Hi there,
My specs:
i7 3770k @ 4.5Ghz
16Gb TridentX @ 2400Mhz
GTX Titan.
My speedtests:
Local
Germany,Frankfurt
My OBS settings:
I was streaming Diablo III and I noticed this in OBS:
Here is the log:
It looks like the OBS was struggling with twitch...
Do I need to change anything in the settings?
All suggestions are welcome
My specs:
i7 3770k @ 4.5Ghz
GTX Titan.
My speedtests:
Local
Germany,Frankfurt
My OBS settings:
Here is the log:
17:32:36: Open Broadcaster Software v0.51.01b (kamehameha test build) - 64bit ( ^ω^)
17:32:36: -------------------------------
17:32:36: CPU Name: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
17:32:36: CPU Speed: 3500MHz
17:32:36: Physical Memory: 16330MB Total, 12968MB Free
17:32:36: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
17:32:36: monitor 1: pos={0, 0}, size={1920, 1080}
17:32:36: Windows Version: 6.1 Build 7601 S
17:32:36: Aero is Enabled
17:32:36: ------------------------------------------
17:32:36: Adapter 1
17:32:36: Video Adapter: NVIDIA GeForce GTX TITAN
17:32:36: Video Adapter Dedicated Video Memory: 2055929856
17:32:36: Video Adapter Shared System Memory: 3998648320
17:32:36: =====Stream Start: 2013-05-13, 17:32:36===============================================
17:32:36: Multithreaded optimizations: On
17:32:36: Base resolution: 1920x1080
17:32:36: Output resolution: 1280x720
17:32:36: Loading up D3D10...
17:32:36: Playback device Default
17:32:36: Using desktop audio input: Speakers (USB PnP Sound Device)
17:32:36: Audio Encoding: AAC
17:32:36: bitrate: 96
17:32:36: Using graphics capture
17:32:36: Video Encoding: x264
17:32:36: fps: 45
17:32:36: width: 1280, height: 720
17:32:36: preset: faster
17:32:36: CBR: no
17:32:36: CFR: no
17:32:36: max bitrate: 2800
17:32:36: buffer size: 2800
17:32:36: quality: 10
17:32:36: SharedTexCapture hooked
17:32:37: Total frames rendered: 18, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
17:32:37: =====Stream End: 2013-05-13, 17:32:37=================================================
17:32:51: =====Stream Start: 2013-05-13, 17:32:51===============================================
17:32:51: Multithreaded optimizations: On
17:32:51: Base resolution: 1920x1080
17:32:51: Output resolution: 1280x720
17:32:51: ------------------------------------------
17:32:51: Loading up D3D10...
17:32:51: Playback device Default
17:32:51: Using desktop audio input: Speakers (USB PnP Sound Device)
17:32:51: Audio Encoding: AAC
17:32:51: bitrate: 96
17:32:51: Using graphics capture
17:32:51: Video Encoding: x264
17:32:51: fps: 45
17:32:51: width: 1280, height: 720
17:32:51: preset: faster
17:32:51: CBR: no
17:32:51: CFR: no
17:32:51: max bitrate: 2800
17:32:51: buffer size: 2800
17:32:51: quality: 10
17:32:51: SharedTexCapture hooked
17:32:53: Total frames rendered: 83, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
17:32:53: =====Stream End: 2013-05-13, 17:32:53=================================================
17:32:55: Using fixed low latency mode, factor 20
17:32:55: =====Stream Start: 2013-05-13, 17:32:55===============================================
17:32:55: Multithreaded optimizations: On
17:32:55: Base resolution: 1920x1080
17:32:55: Output resolution: 1280x720
17:32:55: ------------------------------------------
17:32:55: Loading up D3D10...
17:32:55: Playback device Default
17:32:55: Using desktop audio input: Speakers (USB PnP Sound Device)
17:32:55: Audio Encoding: AAC
17:32:55: bitrate: 96
17:32:55: Using graphics capture
17:32:55: Video Encoding: x264
17:32:55: fps: 45
17:32:55: width: 1280, height: 720
17:32:55: preset: faster
17:32:55: CBR: no
17:32:55: CFR: no
17:32:55: max bitrate: 2800
17:32:55: buffer size: 2800
17:32:55: quality: 10
17:32:55: SharedTexCapture hooked
17:32:57: Using RTMP service: Twitch / Justin.tv
17:32:57: Server selection: rtmp://live-fra.justin.tv/app
17:32:58: SO_SNDBUF was at 8192
17:32:58: SO_SNDBUF is now 65536
17:39:06: Total frames rendered: 16702, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
17:39:06: RTMPPublisher::SocketLoop: Aborting due to loop exit
17:39:06: Number of times waited to send: 186, Waited for a total of 657972 bytes
17:39:06: Number of b-frames dropped: 75 (0.45%), Number of p-frames dropped: 46 (0.28%), Total 121 (0.73%)
17:39:06: =====Stream End: 2013-05-13, 17:39:06=================================================
17:39:09:
17:39:09: Profiler results:
17:39:09:
17:39:09: ==============================================================
17:39:09: frame - [100%] [avg time: 0.997 ms] [avg calls per frame: 1] [children: 82.9%] [unaccounted: 17.1%]
17:39:09: | scene->Preprocess - [0%] [avg time: 0 ms] [avg calls per frame: 1]
17:39:09: | video encoding and uploading - [82.9%] [avg time: 0.827 ms] [avg calls per frame: 1] [children: 81.4%] [unaccounted: 1.5%]
17:39:09: | | CopyResource - [0.802%] [avg time: 0.008 ms] [avg calls per frame: 0]
17:39:09: | | conversion to 4:2:0 - [0.401%] [avg time: 0.004 ms] [avg calls per frame: 0]
17:39:09: | | call to encoder - [79.1%] [avg time: 0.789 ms] [avg calls per frame: 0]
17:39:09: | | sending stuff out - [1.1%] [avg time: 0.011 ms] [avg calls per frame: 0]
17:39:09:
