Bug Report Stream freezes with sound
dodgepong
Administrator
Community Helper
Can you post your log? http://obsproject.com/forum/viewtopic.php?f=6&t=97
The best way to stream LoL is to set up 2 scenes. First, keep Aero enabled. Then, in the first scene, have a Window Capture of the LoL client, and in the second scene, have a Game Capture of the actual LoL game (or Window capture if the game is in Windowed or Borderless mode). Then use the Simple Scene Switcher to automatically swap between them: viewtopic.php?f=11&t=1785 Avoid Monitor capture altogether.
deaththekid5
01:44:32: Open Broadcaster Software v0.592b - 64bit ( ^ω^)
01:44:32: -------------------------------
01:44:32: CPU Name: Intel(R) Core(TM)2 Duo CPU     E7400  @ 2.80GHz
01:44:32: CPU Speed: 2805MHz
01:44:32: Physical Memory:  4095MB Total, 2427MB Free
01:44:32: stepping id: 10, model 23, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 2, total cores 2
01:44:32: monitor 1: pos={0, 0}, size={1024, 768}
01:44:32: Windows Version: 6.2 Build 9200
01:44:32: Aero is Enabled
01:44:32: OBS Modules:
01:44:32: Base Address     Module
01:44:32: 0000000048330000 OBS.exe
01:44:32: 000000006D050000 OBSApi.dll
01:44:32: 000000007A2A0000 DShowPlugin.dll
01:44:32: 000000007F3E0000 GraphicsCapture.dll
01:44:32: 000000007F3B0000 NoiseGate.dll
01:44:32: 000000007E570000 PSVPlugin.dll
01:44:32: ------------------------------------------
01:44:32: Adapter 1
01:44:32:   Video Adapter: NVIDIA GeForce 9500 GT
01:44:32:   Video Adapter Dedicated Video Memory: 1048117248
01:44:32:   Video Adapter Shared System Memory: 2147084288
01:44:32:   Video Adapter Output 1: pos={0, 0}, size={1024, 768}, attached=true
01:44:32: Using fixed low latency mode, factor 20
01:44:32: =====Stream Start: 2014-01-10, 01:44:32===============================================
01:44:32:   Multithreaded optimizations: On
01:44:32:   Base resolution: 1024x768
01:44:32:   Output resolution: 1024x768
01:44:32: Loading up D3D10 on NVIDIA GeForce 9500 GT (Adapter 1)...
01:44:32: Audio Format: 44100hz
01:44:32: Playback device {0.0.0.00000000}.{04e05bb5-0916-4515-a88e-5f6b41ddc8a2}
01:44:32: Using desktop audio input: Headphones (High Definition Audio Device)
01:44:32: Audio Encoding: MP3
01:44:32:     bitrate: 128
01:44:32: Using Monitor Capture
01:44:32: Scene buffering time set to 700
01:44:32: Video Encoding: x264
01:44:32:     fps: 40
01:44:32:     width: 1024, height: 768
01:44:32:     preset: fast
01:44:32:     profile: high
01:44:32:     keyint: 250
01:44:32:     CBR: no
01:44:32:     CFR: yes
01:44:32:     max bitrate: 1000
01:44:32:     buffer size: 1000
01:44:32:     quality: 8
01:44:32: MMDeviceAudioSource: Frequency for device 'Headphones (High Definition Audio Device)' is 352800, samples per sec is 44100
01:44:32: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
01:44:34: Using RTMP service: Twitch / Justin.tv
01:44:34:   Server selection: rtmp://live-jfk.justin.tv/app
01:44:34:   Interface: Realtek PCIe FE Family Controller (ethernet, 100 mbps)
01:44:35: Completed handshake with rtmp://live-jfk.justin.tv/app in 305 ms.
01:44:36: SO_SNDBUF was at 65536
01:44:36: SO_SNDBUF is now 65536
02:14:40: Total frames encoded: 51757, total frames duplicated: 49016 (94.70%)
02:14:40: Number of frames skipped due to encoder lag: 48554 (93.81%)
02:14:40: Total frames rendered: 3132, number of late frames: 157 (5.01%) (it's okay for some frames to be late)
02:14:40: RTMPPublisher::SocketLoop: Aborting due to WSAEnumNetworkEvents failure, 10038
02:14:40: Average send payload: 1660 bytes, average send interval: 61 ms
02:14:40: Number of times waited to send: 0, Waited for a total of 0 bytes
02:14:40: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
02:14:40: Number of bytes sent: 49041127
02:14:40:
02:14:40: Profiler time results:
02:14:40:
02:14:40: ==============================================================
02:14:40: video thread frame - [100%] [avg time: 9.152 ms] [children: 92.6%] [unaccounted: 7.4%]
02:14:40: | scene->Preprocess - [1.11%] [avg time: 0.102 ms]
02:14:40: | GPU download and conversion - [91.5%] [avg time: 8.373 ms] [children: 83.1%] [unaccounted: 8.42%]
02:14:40: | | flush - [2.35%] [avg time: 0.215 ms]
02:14:40: | | CopyResource - [80.7%] [avg time: 7.382 ms]
02:14:40: | | conversion to 4:2:0 - [0.0546%] [avg time: 0.005 ms]
02:14:40: Convert444Thread - [100%] [avg time: 1.599 ms] [children: 97.7%] [unaccounted: 2.25%]
02:14:40: | Convert444toNV12 - [97.7%] [avg time: 1.563 ms]
02:14:40: encoder thread frame - [100%] [avg time: 33.904 ms]
02:14:40:
02:14:40:
02:14:40: Profiler CPU results:
02:14:40:
02:14:40: video thread frame - [cpu time: avg 4.844 ms, total 15171.9 ms] [avg calls per frame: 1]
02:14:40: | scene->Preprocess - [cpu time: avg 0.024 ms, total 78.125 ms] [avg calls per frame: 1]
02:14:40: | GPU download and conversion - [cpu time: avg 4.614 ms, total 14453.1 ms] [avg calls per frame: 1]
02:14:40: | | flush - [cpu time: avg 0.099 ms, total 312.5 ms] [avg calls per frame: 1]
02:14:40: | | CopyResource - [cpu time: avg 4.547 ms, total 14109.4 ms] [avg calls per frame: 1]
02:14:40: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
02:14:40: Convert444Thread - [cpu time: avg 1.158 ms, total 3593.75 ms] [avg calls per frame: 1]
02:14:40: | Convert444toNV12 - [cpu time: avg 1.158 ms, total 3593.75 ms] [avg calls per frame: 1]
02:14:40: encoder thread frame - [cpu time: avg 1.78 ms, total 92093.8 ms] [avg calls per frame: 1]
02:14:40:
02:14:40: =====Stream End: 2014-01-10, 02:14:40=================================================
dodgepong
Administrator
Community Helper
Oh wow, your hardware is really really bad, and you're trying to encode at some pretty high settings.
Downscale your resolution to ~360p, change your FPS to 25, and change your x264 preset to ultrafast, and then see how that goes. But dual core CPUs and super-slow GPUs like the 9500GT are absolutely terrible for streaming, so even that might not be enough.
CataclysmShock
I Get the Same Problem when i try to start a stream It goes for a second or two then It freezes but sound keeps playing Normally does the same thing even For game Record But it also ends Much eariler then what i record for. Tryed Installing and Reinstalling to see if that would work and changed Framerate Heres the Log If I did it correctly
02:22:37: Open Broadcaster Software v0.592b - 32bit (´・ω・`)
02:22:37: -------------------------------
02:22:37: CPU Name: AMD FX(tm)-4100 Quad-Core Processor
02:22:37: CPU Speed: 3616MHz
02:22:37: Physical Memory:  4095MB Total, 4095MB Free
02:22:37: stepping id: 2, model 1, family 21, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 2, total cores 2
02:22:37: monitor 1: pos={0, 0}, size={1360, 768}
02:22:37: Windows Version: 6.1 Build 7601 S
02:22:37: Aero is Enabled
02:22:37: OBS Modules:
02:22:37: Base Address     Module
02:22:37: 013E0000         OBS.exe
02:22:37: 64BC0000         OBSApi.dll
02:22:37: 67F80000         DShowPlugin.dll
02:22:37: 6D460000         GraphicsCapture.dll
02:22:37: 694E0000         NoiseGate.dll
02:22:37: 68310000         PSVPlugin.dll
02:22:37: ------------------------------------------
02:22:37: Adapter 1
02:22:37:   Video Adapter: AMD Radeon R9 200 Series
02:22:37:   Video Adapter Dedicated Video Memory: 2128814080
02:22:37:   Video Adapter Shared System Memory: 2166087680
02:22:37:   Video Adapter Output 1: pos={0, 0}, size={1360, 768}, attached=true
02:22:37: =====Stream Start: 2014-01-23, 02:22:37===============================================
02:22:37:   Multithreaded optimizations: On
02:22:37:   Base resolution: 1360x768
02:22:37:   Output resolution: 1360x768
02:22:37: Loading up D3D10 on AMD Radeon R9 200 Series (Adapter 1)...
02:22:37: Audio Format: 48000hz
02:22:37: Playback device {0.0.0.00000000}.{ca1c0e64-666a-420b-b14b-3e90298507b8}
02:22:37: Using desktop audio input: Speakers (4- Turtle Beach PX3 (PC))
02:22:37: Using auxilary audio input: Microphone (4- Turtle Beach PX3 (PC))
02:22:37: Audio Encoding: AAC
02:22:37:     bitrate: 128
02:22:37:     device: MiniCam Pro,
02:22:37:     device id \\?\usb#vid_0c45&pid_60fe&mi_00#6&10c92d2a&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
02:22:37:     chosen type: RGB24, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-666666
02:22:37:     use buffering: false - 0, fourCC: 00000000
02:22:37:     audio device: Disable,
02:22:37:     audio device id Disabled,
02:22:37:
02:22:37: Using directshow input
02:22:37: Using graphics capture
02:22:37: Scene buffering time set to 700
02:22:37: Video Encoding: x264
02:22:37:     fps: 50
02:22:37:     width: 1360, height: 768
02:22:37:     preset: veryfast
02:22:37:     profile: main
02:22:37:     keyint: 100
02:22:37:     CBR: yes
02:22:37:     CFR: yes
02:22:37:     max bitrate: 1000
02:22:37:     buffer size: 1000
02:22:37: MMDeviceAudioSource: Frequency for device 'Speakers (4- Turtle Beach PX3 (PC))' is 352800, samples per sec is 44100
02:22:37: MMDeviceAudioSource: Frequency for device 'Microphone (4- Turtle Beach PX3 (PC))' is 176400, samples per sec is 44100
02:22:46: SharedTexCapture hooked
02:22:54: GraphicsCaptureSource::NewCapture:  eliminating old capture
02:22:54: SharedTexCapture hooked
02:23:04: GraphicsCaptureSource::NewCapture:  eliminating old capture
02:23:04: SharedTexCapture hooked
02:23:50: Total frames encoded: 3615, total frames duplicated: 902 (24.95%)
02:23:50: Number of frames skipped due to encoder lag: 472 (13.06%)
02:23:50: Total frames rendered: 2967, number of late frames: 120 (4.04%) (it's okay for some frames to be late)
02:23:50:
02:23:50: Profiler time results:
02:23:50:
02:23:50: ==============================================================
02:23:50: video thread frame - [100%] [avg time: 3.357 ms] [children: 38.2%] [unaccounted: 61.8%]
02:23:50: | scene->Preprocess - [0.209%] [avg time: 0.007 ms]
02:23:50: | GPU download and conversion - [38%] [avg time: 1.277 ms] [children: 30.4%] [unaccounted: 7.66%]
02:23:50: | | flush - [27%] [avg time: 0.906 ms]
02:23:50: | | CopyResource - [3.19%] [avg time: 0.107 ms]
02:23:50: | | conversion to 4:2:0 - [0.209%] [avg time: 0.007 ms]
02:23:50: Convert444Thread - [100%] [avg time: 1.56 ms] [children: 99.4%] [unaccounted: 0.641%]
02:23:50: | Convert444toNV12 - [99.4%] [avg time: 1.55 ms]
02:23:50: encoder thread frame - [100%] [avg time: 5.307 ms]
02:23:50:
02:23:50:
02:23:50: Profiler CPU results:
02:23:50:
02:23:50: video thread frame - [cpu time: avg 0.173 ms, total 515.625 ms] [avg calls per frame: 1]
02:23:50: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
02:23:50: | GPU download and conversion - [cpu time: avg 0.068 ms, total 203.125 ms] [avg calls per frame: 1]
02:23:50: | | flush - [cpu time: avg 0.057 ms, total 171.875 ms] [avg calls per frame: 1]
02:23:50: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
02:23:50: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
02:23:50: Convert444Thread - [cpu time: avg 1.377 ms, total 4031.25 ms] [avg calls per frame: 1]
02:23:50: | Convert444toNV12 - [cpu time: avg 1.371 ms, total 4015.63 ms] [avg calls per frame: 1]
02:23:50: encoder thread frame - [cpu time: avg 1.016 ms, total 3640.63 ms] [avg calls per frame: 1]
02:23:50:
02:23:50: =====Stream End: 2014-01-23, 02:23:50=================================================
02:23:52: =====Stream Start: 2014-01-23, 02:23:52===============================================
02:23:52:   Multithreaded optimizations: On
02:23:52:   Base resolution: 1360x768
02:23:52:   Output resolution: 1360x768
02:23:52: ------------------------------------------
02:23:52: Loading up D3D10 on AMD Radeon R9 200 Series (Adapter 1)...
02:23:52: Audio Format: 48000hz
02:23:52: Playback device {0.0.0.00000000}.{ca1c0e64-666a-420b-b14b-3e90298507b8}
02:23:52: Using desktop audio input: Speakers (4- Turtle Beach PX3 (PC))
02:23:52: Using auxilary audio input: Microphone (4- Turtle Beach PX3 (PC))
02:23:52: Audio Encoding: AAC
02:23:52:     bitrate: 128
02:23:52:     device: MiniCam Pro,
02:23:52:     device id \\?\usb#vid_0c45&pid_60fe&mi_00#6&10c92d2a&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
02:23:52:     chosen type: RGB24, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-666666
02:23:52:     use buffering: false - 0, fourCC: 00000000
02:23:52:     audio device: Disable,
02:23:52:     audio device id Disabled,
02:23:52:
02:23:52: Using directshow input
02:23:52: Using graphics capture
02:23:52: Scene buffering time set to 700
02:23:52: Video Encoding: x264
02:23:52:     fps: 50
02:23:52:     width: 1360, height: 768
02:23:52:     preset: veryfast
02:23:52:     profile: main
02:23:52:     keyint: 100
02:23:52:     CBR: yes
02:23:52:     CFR: yes
02:23:52:     max bitrate: 1000
02:23:52:     buffer size: 1000
02:23:52: MMDeviceAudioSource: Frequency for device 'Speakers (4- Turtle Beach PX3 (PC))' is 352800, samples per sec is 44100
02:23:52: MMDeviceAudioSource: Frequency for device 'Microphone (4- Turtle Beach PX3 (PC))' is 176400, samples per sec is 44100
02:24:18: SharedTexCapture hooked
02:24:42: Total frames encoded: 2252, total frames duplicated: 1620 (71.94%)
02:24:42: Number of frames skipped due to encoder lag: 1557 (69.14%)
02:24:42: Total frames rendered: 687, number of late frames: 20 (2.91%) (it's okay for some frames to be late)
02:24:42:
02:24:42: Profiler time results:
02:24:42:
02:24:42: ==============================================================
02:24:42: video thread frame - [100%] [avg time: 2.346 ms] [children: 36.4%] [unaccounted: 63.6%]
02:24:42: | scene->Preprocess - [13.1%] [avg time: 0.307 ms]
02:24:42: | GPU download and conversion - [23.4%] [avg time: 0.548 ms] [children: 20%] [unaccounted: 3.32%]
02:24:42: | | flush - [13.4%] [avg time: 0.315 ms]
02:24:42: | | CopyResource - [6.39%] [avg time: 0.15 ms]
02:24:42: | | conversion to 4:2:0 - [0.213%] [avg time: 0.005 ms]
02:24:42: Convert444Thread - [100%] [avg time: 1.65 ms] [children: 99.3%] [unaccounted: 0.667%]
02:24:42: | Convert444toNV12 - [99.3%] [avg time: 1.639 ms]
02:24:42: encoder thread frame - [100%] [avg time: 16.935 ms]
02:24:42:
02:24:42:
02:24:42: Profiler CPU results:
02:24:42:
02:24:42: video thread frame - [cpu time: avg 0.386 ms, total 265.625 ms] [avg calls per frame: 1]
02:24:42: | scene->Preprocess - [cpu time: avg 0.159 ms, total 109.375 ms] [avg calls per frame: 1]
02:24:42: | GPU download and conversion - [cpu time: avg 0.068 ms, total 46.875 ms] [avg calls per frame: 1]
02:24:42: | | flush - [cpu time: avg 0.045 ms, total 31.25 ms] [avg calls per frame: 1]
02:24:42: | | CopyResource - [cpu time: avg 0.024 ms, total 15.625 ms] [avg calls per frame: 1]
02:24:42: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
02:24:42: Convert444Thread - [cpu time: avg 1.328 ms, total 859.375 ms] [avg calls per frame: 1]
02:24:42: | Convert444toNV12 - [cpu time: avg 1.328 ms, total 859.375 ms] [avg calls per frame: 1]
02:24:42: encoder thread frame - [cpu time: avg 1.191 ms, total 2640.63 ms] [avg calls per frame: 1]
02:24:42:
02:24:42: =====Stream End: 2014-01-23, 02:24:42=================================================
02:25:50: =====Stream Start: 2014-01-23, 02:25:50===============================================
02:25:50:   Multithreaded optimizations: On
02:25:50:   Base resolution: 1360x768
02:25:50:   Output resolution: 1360x768
02:25:50: ------------------------------------------
02:25:50: Loading up D3D10 on AMD Radeon R9 200 Series (Adapter 1)...
02:25:50: Audio Format: 48000hz
02:25:51: Playback device {0.0.0.00000000}.{ca1c0e64-666a-420b-b14b-3e90298507b8}
02:25:51: ------------------------------------------
02:25:51: Using desktop audio input: Speakers (4- Turtle Beach PX3 (PC))
02:25:52: ------------------------------------------
02:25:52: Using auxilary audio input: Microphone (4- Turtle Beach PX3 (PC))
02:25:53: ------------------------------------------
02:25:53: Audio Encoding: AAC
02:25:53:     bitrate: 128
02:25:53:     device: MiniCam Pro,
02:25:53:     device id \\?\usb#vid_0c45&pid_60fe&mi_00#6&10c92d2a&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
02:25:53:     chosen type: RGB24, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-666666
02:25:53:     use buffering: false - 0, fourCC: 00000000
02:25:53:     audio device: Disable,
02:25:53:     audio device id Disabled,
02:25:53:
02:25:54: Using directshow input
02:25:54: Using graphics capture
02:25:54: Scene buffering time set to 700
02:25:54: ------------------------------------------
02:25:54: Video Encoding: x264
02:25:54:     fps: 50
02:25:54:     width: 1360, height: 768
02:25:54:     preset: veryfast
02:25:54:     profile: main
02:25:54:     keyint: 100
02:25:54:     CBR: yes
02:25:54:     CFR: yes
02:25:54:     max bitrate: 1000
02:25:54:     buffer size: 1000
02:25:54: MMDeviceAudioSource: Frequency for device 'Speakers (4- Turtle Beach PX3 (PC))' is 352800, samples per sec is 44100
02:25:54: MMDeviceAudioSource: Frequency for device 'Microphone (4- Turtle Beach PX3 (PC))' is 176400, samples per sec is 44100
02:25:55: SharedTexCapture hooked
02:26:14: Total frames encoded: 299, total frames duplicated: 246 (82.27%)
02:26:14: Number of frames skipped due to encoder lag: 237 (79.26%)
02:26:14: Total frames rendered: 51, number of late frames: 15 (29.41%) (it's okay for some frames to be late)
02:26:15:
02:26:15: Profiler time results:
02:26:15:
02:26:15: ==============================================================
02:26:15: video thread frame - [100%] [avg time: 19.133 ms] [children: 27.5%] [unaccounted: 72.5%]
02:26:15: | scene->Preprocess - [7.1%] [avg time: 1.359 ms]
02:26:15: | GPU download and conversion - [20.4%] [avg time: 3.894 ms] [children: 17.5%] [unaccounted: 2.86%]
02:26:15: | | flush - [17.4%] [avg time: 3.331 ms]
02:26:15: | | CopyResource - [0.0627%] [avg time: 0.012 ms]
02:26:15: | | conversion to 4:2:0 - [0.0157%] [avg time: 0.003 ms]
02:26:15: Convert444Thread - [100%] [avg time: 2.579 ms] [children: 99.7%] [unaccounted: 0.31%]
02:26:15: | Convert444toNV12 - [99.7%] [avg time: 2.571 ms]
02:26:15: encoder thread frame - [100%] [avg time: 69.506 ms]
02:26:15:
02:26:15:
02:26:15: Profiler CPU results:
02:26:15:
02:26:15: video thread frame - [cpu time: avg 0.306 ms, total 15.625 ms] [avg calls per frame: 1]
02:26:15: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
02:26:15: | GPU download and conversion - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
02:26:15: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
02:26:15: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
02:26:15: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 0]
02:26:15: Convert444Thread - [cpu time: avg 1.875 ms, total 46.875 ms] [avg calls per frame: 1]
02:26:15: | Convert444toNV12 - [cpu time: avg 1.875 ms, total 46.875 ms] [avg calls per frame: 1]
02:26:15: encoder thread frame - [cpu time: avg 1.302 ms, total 343.75 ms] [avg calls per frame: 1]
02:26:15:
02:26:15: =====Stream End: 2014-01-23, 02:26:15=================================================
Lain
Lain
02:22:37: [..], logical cores 2, total cores 2
02:22:37: fps: 50
You need more downscale, less FPS. Your computer is trying to encode an HD stream at high FPS when you only have 2 cores. Your computer just isn't powerful enough to handle it. Use more downscale, and use 30fps.
