll wait until next time and i come with an answer. thank you so much for help!
