Stream Crash Problems
MysticMags13
Hey everyone, I've read and seen so many stream crash problems but no matter what I do or what streaming platform I use, my stream crashes. I don't know what to do, and I know this forum is the best for tech help. I'm going to attach my recent logs, and crash logs. My stream could crash anywhere from every 20 minutes to every 2 hours. I've played with the bitrates; my bandwidth is pretty good, and my PC is fairly new. I do stream Wi-Fi right now but by the time everyone sees this post, I'll have an ethernet cord in my system, but I don't think that's the problem? I have documented my download/upload speeds via Wi-Fi in the notes towards the bottom. I. Am. Struggling. I don't want to throw in the towel with streaming, but I can't get anywhere with it crashing so much.
My video Bitrate is at 5000 Kbps, it was at 6000 but I brought it down
My audio bitrate is at 192.
I've turned ON and OFF Dynamic bitrate, doesn't seem to really change anything for me.
Nothing needs to be updated on my PC.
I did turn off Hardware-accelerated GPU scheduling in my settings but that's because in one of my reports run through the OBS Analyzer, it said to?
I have Optimizatios for Windowed Games off too, should I have that on?
My Set Up is: POWERSPEC G445 129K/32/1/4070/P with 2 Acer 27" IPS XV272U monitors.
My download speed: 741.84 Mbps
My upload speed: 70.88
https://obsproject.com/logs/8trbzcVJfy3BijzE
  • 2024-05-28 21-04-59.txt
  • 2024-05-29 19-53-10.txt
  • 2024-05-30 16-02-14.txt
  • 2024-05-30 16-46-56.txt
  • 2024-05-30 17-06-09.txt
  • 2024-05-30 21-14-18.txt
  • 2024-05-30 22-01-47.txt
  • 2024-05-30 22-19-33.txt
When you say "stream crash", do you mean "the OBS program crashes when I stream", "my stream fails after a while", or "my streams don't start"? The crash dump (meaning OBS crashed) you link to is from March 11. The log files all seem to show normal OBS shutdowns.
All of the logs show piles of Content Security Policy failures, meaning that lots of Javascript you are presumably hoping to run is NOT being run.
MysticMags13
MysticMags13
How do I figure out the content security policy failures? I have no idea what that means. My stream crashes aka stops and then will restart. I didn’t realize the link was from march. Apologies. The logs are way more recent.
