I just got a new rig and am looking to stream all my games. Just to test out the stream I loaded up Antichamber and the stream was constantly dropping frames.
I tried all kinds of settings and resolutions but nothing really fixed it or made it better. Not sure what type of information you would need to know how to help me out but just let me know and I will post em up! Thanks
18:08:26: Open Broadcaster Software v0.541b - 32bit (´・ω・`)
18:08:26: -------------------------------
18:08:26: CPU Name: Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz
18:08:26: CPU Speed: 3600MHz
18:08:26: Physical Memory: 4095MB Total, 4095MB Free
18:08:26: stepping id: 7, model 13, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
18:08:26: monitor 1: pos={0, 0}, size={1920, 1080}
18:08:26: Windows Version: 6.2 Build 9200
18:08:26: Aero is Enabled
18:08:26: OBS Modules:
18:08:26: Base Address Module
18:08:26: 00B80000 OBS.exe
18:08:26: 6F910000 OBSApi.dll
18:08:26: 70020000 DShowPlugin.dll
18:08:26: 70000000 GraphicsCapture.dll
18:08:26: 6FFE0000 NoiseGate.dll
18:08:26: 6FE00000 PSVPlugin.dll
18:08:26: ------------------------------------------
18:08:26: Adapter 1
18:08:26: Video Adapter: AMD Radeon HD 7900 Series
18:08:26: Video Adapter Dedicated Video Memory: 3194155008
18:08:26: Video Adapter Shared System Memory: 1100746752
18:08:26: =====Stream Start: 2013-07-18, 18:08:26===============================================
18:08:26: Multithreaded optimizations: On
18:08:26: Base resolution: 1920x1080
18:08:26: Output resolution: 1280x720
18:08:26: Loading up D3D10...
18:08:26: Playback device Default
18:08:26: Using desktop audio input: Speakers (2- Plantronics GameCom 780)
18:08:27: ------------------------------------------
18:08:27: Using auxilary audio input: Microphone (2- Plantronics GameCom 780)
18:08:27: Audio Encoding: AAC
18:08:27: bitrate: 256
18:08:27: device: Logitech HD Webcam C525,
18:08:27: device id \\?\usb#vid_046d&pid_0826&mi_02#7&2c438089&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:08:27: chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
18:08:27: audio device: Disable,
18:08:27: audio device id Disabled,
18:08:27:
18:08:27: Using directshow input
18:08:27: Using graphics capture
18:08:27: Video Encoding: x264
18:08:27: fps: 45
18:08:27: width: 1280, height: 720
18:08:27: preset: fast
18:08:27: CBR: no
18:08:27: CFR: no
18:08:27: max bitrate: 2293
18:08:27: buffer size: 2293
18:08:27: quality: 7
18:08:27: SharedTexCapture hooked
18:08:29: Using RTMP service: Twitch / Justin.tv
18:08:29: Server selection: rtmp://live-iad.justin.tv/app
18:08:31: SO_SNDBUF was at 65536
18:08:31: SO_SNDBUF is now 65536
18:08:43: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 131072
18:09:14: Total frames rendered: 2121, number of frames that lagged: 2 (0.09%) (it's okay for some frames to lag)
18:09:14: RTMPPublisher::SocketLoop: Aborting due to bStopping
18:09:14: Number of times waited to send: 10, Waited for a total of 33280 bytes
18:09:14: Number of b-frames dropped: 20 (1.1%), Number of p-frames dropped: 135 (7.2%), Total 155 (8.3%)
18:09:14: =====Stream End: 2013-07-18, 18:09:14=================================================
18:10:36: =====Stream Start: 2013-07-18, 18:10:36===============================================
18:10:36: Multithreaded optimizations: On
18:10:36: Base resolution: 1920x1080
18:10:36: Output resolution: 960x540
18:10:36: ------------------------------------------
18:10:36: Loading up D3D10...
18:10:36: Playback device Default
18:10:36: Using desktop audio input: Speakers (2- Plantronics GameCom 780)
18:10:36: Using auxilary audio input: Microphone (2- Plantronics GameCom 780)
18:10:36: Audio Encoding: AAC
18:10:36: bitrate: 256
18:10:36: device: Logitech HD Webcam C525,
18:10:36: device id \\?\usb#vid_046d&pid_0826&mi_02#7&2c438089&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:10:36: chosen type: I420, usingFourCC: false, res: 1600x896 - 1600x896, frameIntervals: 333333-2000000, fourCC: 'I420'
18:10:36: audio device: Disable,
18:10:36: audio device id Disabled,
18:10:36:
18:10:36: Using directshow input
18:10:36: Using graphics capture
18:10:37: ------------------------------------------
18:10:37: Video Encoding: x264
18:10:37: fps: 45
18:10:37: width: 960, height: 540
18:10:37: preset: fast
18:10:37: CBR: no
18:10:37: CFR: no
18:10:37: max bitrate: 2293
18:10:37: buffer size: 2293
18:10:37: quality: 7
18:10:37: SharedTexCapture hooked
18:10:39: Using RTMP service: Twitch / Justin.tv
18:10:39: Server selection: rtmp://live-iad.justin.tv/app
18:10:41: SO_SNDBUF was at 65536
18:10:41: SO_SNDBUF is now 65536
18:11:25: Total frames rendered: 2195, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
18:11:26: RTMPPublisher::SocketLoop: Aborting due to bStopping
18:11:26: Number of times waited to send: 0, Waited for a total of 0 bytes
18:11:26: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
18:11:26: =====Stream End: 2013-07-18, 18:11:26=================================================
18:17:13:
18:17:13: Profiler results:
18:17:13:
18:17:13: ==============================================================
18:17:13: frame - [100%] [avg time: 1.947 ms (cpu time: avg 1.647 ms, total 7109.38 ms)] [avg calls per frame: 1] [children: 70.9%] [unaccounted: 29.1%]
18:17:13: | scene->Preprocess - [21.9%] [avg time: 0.426 ms (cpu time: avg 0.365 ms, total 1578.13 ms)] [avg calls per frame: 1]
18:17:13: | video encoding and uploading - [49%] [avg time: 0.954 ms (cpu time: avg 0.886 ms, total 3828.13 ms)] [avg calls per frame: 1] [children: 47.9%] [unaccounted: 1.13%]
18:17:13: | | CopyResource - [0.462%] [avg time: 0.009 ms (cpu time: avg 0.01 ms, total 46.875 ms)] [avg calls per frame: 0]
18:17:13: | | conversion to 4:2:0 - [0.257%] [avg time: 0.005 ms (cpu time: avg 0.003 ms, total 15.625 ms)] [avg calls per frame: 0]
18:17:13: | | call to encoder - [46.6%] [avg time: 0.907 ms (cpu time: avg 0.872 ms, total 3765.63 ms)] [avg calls per frame: 0]
18:17:13: | | sending stuff out - [0.565%] [avg time: 0.011 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
18:17:13: | Convert444Threads - [2.26e+003%] [avg time: 43.967 ms (cpu time: avg 0.749 ms, total 3234.38 ms)] [avg calls per frame: 1]
18:17:13:
