Stream bitrate goes to 0 when display capture is visible - Youtube
rianradeck
Stream starts with no problem on youtube since you do not show your display. I tried with game capture and image capture and both worked fine, but as soon as I click to show my screen the stream bitrate drops to 0 and youtube closes it. Have no ideia why, but it works just fine on twitch this issue just happend on youtube and only when my display capture is visible.
I saw on log that OBS receives a FD_CLOSE when display capture is visible, but I can't tell if this is a Youtube problem, a client side problem or a bug in the software.
15:11:43 - Clicked start stream button (camera visible, game capture visible and camera frame visible)
15:12:22 - Set display capture to visible
And then the bitrate drops to 0.
PS. Tried with only the notebook monitor too, same problem.
  • 2021-06-17 15-11-31.txt
rianradeck
Game capture and window capture don't work either, sorry for not testing it properly.
The moment any of them starts actually displaying somethig the bitrate goes to 0.
