Shifter
Hello guys,
I've recently gotten into streaming but I'm not satisfied with my quality.
First off my specs:
i5 2500k @ 4.3ghz
8GB Vengeance LP
7950 DC2T @ 1100/1250
P8P67 Pro
100mbit/100mbit Down/Up
If you take a look at my VoD it's hard to make things out when it's going a wee bit fast in NFS.
I'm streaming in 720p @ 60fps with the help from dxtory. I use these settings although I do not record, just use directshow output:
This image is taken from this guide.
All the feedback on how I can improve my streaming is appreciated and I will try to test the different suggestions and post a short (~3 min) video of the new settings you suggest.
First off my specs:
i5 2500k @ 4.3ghz
8GB Vengeance LP
P8P67 Pro
Open Broadcaster Software v0.466a - 64bit ( ^ω^)
CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
CPU Speed: 3300MHz
Physical Memory: 8159MB Total, 4441MB Free
stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
Aero is Disabled
Adapter 1
Video Adapter: AMD Radeon HD 7900 Series
Video Adapter Dedicated Video Memory: 3201495040
Video Adapter Shared System Memory: 4009304064
Base resolution: 1920x1080
Output resolution: 1280x720
Loading up D3D10...
Using 7.1 surround speaker setup (experimental)
Using auxilary audio input: G35 (Logitech G35 Headset)
Audio Encoding: AAC
bitrate: 192
DShowPlugin: No audio pin, result = 80004005
device: Dxtory Video 1,
device id (null),
chosen type: RGB32, usingFourCC: false, res: 1280x720 - 1280x720, fps: 60.0002-60.0002, fourCC: 00000000
Using directshow input
Video Encoding: x264
fps: 60
width: 1280, height: 720
preset: veryfast
CBR: no
max bitrate: 3000
buffer size: 3000
quality: 10
Server selection: ﻀ!
bufferTime: 1899, outputRateWindowTime: 1000, dropThreshold: 2399
RTMPPublisher::BufferedSend: Buffer is full (408206 / 408576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (408108 / 408576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Buffer is full (405586 / 408576 bytes), waiting to send 3417 bytes
RTMPPublisher::BufferedSend: Buffer is full (406652 / 408576 bytes), waiting to send 3741 bytes
RTMPPublisher::BufferedSend: Buffer is full (408511 / 408576 bytes), waiting to send 599 bytes
RTMPPublisher::BufferedSend: Buffer is full (408338 / 408576 bytes), waiting to send 626 bytes
RTMPPublisher::BufferedSend: Buffer is full (405411 / 408576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Buffer is full (408393 / 408576 bytes), waiting to send 526 bytes
Total frames rendered: 13420, number of frames that lagged: 129 (0.96%) (it's okay for some frames to lag)
Number of b-frames dropped: 233 (1%), Number of p-frames dropped: 40 (0.17%), Total 273 (1.2%)
Profiler results:
frame - [100%] [avg time: 4.558 ms] [avg calls per frame: 1] [children: 99.3%] [unaccounted: 0.68%]
| scene->Preprocess - [17%] [avg time: 0.773 ms] [avg calls per frame: 1]
| video encoding and uploading - [82.4%] [avg time: 3.754 ms] [avg calls per frame: 1] [children: 28.8%] [unaccounted: 53.6%]
| | CopyResource - [7.7%] [avg time: 0.351 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.0439%] [avg time: 0.002 ms] [avg calls per frame: 0]
| | call to encoder - [20.7%] [avg time: 0.945 ms] [avg calls per frame: 0]
| | sending stuff out - [0.329%] [avg time: 0.015 ms] [avg calls per frame: 0]
