Internet:
System Specifications:
OS: Microsoft Windows 7
CPU: Intel I7 3770k @3.7ghz
GPU: NVIDIA GeForce 680
RAM: ~12 GB
Log:
RESULT STREAM: http://sv.twitch.tv/kaninstek/b/379416409
Fraps and the in-game FPS counter never drops below 100 fps (I think) but when I'm playing it feels like 25-30 FPS and the stream shows it as 25-30 fps aswell.
I did a short test with Game Capture instead of Software Catcher and it seemed to increase the performance a bit, but it could also be that I lowered the Quality Blanace from 10 to 8.
I really have no idea what I'm doing, so if anyone could just like help me with what settings would be optimal for me I would greatly appreciate it.
Thanks!
RAM: ~12 GB
Log:
Open Broadcaster Software v0.472b - 64bit ( ^ω^)
CPU Name: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
CPU Speed: 3500MHz
Physical Memory: 12242MB Total, 9202MB Free
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
Aero is Enabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 680
Video Adapter Dedicated Video Memory: 2091581440
Video Adapter Shared System Memory: 2147479552
Base resolution: 1920x1080
Output resolution: 1920x1080
Loading up D3D10...
Playback device {0.0.0.00000000}.{fa3206b7-00d4-41c7-8664-7eb1ecb2402e}
Using desktop audio input: Realtek Digital Output (2- Realtek High Definition Audio)
Audio Encoding: AAC
bitrate: 320
Using Monitor Capture
x264: profile High, level 4.2
Video Encoding: x264
fps: 60
width: 1920, height: 1080
preset: veryfast
CBR: yes
CFR: yes
max bitrate: 4000
Total frames rendered: 48, number of frames that lagged: 48 (100.00%) (it's okay for some frames to lag)
Total duplicated CFR frames: 58
x264: frame I:1 Avg QP:30.34 size: 90033
x264: frame P:16 Avg QP:27.10 size: 13396
x264: frame B:48 Avg QP:28.98 size: 3902
x264: consecutive B-frames: 1.5% 0.0% 0.0% 98.5%
x264: mb I I16..4: 38.7% 34.1% 27.2%
x264: mb P I16..4: 2.5% 0.4% 0.1% P16..4: 18.9% 4.0% 1.7% 0.0% 0.0% skip:72.4%
x264: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.9% 0.1% 0.0% direct: 0.1% skip:98.9% L0:32.4% L1:65.8% BI: 1.8%
x264: 8x8 transform intra:27.3% inter:26.5%
x264: coded y,uvDC,uvAC intra: 41.5% 38.4% 14.8% inter: 2.0% 2.3% 0.3%
x264: i16 v,h,dc,p: 27% 64% 7% 2%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 24% 18% 6% 6% 7% 8% 6% 8%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 35% 12% 4% 6% 5% 7% 4% 5%
x264: i8c dc,h,v,p: 59% 23% 15% 4%
x264: kb/s:3630.77
Loading up D3D10...
Audio Encoding: AAC
bitrate: 320
fps: 60
preset: veryfast
CBR: yes
CFR: yes
max bitrate: 4000
Server selection: rtmp://live-ams.justin.tv/app
bufferTime: 2015, outputRateWindowTime: 1000, dropThreshold: 2515
Total frames rendered: 27250, number of frames that lagged: 27250 (100.00%) (it's okay for some frames to lag)
Total duplicated CFR frames: 51641
x264: frame I:328 Avg QP:26.27 size:164737
x264: frame P:32979 Avg QP:29.78 size: 16694
x264: frame B:45541 Avg QP:33.98 size: 1151
x264: consecutive B-frames: 18.8% 7.4% 15.5% 58.3%
x264: mb I I16..4: 24.6% 32.4% 43.0%
x264: mb P I16..4: 1.5% 1.6% 0.8% P16..4: 11.4% 3.4% 1.9% 0.0% 0.0% skip:79.5%
x264: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 1.5% 0.1% 0.0% direct: 0.3% skip:98.1% L0:54.8% L1:41.8% BI: 3.4%
x264: 8x8 transform intra:39.9% inter:27.0%
x264: coded y,uvDC,uvAC intra: 56.4% 62.5% 35.7% inter: 2.7% 3.2% 0.7%
x264: i16 v,h,dc,p: 37% 30% 25% 8%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 11% 13% 30% 8% 9% 7% 8% 5% 9%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 19% 20% 8% 9% 7% 8% 6% 8%
x264: i8c dc,h,v,p: 57% 22% 15% 7%
x264: kb/s:3999.76
Profiler results:
frame - [100%] [avg time: 48.255 ms] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.23%]
| scene->Preprocess - [80.9%] [avg time: 39.062 ms] [avg calls per frame: 1]
| video encoding and uploading - [18.8%] [avg time: 9.082 ms] [avg calls per frame: 1] [children: 13.1%] [unaccounted: 5.74%]
| | CopyResource - [0.0414%] [avg time: 0.02 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.00414%] [avg time: 0.002 ms] [avg calls per frame: 0]
| | call to encoder - [13%] [avg time: 6.263 ms] [avg calls per frame: 2]
| | sending stuff out - [0.0601%] [avg time: 0.029 ms] [avg calls per frame: 2]
Thanks!
